S-PAutomotive.com
Author Topic: Kia mtdi pump on 1Z  (Read 21454 times)
Reply #15December 04, 2009, 10:10:33 pm
oldskool rich
  • 446
Re: Kia mtdi pump on 1Z
« Reply #15 on: December 04, 2009, 10:10:33 pm »
i can get you one ::)
if we are talking about the same bracket
if you cant find one that is
f6squared I.D.S.T
Reply #16December 07, 2009, 07:06:37 am
gigaz2
  • 626
« Reply #16 on: December 07, 2009, 07:06:37 am »
that would be super mate, let me know how much you want for it, and, can you get it wheigted so we calculate postage to Portugal?
Reply #17August 05, 2019, 10:25:53 am
Dino
  • 44
« Reply #17 on: August 05, 2019, 10:25:53 am »
Hello.
Any info about pump code? How many pumps are there?
I found those codes.
0460414191    VE4/11F2000R790-1
REPLACING PARTS:
ORDER NUMBER    DESIGNATION    CODE    POSITION    QUANTITY
2 460 283 001    SHAFT SEALING RING    2460283001    3    1
1 467 030 308    SUPPLY PUMP    1467030308    7    1
1 460 134 317    SUPPORT RING    1460134317    9    1
1 463 429 300    TORX FLAT-HEAD SCREW    1463429300    10    2
1 466 100 405    DRIVE SHAFT    1466100405    12    1
1 460 023 302    WOODRUFF KEY    1460023302    13    1
1 460 056 302    BUFFER    1460056302    15    2
1 466 317 301    TOOTHED GEAR    1466317301    16    1
2 460 102 001    SLIDING DISK    2460102001    17    1
1 460 232 328    ROLLER RING    1460232328    20    1
2 463 100 002    BEARING PIN    2463100002    21    4
2 460 300 005    ROLLER    2460300005    22    4
2 460 120 013    FRICTION WASHER    2460120013    23    4
1 463 103 316    ADJUSTING PIN    1463103316    24    1
1 463 120 359    RETAINING PIN    1463120359    25    1
1 461 310 300    RETAINING BRACKET    1461310300    26    1
1 460 140 334    CROSS DISK    1 460 140 334    27    1
1 466 110 664    CAM PLATE    1466110664    29    1
1 461 074 328    SEALING PLATE    1461074328    30    1
1 463 104 667    TIMING-DEVICE PISTON    1463104667    31    1
1 463 218 312    SLIDING PIECE    1463218312    32    1
1 460 144 302    SHIM RING    1460144302    33    1
1 464 618 934    COMPRESSION SPRING    1464618934    34    1
1 460 100 178    PLAIN WASHER    1460100178    35    1
1 461 038 319    SEALING PLATE    1461038319    36    1
1 467 414 478    PRESSURE MODULATION VALVE    1467414478    37    1
1 463 414 344    TORX FILLISTER SCREW    1463414344    38    2
2 461 038 019    COVER PLATE    2461038019    39    1
1 463 414 344    TORX FILLISTER SCREW    1463414344    40    4
1 468 334 987    HYDRAULIC HEAD    1468334987    50    1
2 460 210 012    O-RING    2460210012    51    1
   SELECTION GROUP SHIM       52    1
1 460 105 305    GASKET    1460105305    54    4
2 463 370 028    FITTING    2463370028    58    4
1 463 414 312    TORX FILLISTER SCREW    1463414312    60    1
1 460 210 008    O-RING    1460210008    66    1
1 467 134 733    MANIFOLD-PRESSURE COMP.    1467134733    67    1
1 463 163 320    PART LOAD GOVERNOR    1463163320    68    1
1 200 101 640    SHIM    1200101640    69    1
1 461 902 251    CONTROL LEVER    1461902251    72    1
1 463 315 310    FLANGE NUT    1463315310    75    1
