Author Topic: AAZ crank failure results  (Read 2019 times)
October 24, 2009, 03:05:37 pm
Henchman
  • 183
« on: October 24, 2009, 03:05:37 pm »
Pulling apart an AAZ yesterday and I found out why the previous owner said "it just stopped running".  Crank bolt had come loose.  Pulled the head and expected to see the usual, instead I met the luckyest pistons in the world.  The valve imprints don't even go as deep as the dishing.
This is normally what I see when there is a crank problem (the bolt sheared on this engine), minus the rust!
The head is in great shape from the first picture, better than I usally see.  Too bad about the crank bolt!
Ian
Reply #1October 25, 2009, 03:38:16 pm
Black Smokin' Diesel
  • 656
Re: AAZ crank failure results
« Reply #1 on: October 25, 2009, 03:38:16 pm »
This is a lucky piston
(Edited for language by mod... guys this is a family forum.)
« Last Edit: October 25, 2009, 05:19:56 pm by Vincent Waldon »
