Author Topic: 1981 Rabbit P/U ...Build pictures  (Read 7761 times)
November 08, 2009, 09:35:36 am
1.9TD Caddy
« on: November 08, 2009, 09:35:36 am »
Here are pictures of my progress so far
<a href="http://s580.photobucket.com/albums/ss245/AYANKAH/?action=view&current=81pickbeforeres.jpg" target="_blank"><img src="http://i580.photobucket.com/albums/ss245/AYANKAH/81pickbeforeres.jpg" border="0" alt="Photobucket"></a>
« Last Edit: November 09, 2009, 09:29:08 am by 1.9TD Caddy »
Reply #1November 08, 2009, 06:24:02 pm
Re: 1981 Rabbit P/U ...Build pictures
« Reply #1 on: November 08, 2009, 06:24:02 pm »
Wow, colour me jealous!!  Looks awesome!
Reply #2November 09, 2009, 09:36:43 am
1.9TD Caddy
« Reply #2 on: November 09, 2009, 09:36:43 am »
Before and after....
http://i580.photobucket.com/albums/ss245/AYANKAH/81pickbeforeres.jpg?t=1257787893
http://i580.photobucket.com/albums/ss245/AYANKAH/81pickbeforeresjpg5.jpg?t=1257789324
http://i580.photobucket.com/albums/ss245/AYANKAH/81pickbeforeresjpg3.jpg?t=1257787928
http://i580.photobucket.com/albums/ss245/AYANKAH/81pickbeforeresjpg2.jpg?t=1257787962
http://i580.photobucket.com/albums/ss245/AYANKAH/80pickuprar17.jpg?t=1257788005
http://i580.photobucket.com/albums/ss245/AYANKAH/80pickuprar13.jpg?t=1257788165
Worn out 1.6 N/A
http://i580.photobucket.com/albums/ss245/AYANKAH/AAZBUILD043-1.jpg?t=1257788351
http://i580.photobucket.com/albums/ss245/AYANKAH/80pickuprar18.jpg?t=1257789371
Start of 1.9AAZ BUILD
http://i580.photobucket.com/albums/ss245/AYANKAH/AAZBUILD042.jpg?t=1257788407
http://i580.photobucket.com/albums/ss245/AYANKAH/AAZBUILD040.jpg?t=1257788439
http://i580.photobucket.com/albums/ss245/AYANKAH/AAZBUILD037.jpg?t=1257788475
http://i580.photobucket.com/albums/ss245/AYANKAH/AAZBUILD032.jpg?t=1257788512
http://i580.photobucket.com/albums/ss245/AYANKAH/AAZBUILD031.jpg?t=1257788538
Brand new head
http://i580.photobucket.com/albums/ss245/AYANKAH/AAZBUILD029.jpg?t=1257788566
Brand new pistons
http://i580.photobucket.com/albums/ss245/AYANKAH/AAZBUILD027.jpg?t=1257788622
Used tranny off a 1993 golf TD. Cleaned and painted.
http://i580.photobucket.com/albums/ss245/AYANKAH/AAZBUILD026.jpg?t=1257788677
Other bits
http://i580.photobucket.com/albums/ss245/AYANKAH/AAZBUILD024.jpg?t=1257788829
http://i580.photobucket.com/albums/ss245/AYANKAH/AAZBUILD023.jpg?t=1257788852
http://i580.photobucket.com/albums/ss245/AYANKAH/AAZBUILD022.jpg?t=1257788890
http://i580.photobucket.com/albums/ss245/AYANKAH/AAZBUILD020.jpg?t=1257788918
Modified crank nose TDI style
http://i580.photobucket.com/albums/ss245/AYANKAH/AAZBUILD017.jpg?t=1257788962
Bock bored and hoened
http://i580.photobucket.com/albums/ss245/AYANKAH/AAZBUILD016.jpg?t=1257789018
« Last Edit: November 09, 2009, 09:57:32 am by 1.9TD Caddy »
Reply #3November 09, 2009, 04:11:19 pm
GEE-BEE
  • 1604
« Reply #3 on: November 09, 2009, 04:11:19 pm »
What turbo are you going with ?