   ADJUSTING SCREW       88    1
1 461 015 302    GASKET    1461015302    92    1
1 461 907 034    FULCRUM LEVER    1461907034    95    1
2 916 012 017    PLAIN WASHER, DIN 433 - 10,5-160 HV    2916012017    103    1
1 463 452 313    SLOTTED SHOULDER SCREW    1463452313    104    2
1 460 105 307    GASKET    1460105307    105    2
1 464 613 611    COMPRESSION SPRING    1464613611    106    2
1 463 300 304    HEXAGON NUT    1463300304    107    1
1 460 210 313    O-RING    1460210313    109    1
1 461 030 343    SHIM PLATE, 0,95 MM    1461030343    110    1
   SELECTION GROUP SUPPORTING DISK       111    1
1 466 317 319    FLYWEIGHT ASSEMBLY    1466317319    112    1
1 460 100 370    SHIM RING    1460100370    114    1
1 460 422 328    SLIDING SLEEVE    1460422328    115    1
1 460 508 309    SEALING CAP    1460508309    116    1
1 463 203 907    SELECTION GROUP PLUG    1463203907    117    1
2 910 142 207    HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x35-8.8    2910142207    123    4
1 460 210 349    O-RING    1460210349    129    1
2 463 461 002    SCREW PLUG    2463461002    130    1
2 463 461 001    BLEEDER SCREW    2463461001    132    1
1 460 225 081    O-RING    1460225081    133    1
1 460 225 082    O-RING    1460225082    134    3
1 460 362 485    CONTROL VALVE    1460362485    135    1
1 463 456 344    HOLLOW BOLT    1463456344    136    1
1 460 591 315    PROTECTIVE CAP    1460591315    140    1
2 911 202 702    HOLLOW BOLT, DIN 7643 - 8-(3-4)    2911202702    141    1
1 463 457 312    TUBE FITTING    1463457312    142    1
0 281 005 019    SOLENOID-VALVE CONTROL UN    0281005019    184    1
1 467 212 360    ANEROID BOX    1467212360    186    1
2 915 032 028    HEXAGON NUT, DIN 439 - BM16x1,5-06    2915032028    187    1
1 460 101 376    GASKET    1460101376    189    1
2 916 710 603    FLAT SEAL RING, DIN 7603 - A8x11,5-Cu    2916710603    191    2
1 463 385 338    INLET UNION    1463385338    192    1
2 911 222 700    HOLLOW BOLT    2911222700    193    1
1 900 508 001    PROTECTIVE CAP    1900508001    194    1
2 464 633 002    COMPRESSION SPRING    2464633002    200    1
1 464 651 485    COILED SPRING    1464651485    220    1
1 460 100 197    RETAINING WASHER    1460100197    228    1
1 463 314 306    FLANGE NUT    1463314306    230    1
1 461 021 872    BRACKET    1461021872    235    1
1 463 414 305    TORX FILLISTER SCREW    1463414305    237    3
1 464 460 331    CABLE    1464460331    242    1
1 460 105 312    FLAT SEAL RING    1460105312    245    3
1 463 457 312    TUBE FITTING    1463457312    246    1
1 460 591 338    PROTECTIVE CAP    1460591338    247    1
1 463 385 335    INLET UNION    1463385335    250    1
1 460 105 312    FLAT SEAL RING    1460105312    251    3
2 910 142 203    HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x25-8.8    2910142203    254    3
1 461 901 729    HOLDING PLATE    1461901729    271    1
1 461 332 471    MOUNTING BRACKET    1461332471    273    1
1 461 900 600    SWITCH LEVER    1461900600    289    1
1 461 900 599    SWITCH LEVER    1461900599    289    1
1 463 433 313    WASHER-AND-SCREW ASSEMBLY    1463433313    292    1
