Author Topic: Aux belt....tensioner?  (Read 4651 times)
November 04, 2009, 05:45:26 pm
Makebeleaf
  • 57
« on: November 04, 2009, 05:45:26 pm »
My belt is bouncing up and down...almost hitting the water pump.
Why is it doing this?....the automatic tensioner is on the belt holding it tight. The tensioner is bouncing a lttle bit. (I believe they are supposed to to this?)
Any ideas?
« Last Edit: November 04, 2009, 06:02:03 pm by Makebeleaf »
Reply #1November 04, 2009, 07:15:59 pm
veedubcanuck
  • 151
Re: Aux belt....tensioner?
« Reply #1 on: November 04, 2009, 07:15:59 pm »
You need to install an alternator clutch pulley and the difference will be night and day... I've done it to my 2 AAZ's  and no more issues. Saves the crank pulley and your tensioner from self destruction.
Reply #2November 05, 2009, 04:29:49 am
Makebeleaf
  • 57
« Reply #2 on: November 05, 2009, 04:29:49 am »
Do all the belts on all cars do this? Why is it happening? I don't get it?
Reply #3November 06, 2009, 08:07:17 am
Makebeleaf
  • 57
« Reply #3 on: November 06, 2009, 08:07:17 am »
Could it be the tensioner itself? or the bushings along the tensioner shaft?
Reply #4November 06, 2009, 01:21:38 pm
veedubcanuck
  • 151
« Reply #4 on: November 06, 2009, 01:21:38 pm »
It's just the nature of the beast. Diesels have alot of pulsations as they fire, combined with the long tensioner arm and location of the tensioner on a long stretch of belt make it prone to this. As I said, get a alternator clutch pulley and put it on and it will be like night and day. . The mass of the alternator turning is trying to spin the motor during the firing pulses and that's why it does it... It was a poor design.
Reply #5November 07, 2009, 09:45:19 am
Makebeleaf
  • 57
« Reply #5 on: November 07, 2009, 09:45:19 am »
You mean it will be like night and day for the belt bounce? Or will I notice somewhere else .."ight and day?"
Reply #6November 08, 2009, 09:10:33 am
macka
  • 957
« Reply #6 on: November 08, 2009, 09:10:33 am »
it should pretty much eliminate the bounces
Quote from: Vincent Walden
Reply #7May 19, 2010, 07:36:39 am
« Reply #7 on: May 19, 2010, 07:36:39 am »
Hi Jeremy... like I said I'm responding to your PM here so that the search function can do its job.
Posting a video was exactly the right approach here... yup, that's the classic "solid pulley bounce"... very noticeable at idle, particularly if your tensioner is old and/or has worn bushings.
It's caused by the momentum of the spinning alternator with its tiny pulley (so lots of leverage) fighting the normal pulsations of power delivery on a high-compression engine...especially at low RPMs.
You can imagine the pounding the crank sprocket key and crank keyway are taking as the belt loads and unloads.  Over time this leads to the key and keyway degrading enough that the crank nose deforms, the sprocket wobbles loose, and ultimately if unchecked the engine timing relaxes to a point that pistons meet valves. :o
VW did in fact fix this issue by installing the clutched version of the alternator pulley on very-late AAZs and later in 1997 the early TDI engines.  The clutch allows the alternator to free-wheel when it wants to overspin the crank sprocket... belt bounce gone.
Why didn't they fix it sooner??  My guess... it took 3-4 years (so from 1993 to 1996ish) before damaged cranks started to make their appearance.
In terms of what to do about it... lots of discussion here... your best bet is to let search be your friend:
1) click on the "home" icon at the top of the page... this ensures you're searching the entire board
2) in the "Search" window on the right hand screen enter "AAZ alternator pulley"
3) click on the "search" window to the right of the box
The first page of hits you'll get are very very relevant.... part numbers, installation thoughts, etc. Have a read and then post back if all of your questions aren't answered.
One other thought... one of the posts shows me drilling and tapping the alt shaft to install a back-up bolt against the alternator pulley as a safety.  Given the way the pulley installs and how VW installs all their pulleys I'd not bother doing that again... doesn't hurt, but not really required.
Reply #8May 21, 2010, 03:03:28 am
Makebeleaf
  • 57
« Reply #8 on: May 21, 2010, 03:03:28 am »
I am having a hard time finding the Clutched pulley for my car. Called a couple places and they can't seem to help.
Does anyone know where i can get one around Southern Ontario between Barrie and Toronto?
Also, if anyone has the spline tool to swap mine in I can come to your place to use it and pay you for it if possible?
Thanks!
