Author Topic: More power from 1.9TD (AAZ) - question  (Read 7277 times)
October 23, 2009, 01:08:29 pm
Les
  • 13
« on: October 23, 2009, 01:08:29 pm »
I want to get more power from my 1.9 TD (AAZ, K14 turbo) so this is what I am planning:
1. EGT
2. Intercooler
3. VNT turbo ? (maybe)
4. IP mods (replacing the AAZ “joke” pin with 1.6 TD boost pin, governor mod, LDA and max fuel adjustments)
1.9TD pump does not have the large screw on the top of the LDA nor the starwheel so no adjustments can be made here.
Is it better to replace the 1.9 pump with 1.6 pump and have all LDA adjustments available? I can get a used 1.6 pump from a wrecker for $300 and rebuild it myself. Or keep the 1.9 pump and just replace the boost pin?
98 Suzuki Sidekick converted to diesel (94 VW Golf 1.9 TD AAZ Engine), 5" lift, 31" tires, Petroworks Hi Perf. Clutch
Reply #1October 23, 2009, 02:19:25 pm
GEE-BEE
  • 1604
Re: More power from 1.9TD (AAZ) - question
« Reply #1 on: October 23, 2009, 02:19:25 pm »
I WOULD GET A PUMP , SEND TO GILES FOR OHC
 2'5 DOWNPIPE ?
EGT GAUGE / BOOST :  McNally
Gee-Bee
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2October 24, 2009, 07:43:49 am
« Reply #2 on: October 24, 2009, 07:43:49 am »
VNT turbo would be a great addition.
Reply #3November 05, 2009, 05:48:02 am
D1ES3L
  • 62
« Reply #3 on: November 05, 2009, 05:48:02 am »
so does that work?  1.6 pump on 1.9,  or even vice versa?
just swap out the unions, lines, injectors?
81 scirocco--80 TD caddy--99.5 TDI golf
Reply #4November 10, 2009, 09:09:46 am
Andy@React
« Reply #4 on: November 10, 2009, 09:09:46 am »
i have a (1.6) GTD pump on my AAZ, you need the pump, complete with pulley and the bolts to hold it on and thats it...
Reply #5November 12, 2009, 04:39:34 am
stewardc
« Reply #5 on: November 12, 2009, 04:39:34 am »
On my AAZ, I sent the pump to Giles...best money I ever spent. The VNT is nice, but a pain to build a controller for, so I just installed a Garrett T3 from the 1.6. I have a 2.5" PP downpipe and custom exhaust with a Magnaflow muffler.
Add an intercooler, and a manual boost controller. Get an EGT gauge (I got AutoMeter because it matches the rest of my gauges). The important thing is the EGT probe, not the gauge. Aircraft Spruce sell the best one. It responds faster than most.
Reply #6November 12, 2009, 04:50:22 am
« Reply #6 on: November 12, 2009, 04:50:22 am »
If you are sticking with 20psi max the K14 will be just fine.
