Author Topic: Few glow plug issues...any ideas?  (Read 6741 times)
Reply #15November 13, 2009, 01:49:14 pm
kibs45
  • 46
Re: Few glow plug issues...any ideas?
« Reply #15 on: November 13, 2009, 01:49:14 pm »
Jan, if I keep the car much longer it will probably be completely rewired, in the fashion you described.  The problem also is this car shares the harness of a CIS car so there is way too much wire in and around.  There just isn't a need for all of it, especially considering the age of everything involved.
Reply #16November 13, 2009, 06:57:04 pm
macka
  • 957
« Reply #16 on: November 13, 2009, 06:57:04 pm »
you can always get a painless wiring import kit, and rewire the car.
Quote from: Vincent Walden
Reply #17November 13, 2009, 07:01:23 pm
truckinwagen
  • 1895
« Reply #17 on: November 13, 2009, 07:01:23 pm »
I am going to put a diesel in a CIS car very soon, and have every intention of re wiring the car completely from scratch.
there is just too much electrical clutter in these things.
83 Opel Kadett Diesel
Reply #18November 13, 2009, 08:22:51 pm
kibs45
  • 46
« Reply #18 on: November 13, 2009, 08:22:51 pm »
I havn't figured out if mine is worse because its an Audi or not.  I guess its possible.  I was just shocked at the rats nest that fell out from behind the fuse panel.  Very comparable to our 95 Jetta.  Way too much, and a bunch of it obviously dead ends.  Oh well its still better than my 1990 100q.  That was a mess.  I will let everyone know what happens tomorrow after its finished.
Reply #19November 14, 2009, 05:58:15 pm
kibs45
  • 46
« Reply #19 on: November 14, 2009, 05:58:15 pm »
Well time for a compression test.  All back together smoke and no start still.  Got the tester we'll see how it goes.
Reply #20November 15, 2009, 08:25:13 am
« Reply #20 on: November 15, 2009, 08:25:13 am »
... I have detectable voltage at the appropriate wire at the ignition switch, and again at the solenoid terminal.  This is why I decided to bypass it.  ... I am just trying to keep it workable.  ...By the way the pimped glow plug circuit is MUCH MUCH more robust.
Vince's pimping is a superb and ideal solution.  I do an econo version.... replace the relay with a 'high amp capacity starter push button' with short 10ga leads from the FAT relay terminals.  I have not had a problem as the high load power through the button is quite brief.  Cost ~ $3. Time ~ 10 minutes.  Can also add a relay version directly ahead of strip fuse.
BTW, I share your climate, and relays often seem to fill up with water   :o  VW has a great way about placing water leaks directly above the fuse box  ::)
My first diesel (78) the PO had rewired the entire fuse panel with Ford style solenoids out be battery.  It looked like and airplane job, and was dependable enough to fly  8)
when i bought my rabbit, it had so many relays that were full of water. i thought maybe it was just me, but i guess its not.
Reply #21November 15, 2009, 10:34:24 am
kibs45
  • 46
« Reply #21 on: November 15, 2009, 10:34:24 am »
Rechecked my glow plugs with an OHM meter and found that all four have 0.0 ohms resistance.  Could this be part of the problem?  Havn't done the compression check yet its wet and cold.
Reply #22November 15, 2009, 01:46:41 pm
Familydiesel
  • 154
« Reply #22 on: November 15, 2009, 01:46:41 pm »
Yes, no ohms, no current.  Did you check your ohms with one lead on the threads to the bus, and the other on the threads or casing of the glow plug (not on the tip of the glow plug)?  Since you have the quick glow system, and the relay malfunctioned, leaving the plugs on, they would all be fried.  So, it would be good to replace the glow plugs with the same kind of plugs.  Don't mix slow and fast plugs together.  Just remember which kind you have and hold down the button accordingly.  One quick way to make sure wheather your glow plugs are toast, is to take a wire and connect to the top threads (to glow bus), and connect this wire to the + terminal on your battery.  Ground the body to the negative terminal and see if the plug lights up.  If not, its toast.  If it lights, your plug is still good enough to at least heat some.
Greg
1980 Diesel td pickup, Love that Diesel!
Reply #23November 15, 2009, 02:48:00 pm
kibs45
  • 46
« Reply #23 on: November 15, 2009, 02:48:00 pm »
removed the injectors for the compression check and verified gps are functional.  Bad nes is (mind you engine cold) 1:200 2:200 3:125 4:200.  So next to no compression.  Very interesting that it happened so quickly like I said Friday as running great and monday no start.  Anyays I ill let you all kno hat shakes out,  It might be up for sale soon.
Reply #24November 15, 2009, 04:54:20 pm
Familydiesel
  • 154
« Reply #24 on: November 15, 2009, 04:54:20 pm »
You sound like you're on the right track.  I honestly thought that no ohms meant the plugs were no good, but goes to show I got a lot to learn. I just tested a good one, and it showed 1 ohm.  Oh well, in any case hope you figure it out.
Reply #25November 19, 2009, 03:13:16 pm
kibs45
  • 46
« Reply #25 on: November 19, 2009, 03:13:16 pm »
Car is up for sale.  Portland Oregon.  If you need parts I might be willing.  Or $400 OBO takes it all.
Reply #26November 20, 2009, 09:32:42 am
« Reply #26 on: November 20, 2009, 09:32:42 am »
you must be Joel?
how bout the rest of the car, whats it like? straight? beat to piss?
mileage?
lights and electrical work?
i have a TD 5000 parts car, wanted to find a 4000 quattro, but this might have to do.
the 4000 is quite a bit smaller than the 5000 isnt it?
another thing, is it even worth fixing? or is this more of a parts car?
« Last Edit: November 20, 2009, 09:41:28 am by Rabbit on Roids »
Reply #27November 21, 2009, 04:56:47 pm
kibs45
  • 46
« Reply #27 on: November 21, 2009, 04:56:47 pm »
Its been beat to hell definitely more of a parts car.  Looks like its going away tomorrow.  If it falls through I will let you know.  The 4000 is a lot smaller.  This is a non quattro.  Anyway it had lots of issues and it will go away so another 4000 diesel in better shape will stay running.  Thanks for all the help.
