Newbie Help......
Topic: Newbie Help...... (Read 3329 times)
November 07, 2009, 08:11:19 am
Jimmy Oldskool
Newbie
Newbie Help......
November 07, 2009, 08:11:19 am »
Hi guys, been on here a while, but up till now just been reading topics and taking it all in (well, trying too anyway!
So today I decided to undertake the boost pin/star wheel mod and add a bit of boost to my GTD (SB) engined MK2 van.
I followed all of the instructions carefully to give me max fuelling, then adjusted my KKK K14 to give me just over 1bar of boost (about 15psi)
The problem I now have is that I get an awful 'surging' of boost....It feels like the turbo comes on boost with a loud whooshing noise, then a funny barking type sound, and then boost again.......almost like it's overboosting then venting the excess boost to atmosphere, then boosting again?
Does anyone have any idea what my problem is??? And if it's boost related, is there an overboost mod, or does the K14 simply not handle 1bar
Cheers in advance!
Jimmy
November 07, 2009, 08:48:08 am
Re: Newbie Help......
November 07, 2009, 08:48:08 am »
might just be the upper limits of that turbo. ive heard from alot of people that right around 18 psi is the safe limit for a K14. i push 22 out of my K24, and 28 out of my VNT 17.
November 07, 2009, 12:07:27 pm
LoneWolf
November 07, 2009, 12:07:27 pm »
I wanted a mk2 Golf van
November 21, 2009, 05:06:14 am
GTD.
November 21, 2009, 05:06:14 am »
Have a look on your inlet manifold
Need to block off the overboost return
Or fit an AAZ manifold lower half
I jubilee clipped a 1/2"-3/8" drive adapter in the hose but you wouldnt want that firing into the turbo inlet
[Oo=w=oO]Golf GTD
VW Diesel Mehr Kraft. Weniger Verbrauch, Aus Liebe zum Automobil
November 21, 2009, 10:13:16 am
smutts
ClackClackClackClackClack
November 21, 2009, 10:13:16 am »
I had something similar with a jammed wastegate in the turbo. If this happens about once a second, then that is the item number one dumping the boost. It does this at about 12 psi or even less, and it isn't very subtle about doing it.
November 22, 2009, 02:06:15 pm
November 22, 2009, 02:06:15 pm »
The 'overboost' valve is pretty easy to block off. If you crank the screw in the end of it down you can increase its popping pressure a bit, but it's just a PITA basically. VW removed 'em from later intake manifolds so that's one route...
I just cut off a chunk of a broom handle and stuffed it in the hose. Problem solved...
November 22, 2009, 05:00:29 pm
smokin_fun
November 22, 2009, 05:00:29 pm »
i used the metal base part off a broken light bulb... works great so far (40,000+kms). Used to think it was kinda funny before i blocked it off.....talk about SMOKE!!!!
November 23, 2009, 08:37:55 am
November 23, 2009, 08:37:55 am »
i drilled a hole in mine and put a bolt and rubber grommet inside it. and i made sure to use stuff big enough that the engine could not ingest the bolt no matter how hard it tried. and the nut is on the outside, so worst case scenario, it comes apart, i have no boost, and i instantly notice my bolt gone.
Newbie Help......
