Author Topic: hot tank after honing?  (Read 4430 times)
Reply #15October 24, 2009, 03:11:19 pm
Henchman
  • 183
Re: hot tank after honing?
« Reply #15 on: October 24, 2009, 03:11:19 pm »
I cleaned the intake off my old SHO (big arrangement for those who don't know) but we lived in an apartment at the time and I did not have access to a pressure washer, altho it just occured to me know, 10 years later that I could have taken the intake to the self car wash.
Next time,
Ian
Reply #16October 25, 2009, 08:30:47 am
sdwarf36
  • 159
« Reply #16 on: October 25, 2009, 08:30:47 am »
I've worked for 20++ years as an automotive machinist-currently building mainly hi dollar vintage race motors. what I do is use acatone or paint thinner and clean paper towels. I wet the towel-wipe in a circular (following crosshatch) pattern. do this a couple of times untill you can take a fresh towel and see nothing  on it. I have used the hot water + dishsoap  method (works fine-just make sure you wipe it down with wd 40 after) or just used wd 40 + keep wiping till a clean one show no residue( might take 3 or 4 times).
91 Jetta on WVO na / td swap in progress.
 "VW happiness is having 4 working door handles."
Reply #17October 25, 2009, 09:10:36 pm
monomer
  • 414
« Reply #17 on: October 25, 2009, 09:10:36 pm »
What kind of tide? Liquid, powder?
Powder, you mix it into a paste and brush it in. I completely forgot about this old school trick. It cleans hands awesomely after a day in the shop. There is one catch though, you know where all your cuts and scratches are.
Yup.
I knew the machineshop I dropped the block at to get machined was ok - I saw a box of tide sitting on the windowsill when I walked in.
www.michiganvw.org
Reply #18October 27, 2009, 08:28:35 am
« Reply #18 on: October 27, 2009, 08:28:35 am »
Water plus TIDE laundry detergent
TIDE is high in phosphates and clean nicely. It's a nice little trick I learned from my shop's tolken mopar guy.
use that in your radiator too when you blow a head gasket. the granules kinda scour the radiator and clean it spotless too!
