Author Topic: So my starter has problems......solved!!!  (Read 8292 times)
November 09, 2009, 08:59:45 pm
« on: November 09, 2009, 08:59:45 pm »
Last winter my starter developed a issue were it would crank for a split second and then disengage, and then spin unloaded, after a few trys it would hold long enough to start.
Thinking the 'clutch' in the drive gear was bad I rebuilt it with a new drive gear, brushes and bushings.
Now if it's 40F or colder out it will spin but not engage for a couple trys, then it'll finally engage and crank just fine.
According to everything I've read and observed by taking my starter apart, the motor can't spin unless the solenoid clicks, there's a little button that the solenoid plunger pushes that gives power to the motor
BUT....when the solenoid clicks it also slams the drivegear out.
So it shouldn't be able to spin unless the gear is out and then it should spin the motor.
I greased the twisted splined shaft when I rebuilt it, after these latest problems I thought the grease was the cause so I took it all apart and cleaned the grease out but it didn't help a bit.
If anyone have any wild guesses then speak up!!haha I'm long out of ideas.....thanks
« Last Edit: December 08, 2009, 03:50:30 pm by rabbitman »
Reply #1November 09, 2009, 09:13:37 pm
maxfax
  • 2126
Re: So my starter has problems......
« Reply #1 on: November 09, 2009, 09:13:37 pm »
Lemme know when you figure it out..    I replaced the starter on mine last fall as it totally took a poop..  It was a USA industies reman (which I've had excellent results with to date).  WHen it got bitter cold I had the same issue..   Warmer days it was fine..   Exchanged it for another and the same thing happened...   Checked everything stem to stern and then called USA industries..   Although we never did get to the bottom of the issue they tried their darnest to help out.. Even sent them one of the starters to check out, and they couldn;t find a problem..  By this point the weather was warm and I figured I'd deal with it later..   The other morn at 22 def F it was fine, so maybe some wear helped out..    I am sort of suspecting maybe an issue with the grease being too stiff when cold..
Reply #2November 09, 2009, 09:19:39 pm
« Reply #2 on: November 09, 2009, 09:19:39 pm »
One thing I noticed is that the original bosch drivegear/oneway clutch assembly has part #'s on it, visible without disassembling the starter. The replacement I bought doesn't have the part #'s so I wonder if it's a chinese copy?? and just slips with the added load of a cold engine :-\
Reply #3November 09, 2009, 11:11:20 pm
maxfax
  • 2126
« Reply #3 on: November 09, 2009, 11:11:20 pm »
I should have looked closer at the teeth, but I could actually hear mine grinding on engaugement from time to time..   Maybe it was something internal in the clutch..  THe grinding sounded more like ring gear teeth, but who knows..  I think it is possible that the solenoid can move far enough to engauge the motor without the drive being completely engauged into the ring gear..  Been ages since I had one of these apart, but I believe there is a spring between the drive and the arm that moves it..
Reply #4November 09, 2009, 11:35:49 pm
« Reply #4 on: November 09, 2009, 11:35:49 pm »
Yeah there is a spring, my theory was that thick grease on the splines would hold the gear back while the spring compressed.
I tested my starter in the cold with it out and it acted normal. I might just take it to the shop that I bought the rebuild stuff from, they're the old school kind of guys that know what they're talking about.
Reply #5November 10, 2009, 12:57:17 am
burnt_servo
  • 278
« Reply #5 on: November 10, 2009, 12:57:17 am »
a few years ago i built a stroker 360  for my '77 powerwagon , to run on natral gas .  so the compression was really high , and due to the way the natural gas was fed into the motor , you had to crank the engine 2 or 3 times longer than if it was on gasoline  .
anyways , roughly every 18months of strict natural gas use i'd have to replace  either the starter , torque converter ( due to wear on the starter gear , or ring gear )  , or both , and when it was about to let go , it would to the exact same thing that rabbitman is going through .......
except that when the starter would disengage from the ring gear ,  gear teeth would get  sheared off of the ring gear and end up a chunks on the bottom of the bellhousing .
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
Reply #6November 10, 2009, 08:02:30 pm
  • 2926
« Reply #6 on: November 10, 2009, 08:02:30 pm »
I had one rebuilt last winter and it did the same thing.
