Author Topic: 3 piece or 2 piece oil ring? which is better?  (Read 7821 times)
Reply #15November 12, 2009, 11:40:07 am
  • 3468
    • McScrubbins Body Wash
Re: Which of these two oil rings to use?
« Reply #15 on: November 12, 2009, 11:40:07 am »
well because it would have been autohaus Arizona that botched the order not the manufacturer of the rings. I suppose i could call autohaus AZ and see if they did in fact screw the order and if they say they are for a diesel i could then call Grant and ask them? but if one were better than the other why would they sell them at the same price?
The fact that total seal uses a three piece oil ring makes me want to find the opinion of you guys.
In my opinion total seal seems to be at the top of the pack for rings... and if they use a 3 piece system i was thinking there may be something superior to that design no?
Reply #16November 12, 2009, 11:43:54 am
  • 3468
Re: 3 piece or 2 piece oil ring? which is better?
« Reply #16 on: November 12, 2009, 11:43:54 am »
Do those other rings fit around your pistons?  It looks like you may have received a gasser set.  Here's what I was [incorrectly] sent:
They are sort of like that but that part of the ring is thinner, it fits in sideways not flat like that and there aren't coloured tabs on it. they just overlap and kind of lock together...
Reply #17November 12, 2009, 01:45:05 pm
maxfax
  • 2126
« Reply #17 on: November 12, 2009, 01:45:05 pm »
Ed, slightly off the topic..   Did you get the entire pistons from you know who, or just rings??   I bought a set of his pistons, which seem decent.. But now you've got me debating whether to use the rings that came with, or buy another set...
Reply #18November 12, 2009, 02:08:33 pm
  • 3468
« Reply #18 on: November 12, 2009, 02:08:33 pm »
I am using my OEM pistons i believe.