If it's a K03 , I would like to send you two fittings to replace the banjo on the block and a adapter on the turbo.. AN-8 FLARE ADAPTER TO 90 DEGREE AN -8 FLARE
Then advise me the distance between the flares so I can have a hose ready to go for this mod...
let me know , I would be happy to send you a gasket for the intake elbow for free
Iam will trying to see if a 1.87( I.D. ) to a 1.50 90 degree elbow will work ( silicone ) to replace the stock vw on the AAZ
let me Know
Gee-Bee
[email protected]
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #4November 09, 2009, 07:48:01 pm
1.9TD Caddy
« Reply #4 on: November 09, 2009, 07:48:01 pm »
Hi Gee- Bee, I shot you an email with pics of my oil lines.
Thanks!
« Last Edit: November 09, 2009, 07:51:21 pm by 1.9TD Caddy »
Reply #5November 10, 2009, 07:50:04 am
GEE-BEE
  • 1604
« Reply #5 on: November 10, 2009, 07:50:04 am »
THAT K14 Oil line looks fine, whats the condition of the turbo ?
If you need a manifold neck gasket let me know I will mail you one..
Gee-Bee
Giles Pump OHC
MK1 JETTA DASH
Reply #6November 10, 2009, 10:07:45 am
1.9TD Caddy
« Reply #6 on: November 10, 2009, 10:07:45 am »
OK, Thanks!
Reply #7November 10, 2009, 10:34:28 am
GEE-BEE
  • 1604
« Reply #7 on: November 10, 2009, 10:34:28 am »
GET A MCNALLY EGT/BOOST GUAGE , I bought all three for my GTI center console...
Techtonic's has the K14 DP for the MK/ AAZ 2.5 S/S , speak with Josh there, tell him I sent you
Help is here if you need it
Giles Pump OHC
MK1 JETTA DASH
Reply #8November 10, 2009, 12:56:17 pm
1.9TD Caddy
« Reply #8 on: November 10, 2009, 12:56:17 pm »
Excellent! once again thanks. I might need some help when it comes to drilling the hole for the EGT probe... Don't want to crack my manifold. I any tips will be appreciated.
Reply #9November 10, 2009, 02:21:10 pm
GEE-BEE
  • 1604
« Reply #9 on: November 10, 2009, 02:21:10 pm »
remove the stud on the exhaust manifold that holds the stock downpipe in place, Mcnally sells a drill and tap kit with there Gauges..
I did both my exhaust and Intake before coating( ceramic ) and powdercoating, I had the shop do the heat shield while they did the exhaust manifold..
Your real close to GPOPSHOP.com a turbo OHC shop that is building my K03/K04 hybrid turbo, they also do ceramic coated housings as well
Stay in touch,
Gee-Bee
[email protected]
Giles Pump OHC
MK1 JETTA DASH
Reply #10November 10, 2009, 11:17:13 pm
Baron VonZeppelin
« Reply #10 on: November 10, 2009, 11:17:13 pm »
About 9 out of 10 81-82's have that same interior color it seems like.
Great score on a solid Truck. Super cool and fuel efficient.
A lot of us have been getting lucky on finding good prospects this year.
Yellow has got to be a wild bright sight under the hood.
That would be a cool eye catcher.
Does yours have multi-leaf springs and/or spring assisted shocks on the rear ?
Reply #11November 10, 2009, 11:19:58 pm
Baron VonZeppelin
« Reply #11 on: November 10, 2009, 11:19:58 pm »
THANKS GB i'm going to look into that too !
Reply #12November 11, 2009, 04:32:33 am
stewardc
« Reply #12 on: November 11, 2009, 04:32:33 am »
As for the drilling, I put mine close to the turbo in the downpipe. It's where a lot of big trucks have theirs. It's about 100 mdegrees cooler, but saves ruining a cast manifold.
Reply #13November 11, 2009, 06:34:29 am
1.9TD Caddy
« Reply #13 on: November 11, 2009, 06:34:29 am »
Thanks for the compliments, It has the standard leaf springs, I will have to get new shocks all the way around! They are pretty worn out.
Reply #14November 11, 2009, 08:29:02 am
GEE-BEE
  • 1604
« Reply #14 on: November 11, 2009, 08:29:02 am »
Do Weitec coilovers front, axle flip rear with Monroe 1968 corvette air shocks, I keep a small 20cu tank of nitrogen behind my seat for tires or to adjust the height if I want......
I did complete new suspension / sterering box  with Addco sway bar kit's and Nuespeed strut bar , Finally found a like new diesel fuel intake tube/Nozzle
Weitec  Coilovers from Rabbitparts.com
15 x 6 Wheels / 195-45 /15 Kuhmo's
let me know ?
Ebay airshock's
Giles Pump OHC
MK1 JETTA DASH