1 464 650 449    EXTENSION SPRING    1464650449    299    1
1 460 522 328    SPRING SEAT    1460522328    325    1
1 460 522 304    SPRING SEAT    1460522304    329    1
1 463 385 341    INLET UNION    1463385341    331    1
1 463 386 301    VENT FITTING    1463386301    336    1
1 460 558 303    PROTECTIVE CAP    1460558303    339    1
1 460 100 893    PLAIN WASHER    1460100893    346    1
1 900 508 001    PROTECTIVE CAP    1900508001    349    1
1 900 508 003    PROTECTIVE CAP    1900508003    350    1
1 460 793 311    CONNECTING PIPE    1460793311    366    1
1 460 210 322    O-RING    1460210322    392    1
1 463 414 306    LOCKING SCREW    1463414306    393    1
1 461 331 325    INTERMEDIATE PLATE    1461331325    394    1
1 463 433 313    WASHER-AND-SCREW ASSEMBLY    1463433313    406    1
1 460 326 387    DRIVER    1460326387    408    1
1 461 098 361    FASTENING PLATE    1461098361    409    1
1 463 300 319    HEXAGON NUT    1463300319    410    1
1 463 433 310    WASHER-AND-SCREW ASSEMBLY    1463433310    430    1
1 461 329 480    BRACKET    1461329480    431    1
1 463 433 310    WASHER-AND-SCREW ASSEMBLY    1463433310    433    1
1 460 109 304    SEAL RING    1460109304    439    2
1 467 217 393    POTENTIOMETER    1467217393    442    1
1 461 098 344    FASTENING PLATE    1461098344    443    1
1 463 433 320    WASHER-AND-SCREW ASSEMBLY    1463433320    444    2
   SELECTION GROUP SHIM       452    3
1 464 616 346    COMPRESSION SPRING    1464616346    453    1
1 463 219 304    CONTROL SPOOL    1463219304    455    1
1 467 032 017    ABSORBER    1467032017    460    1
2 912 702 197    CHEESE HEAD SCREW    2912702197    472    3
1 460 342 313    CLAMPING PIECE    1460342313    540    1
1 463 452 321    HEXAGON SCREW    1463452321    541    1
1 463 218 303    INTERMEDIATE PIECE    1463218303    542    1
1 465 134 927    ASSEMBLY OF SERVICE PARTS PUMP HOUSING    1465134927    800    1
1 467 010 054    PARTS SET FLYWEIGHT    1467010054    805    1
1 463 590 901    ASSEMBLY OF SERVICE PARTS GOVERNOR SHAFT    1463590901    813    1
1 467 010 555    PARTS SET THEFT PROTECTION    1467010555    825    1
0460414193    VE4/11F2000R790-2
REPLACING PARTS:
1 460 140 334    CROSS DISK    1460140334    27    1
1 461 902 253    CONTROL LEVER    1461902253    72    1
1 461 021 873    BRACKET    1461021873    235    1
I don't know if there are other pumps. There's another "R790". I can't say where it's from.
0460414178    VE4/11F2000R790
Reply #18August 05, 2019, 10:27:05 am
Dino
  • 44
« Reply #18 on: August 05, 2019, 10:27:05 am »
0 460 414 178
REPLACING PARTS:
1 467 134 992    MANIFOLD-PRESSURE COMP.    1467134992    67    1
0 330 001 042    PUSHING ELECTROMAGNET    0330001042    240    1
1 464 460 330    CABLE    1464460330    242    1
1 463 314 306    FLANGE NUT    1463314306    243    1
Another pump,the code is from an ad on line.
0460414207    VE4/11F2000R892
The last pump has got different parts, I hope the code is right. The third pump has the same camplate,part load governor,fulcrum lever, control valve as the other two pumps.
