Author Topic: What size is the crank pully bolt?  (Read 5529 times)
November 14, 2009, 02:28:03 am
Jay
  • 157
    Derv power !
    • TONA Valet & Detailing
« on: November 14, 2009, 02:28:03 am »
I've done a search (can't find the size of the bolt) and need to know ASAP so I can get the correct size while I'm out.
Reply #1November 14, 2009, 06:58:37 am
Re: What size is the crank pully bolt?
« Reply #1 on: November 14, 2009, 06:58:37 am »
It has a 19mm 12pt head and is found at your local dealer.
Reply #2November 14, 2009, 07:04:55 am
Jay
  • 157
    Derv power !
« Reply #2 on: November 14, 2009, 07:04:55 am »
Thanks! I bought one from the local(ish) Halfords (lucky my bro in law was here to drive me there), even though I ended up pushing her in gear to get the water out and it worked a treat. At first water was pouring out, then squirting out then just air was coming out and it sounded like a steam train  ;D chooka chooka chooka chooka chooo chooo   ;D
Reply #3November 14, 2009, 07:33:13 am
« Reply #3 on: November 14, 2009, 07:33:13 am »
It's a special torque-to-yield bolt specifically designed for the large amount of torque required to hold everything together...hopefully they sold you the right one.
Reply #4November 14, 2009, 07:48:18 am
Jay
  • 157
    Derv power !
« Reply #4 on: November 14, 2009, 07:48:18 am »
Oh, I just bought a standard 12pt 19mm one :( I just won't use it on the crank pullet bolt if you say it won't work properly.
Reply #5November 14, 2009, 09:05:56 am
GEE-BEE
  • 1604
« Reply #5 on: November 14, 2009, 09:05:56 am »
BRICKWERCKS.COM HAS THEM..
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #6November 14, 2009, 09:18:21 am
« Reply #6 on: November 14, 2009, 09:18:21 am »
If it comes loose for any reason the engine will grenade... so my personal approach is to get this specific part directly from an OEM VW supplier or VW themselves.
Reply #7November 14, 2009, 09:28:04 am
Jay
  • 157
    Derv power !
« Reply #7 on: November 14, 2009, 09:28:04 am »
Cool I'll have to invest in one of those one day and not touch the crank pulley bolt with a standard 12pt.
Reply #8November 14, 2009, 04:20:42 pm
ToddA1
  • 434
« Reply #8 on: November 14, 2009, 04:20:42 pm »
I planned on ordering one to upgrade my 6pt.
Part # or year application..  same as gasser?  I don't want them getting me another 6 pt.
-Todd
Reply #9November 14, 2009, 05:56:53 pm
« Reply #9 on: November 14, 2009, 05:56:53 pm »
I think the 6pt has been superceded to the 12pt. The guy at the counter should know... should is the key word though
Reply #10November 15, 2009, 08:35:09 am
« Reply #10 on: November 15, 2009, 08:35:09 am »
my 1.5 has a 6 pt 17mm bolt holding the crank sprocket on. my 1.6TD mf engine has a 6 pt 19mm bolt. none of my engines have the 12 pt bolt. are they all too old for it?
Reply #11November 15, 2009, 11:58:08 pm
« Reply #11 on: November 15, 2009, 11:58:08 pm »
Hey, maybe it's just me but I think there's 2 different conversations going on here?  One about someone asking what size SOCKET they should be getting, another talking about what bolt to use?
Reply #12November 16, 2009, 04:53:13 am
ToddA1
  • 434
« Reply #12 on: November 16, 2009, 04:53:13 am »
Kinda 2 conversations.  The earlier 6 pt. 17mm bolt has been superseded by a newer, stretch style 12 pt. 19mm bolt.  I found the answer to my question.
-Todd
Reply #13November 16, 2009, 12:32:07 pm
Jay
  • 157
    Derv power !
« Reply #13 on: November 16, 2009, 12:32:07 pm »
Ah yes, so there seems to be  ;D
My bad I do apologise for confusing the situation, I was in a rush to post this and go out and have a look at the engine. I was after the socket size, not the actual bolt  :-[
So it is safe to use a 12pt socket on the bolt to turn the engine over by hand after all?
Reply #14November 16, 2009, 01:29:39 pm
ToddA1
  • 434
« Reply #14 on: November 16, 2009, 01:29:39 pm »
That's common procedure.
-Todd
