General Information
General
The dyno run picture thread
Topic: The dyno run picture thread (Read 11164 times)
November 16, 2009, 09:38:33 am
November 16, 2009, 09:38:33 am »
I know there are a lot of different dyno sheets on the forum but they are scattered all over the place. If everyone that has one could post it here along with a brief description of what you have done to the engine that would be swell. TDI, TD, NA and anything else you might have
VW Diesel engines only please.
November 18, 2009, 12:22:37 am
carrizog60
Re: The dyno run picture thread
November 18, 2009, 12:22:37 am »
i will start
jk engine converted to turbo
kkk24 at 30psi,big front i.c.,upped fuel.
Portugal
November 18, 2009, 01:36:19 am
Alcaid
November 18, 2009, 01:36:19 am »
1V ECO diesel with nothing but the following changes:
- Passat 1.6TD intercooler mounter on top of gearbox (not a lot of airflow)
- Boost pressure adjusted to 1,1bar = 16 psi
- Fueling and idle adjusted
Results at the hubs (Dynapack):
- 91.7hp @ 4112rpm
- 182.1Nm = 246.9ft-lbs @ 2890rpm
Lots more to come
'10 VW Passat 1.6TDI Highline
'83 VW Jetta 1.6TD, 11mm pump, H-beam rods, girdle, fully reworked AAZ head +++ Going Compound
December 04, 2009, 07:45:52 am
December 04, 2009, 07:45:52 am »
91 Golf NA. Stock run plus a stock+Giles pump run
Last Edit: December 04, 2009, 07:48:44 am by burn_your_money
March 03, 2010, 07:28:47 am
joshh
Newbie
March 03, 2010, 07:28:47 am »
1984 Jetta Deluxe 1.6 IDI na
200K+ miles (estimated, odo had stopped for a couple years before I got it)
Stock pump (I think...), recently resealed by me
Stock intake and filter
Stock exhaust
Ran in 4th gear with 7A transmission
Shell ULSD w/ a few oz's of Stanadyne treatment
Difference in runs: first run (lowest), fuel screw set to almost no smoke at WOT, second turned in 1/8th, third another 8th and lots of smoke at WOT.
October 06, 2010, 10:42:45 pm
Powered by Spearco
October 06, 2010, 10:42:45 pm »
I don't have a dyno sheet for the full view of TQ and HP, but have the end result.
Running 30PSI of boost to 6K RPM.
This was the first run, stock boost at 10-11PSI.
Its cool what boost can do.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
October 07, 2010, 05:13:03 am
MJF
October 07, 2010, 05:13:03 am »
Nice hp
Whats your setup, torque seems low? A big turbo that starts to choke upper rpm at 30psi? Could you get dyno sheet, always intresting to compare
Here's my latest. Had to get a dyno sheet for MOT, so there is't everything. Later I found that timing was set at 0.60mm, maybe that had something to do with upper rpm range
I should go again, but 4wd dynos are not that common here.
1,9NA, KKK14-2 (MB om606) with AFN exhaust manifold, some porting in head, custom mech cam with rosten valvesprings and 10mm pump.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
October 07, 2010, 05:20:52 am
dts67
October 07, 2010, 05:20:52 am »
MJF- What boost do run the k14-2 at? What do you think its capable of on a 1.9 idi?
Staying ot heres my peugeot 1.9 xud9 idi print out, 11mm pump and k14-2 from om606, still on standard tmic!
October 07, 2010, 05:44:12 am
MJF
October 07, 2010, 05:44:12 am »
It was at 1,5 bar. IŽm expecting ~200hp (crank), but weŽll see.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
General Information
General