 I'm starting to think there are a bunch of new drive gears that are weak.
 I wonder what brand they used.
Reply #7November 10, 2009, 08:21:07 pm
maxfax
  • 2126
« Reply #7 on: November 10, 2009, 08:21:07 pm »
Are the gears weak, or the lube too heavy???   Rabbitman's sounds like it acted the same as mine.    Fine in warmer temps, but cooler temps not so good..  If it would kick out while cranking I'd blame the gear, but it seems to be the initial engagement is the problem...
Reply #8November 11, 2009, 12:23:21 am
Zulfiqar
  • 254
« Reply #8 on: November 11, 2009, 12:23:21 am »
You need to cleanup the thick grease on the one way clutch splines and lubricate it with dry moly or plain graphite powder, mine did the same - even in rainy conditions, cleaned it up good dusted with graphite and moly - smooth n purrfect...
Diesel IS the future
Reply #9November 11, 2009, 11:23:45 am
« Reply #9 on: November 11, 2009, 11:23:45 am »
I had thick grease on there when I first rebuilt it but then this latest problem developed so I took it apart and cleaned the splines and left it dry, it didn't improve at all. :-[
Reply #10November 11, 2009, 04:27:03 pm
macka
  • 957
« Reply #10 on: November 11, 2009, 04:27:03 pm »
when you assembled the starter, did the bendix drive get damaged? Sometimes the shaft gets scarred and it interferes with the movement of the gear that is on the end of the starter.
Quote from: Vincent Walden
Reply #11November 11, 2009, 05:15:51 pm
« Reply #11 on: November 11, 2009, 05:15:51 pm »
I slides very smooth. :-\
Reply #12November 11, 2009, 08:20:48 pm
« Reply #12 on: November 11, 2009, 08:20:48 pm »
Well 'normally' the starter works fine once the engine (hence starter) is warm.
Well today after the engine was all the way up to temp and turned off for 15 minutes max the starter failed and took 2-3 trys before engaging >:(, did that twice today. I'm really hoping to have another starter in there before I have to get another flywheel also.
Reply #13November 11, 2009, 11:08:52 pm
Zulfiqar
  • 254
« Reply #13 on: November 11, 2009, 11:08:52 pm »
check to see that your starter solenoid plastic anchor is not cracked - it would also pay off to check the splines for rough edges or the stupid spring is plain weak.. on denso direct drive starters we need to shim the solenoid for the pinion to actually engage the flywheel and then juice is applied to the motor.. Cant say this for bosch ones..
You can try reworking the spring behind the clutch assy and also check your starter shaft bronze bushing in the tranny.if its jamming the shaft the clutch will not slide fully - the spring will compress and fire the solenoid,
Reply #14November 12, 2009, 11:27:55 pm
« Reply #14 on: November 12, 2009, 11:27:55 pm »
I put a new tranny bushing in when I rebuilt the starter last winter, not sure what plastic anchor your talking about......but since today didn't go my way I had the opportunity to inspect it a little more.
When I tried leaving work I turned the key to the "start" position and nothing happened >:(, no click, buzz, grind just silence. So I pulled the starter out and thinking the solenoid had died I took it off and hooked it up to 12v to see what would happen, IT WORKED PERFECT AAARRRRGG.
Keep in mind it was dark, 7:30 and 10F and I didn't feel like playing with bunny right then.......
I had a working gasser starter handy so I swapped the solenoids and compared and swapped 'em back over and over. Also compared the splines, I didn't take it apart enough to remove the gear I just slid 'em on the shaft, the gasser one (all original parts) slid slightly easier but the diesel one still slid plenty easy.
The only thing weird I noticed is when I ground the starter housing, hook 12v to the solenoid (key switched connection and high amp input) the starter gear snaps out and starts turning but it doesn't snap completely out at first. It stops it's outward travel about 1/8 inch from the stop ring and then as it spins it makes it the rest of the way out. :o
Does this mean that it's only meshing with the flywheel by a 1/8 inch???? When I try starting it, the starter just freewheels but if I just let it spin it'll eventually try meshing and just grind, I don't do this regular though, usually I hit the key, let up, hit it again and repeat 'til it engages.
I had installed the gasser starter a few weeks ago, it engaged fine but didn't have the power to crank fast enough, so something is different about it and I just can not figure it out.
