Author Topic: Question  (Read 4766 times)
October 24, 2009, 04:04:23 am
nickzom
  • 23
Question
« on: October 24, 2009, 04:04:23 am »
hi all, this engine is for sale locally http://pittsburgh.craigslist.org/pts/1433965668.html
i wanted to know what it would take to go TD with it. i have a exhaust manifold, turbo, intercooler, and oil cooler. what else do i need other than injectors and pump?
Reply #1October 24, 2009, 07:39:55 am
Re: Question
« Reply #1 on: October 24, 2009, 07:39:55 am »
an intake, oil lines.
oil cooler isnt even that important.
Reply #2October 24, 2009, 09:03:49 am
nickzom
  • 23
Re: Question
« Reply #2 on: October 24, 2009, 09:03:49 am »
i have a intake off of a gas motor, too. still have the lines for the turbo
Reply #3October 24, 2009, 09:21:38 am
Re: Question
« Reply #3 on: October 24, 2009, 09:21:38 am »
then what are you waiting for? get that stuff put on there and running with the n/a pump and injectors. i had a n/a pump and injectors on my rabbit for a long time before i actually swapped in my rebuilt TD pump.
Reply #4October 24, 2009, 09:33:02 am
nickzom
  • 23
Re: Question
« Reply #4 on: October 24, 2009, 09:33:02 am »
well, i dont have the engine yet, and my Jetta is still gas, so......
the turbo and manifold i have is a K26 from a Audi 5000, is that too big?
Reply #5October 24, 2009, 03:02:32 pm
nickzom
  • 23
Re: Question
« Reply #5 on: October 24, 2009, 03:02:32 pm »
Reply #6October 27, 2009, 08:44:51 am
nickzom
  • 23
Re: Question
« Reply #6 on: October 27, 2009, 08:44:51 am »
last question for now, do i really need a Diesel sending unit?
Reply #7October 27, 2009, 09:01:10 am
Re: Question
« Reply #7 on: October 27, 2009, 09:01:10 am »
for the fuel tank? i would highly doubt it. you will need to take the restrictor out of the fill neck tho.
and yea, the 2056 is a good unit. theres a few people on here running them i think.
Reply #8October 27, 2009, 10:19:37 am
nickzom
  • 23
Re: Question
« Reply #8 on: October 27, 2009, 10:19:37 am »
if i use the gas sending unit, do i need another fuel pump in conjunction with it, or will the in-tank pump do the job?
Reply #9October 27, 2009, 03:37:14 pm
Re: Question
« Reply #9 on: October 27, 2009, 03:37:14 pm »
These diesel's don't even have an in tank fuel pump, the lift pump is built into the injector pump.
Reply #10October 27, 2009, 03:43:50 pm
rallydiesel
  • 1880
Re: Question
« Reply #10 on: October 27, 2009, 03:43:50 pm »
You could run the k26 but it will spool very late. If you're got a gasser trans then you will pretty much redline by the time the k26 starts spooling. I don't know much about the 2056 but it's got a t25 flange so you will need to fab a custom one or get a t3 manifold and an ebay t3/t25 adapter. I'm not sure, but I can't see the Audi manifold fitting the VW head.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #11October 27, 2009, 03:48:11 pm
nickzom
  • 23
Re: Question
« Reply #11 on: October 27, 2009, 03:48:11 pm »
here is a Audi manifold with a runner cut off, bolts right up http://media.photobucket.com/image/audi%205000%20exhaust%20manifold/pholness927/DSCF2477.jpg
as for a trans it is a diesel trans.
Reply #12October 27, 2009, 03:49:04 pm
nickzom
  • 23
Re: Question
« Reply #12 on: October 27, 2009, 03:49:04 pm »
gas sending unit has a pump though. i am doing a gas to diesel conversion.
Reply #13October 27, 2009, 03:53:59 pm
Re: Question
« Reply #13 on: October 27, 2009, 03:53:59 pm »
You don't need a intank pump, maybe just disable it.
Reply #14October 27, 2009, 03:55:35 pm
nickzom
  • 23
Re: Question
« Reply #14 on: October 27, 2009, 03:55:35 pm »
so i can disable the intank pump, and the engine will still run?