REPLACING PARTS:
1 460 232 376    ROLLER RING    1460232376    20    1
1 463 103 315    ADJUSTING PIN    1463103315    24    1
2 460 140 021    CROSS DISK    2460140021    27    1
1 463 104 700    TIMING-DEVICE PISTON    1463104700    31    1
1 460 100 902    SELECTION GROUP SHIM RING    1460100902    33    2
1 464 619 930    COMPRESSION SPRING    1464619930    34    1
1 464 619 924    COMPRESSION SPRING    1464619924    34    1
1 464 619 868    COMPRESSION SPRING    1464619868    34    1
1 460 100 902    SELECTION GROUP SHIM RING    1460100902    35    1
1 465 530 301    CLOSING COVER    1465530301    37    1
1 468 374 004    HYDRAULIC HEAD    1468374004    50    1
1 467 134 786    MANIFOLD-PRESSURE COMP.    1467134786    67    1
1 463 163 336    PART LOAD GOVERNOR    1463163336    68    1
1 460 422 465    SLIDING SLEEVE    1460422465    115    1
1 460 225 082    O-RING    1460225082    134    1
1 460 362 487    CONTROL VALVE    1460362487    135    1
1 467 230 448    CONTROL UNIT    1467230448    235    1
1 464 460 332    CABLE    1464460332    242    1
2 916 699 132    SPRING LOCK WASHER, DIN 128 - A6-FSt    2916699132    275    1
2 910 142 195    HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x14-8.8    2910142195    276    2
2 460 223 001    SEAL RING    2460223001    277    1
1 463 433 313    WASHER-AND-SCREW ASSEMBLY    1463433313    292    2
1 460 491 300    GUIDE SLEEVE    1460491300    294    1
1 460 410 310    SPRING SLEEVE    1460410310    295    1
2 912 742 154    CHEESE HEAD SCREW    2912742154    296    1
1 463 305 308    CLAMPING PIECE    1463305308    297    1
1 460 101 620    SHIM    1460101620    380    1
1 465 530 863    FITTING COVER    1465530863    381    1
1 461 901 681    CONTROL LEVER    1461901681    382    1
1 461 901 679    CONTROL LEVER    1461901679    382    1
1 461 329 306    STOP BRACKET    1461329306    383    1
1 464 651 422    COILED SPRING    1464651422    384    1
2 916 699 132    SPRING LOCK WASHER, DIN 128 - A6-FSt    2916699132    385    1
2 915 012 007    HEXAGON NUT, ISO 4032 - M6-8-A    2915012007    386    1
1 464 736 300    CLAMPING BAND    1464736300    400    1
1 461 332 442    BRACKET    1461332442    431    1
1 460 100 227    SHIM    1460100227    558    1
1 465 134 871    ASSEMBLY OF SERVICE PARTS PUMP HOUSING    1465134871    800    1
I looked for the camplate and I found the application list from an on line shop.
0460424313 ; 0460424251 ; 0460424242 ; 0460424241 ; 0460424233 ; 0460414247 ; 0460414246 ; 0460414242 ; 0460414239 ; 0460414219 ; 0460414218 ; 0460414216 ; 0460414215 ; 0460414211 ; 0460414210 ; 0460414207 ; 0460414193 ; 0460414191 ; 0460414178
I thought to add it because somebody can be interesting in it for extreme pump tuning.
« Last Edit: August 05, 2019, 01:36:45 pm by Dino »
Reply #19June 21, 2020, 12:27:47 am
Chuck1978
  • 77
« Reply #19 on: June 21, 2020, 12:27:47 am »
So I picked up one of these Kia TDI pumps from eBay Europe, 0 460 414 191.  I posted some cut&paste comments on the mTDI FAQ thread for this and others.
I haven't tried to fit this thing yet, as my Land Rover pump is currently on my ALH and timed etc, but it looks very similar in terms of mounting.
There are a few extra external parts on this pump in addition to the throttle position sensor that I'm trying to figure out.  Andrew L. took a quick look and made some quick guesses as the functions of these two parts in particular.
And here are the two assemblies that I'm not familiar with from the Land Rover pumps or the older VW IDI 1.6TD (or 1.9TD AAZ) pumps:
Flickr
Flickr
Flickr
As far as the unfamiliar additional parts, after consulting the pros on some quick speculation,
the shock  on the throttle linkage slows the return to idle when you let off the accelerator pedal rapidly,
the vacuum actuator and cable output (which is broken in my photo, poor packaging job on it's ride across the ocean) likely raises idle slightly most likely with A/C is running etc.
& perhaps the added solenoid at the dynamic advance retards timing under certain conditions for lower NOx emissions??????????
JFKO, Dino, or anyone else, do you have any comments on this speculated narrative?
Reply #20July 08, 2020, 12:18:44 am
  • 2744
« Reply #20 on: July 08, 2020, 12:18:44 am »
Some of those pictures are too big.
I think the cummins 4BT pump also has the tube running from the timing piston to the internal pressure regulator.
  The regulator compares pressure from inside the pump to pressure at the front of the pump.
  The timing piston also compares internal to input pressure.
I think it's some kind of cold start device but am not sure how it works.
Tornado red, '91 Golf 4 door,
S-PAutomotive.com
