Author Topic: hot tank after honing?  (Read 4431 times)
October 22, 2009, 02:49:58 pm
truckinwagen
  • 1895
« on: October 22, 2009, 02:49:58 pm »
I am about to hone the block for a re-ring, and am wondering if I will need to have the block hot tanked.
I know that it is a good idea after machining to hot tank a block to get rid of any shavings, but does honing really count?
I am tempted to get it tanked just to get rid of the grime on the outside of the block, but it costs $80 so if it is not necessary I don't really want to.
does honing require a hot tank wash?
-Owen
83 Opel Kadett Diesel
Reply #1October 22, 2009, 04:07:54 pm
gldgti
  • 488
    • http://scramjetsite.8m.com
Re: hot tank after honing?
« Reply #1 on: October 22, 2009, 04:07:54 pm »
traditionally no. a good clean with rags and kerosene is considered OK.
if i had hte option, i'd probably do it if it wasnt a hassle - then you can paint the block and make it all nice :-)
'91 Golf Cabrio 1.9TD
Reply #2October 22, 2009, 05:19:39 pm
Syncroincity
  • 727
« Reply #2 on: October 22, 2009, 05:19:39 pm »
I just did mine  a few months ago, the majority of the stuff simply sticks to the honing stones, just keep everything well wetted. I used a wire wheel with blue shop towels around it to clean up the bores afterwards.
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #3October 22, 2009, 05:46:40 pm
truckinwagen
  • 1895
« Reply #3 on: October 22, 2009, 05:46:40 pm »
good to hear, I probably wont to a hot tank then as I want to keep costs down, and that makes $80 I can spend somewhere else.
Reply #4October 22, 2009, 06:16:04 pm
« Reply #4 on: October 22, 2009, 06:16:04 pm »
Yeah, hot soapy water and a rag is fine, just be sure to oil it right after.
Reply #5October 23, 2009, 07:16:50 am
macka
  • 957
« Reply #5 on: October 23, 2009, 07:16:50 am »
I had the bottom end off, so I cleaned the outside of the block first with foamy engine brite and wire brushes, then honed it. After I honed it, I flipped the block over and used a few cans of brake cleaner and a dollar store dish brush and rags to clean up the bore. I used an old white T shirt to check and see if the bores were clean, as well as the mating surfaces. I think I was out a total of 25 bucks for a nice shiny block.
Quote from: Vincent Walden
Reply #6October 23, 2009, 08:23:51 am
« Reply #6 on: October 23, 2009, 08:23:51 am »
at most...
i used my bath tub once. filled it completely up with as hot of water as i could. then let the block sit in the water and get real good and hot. then cleaned it real good and took it out. dried in a matter of minutes.
Reply #7October 23, 2009, 09:09:01 am
blackdogvan
  • 574
« Reply #7 on: October 23, 2009, 09:09:01 am »
Tell me you were single when you did that! If my lady came home & a nasty old diesel block was in her tub... i think thermonuclear would be a proper description!!
As for the block, go buy a 6 pack & go find someone who likes beer & has a hotsy steam pressure washer, that'll clean it out real nice! I can't imagine they are rare up there.
1991 Vanagon 1.9 mTDI
Reply #8October 23, 2009, 09:44:40 am
Jay
  • 157
    Derv power !
    • TONA Valet & Detailing
« Reply #8 on: October 23, 2009, 09:44:40 am »
+1  :o  It is a good idea though  ;D  Just means I'd be sleeping outside under the apple tree for a few months.
Reply #9October 23, 2009, 06:38:05 pm
macka
  • 957
« Reply #9 on: October 23, 2009, 06:38:05 pm »
LMAO my wife would pull my arms off and beat me with the moist ends
Reply #10October 23, 2009, 09:14:13 pm
maxfax
  • 2126
« Reply #10 on: October 23, 2009, 09:14:13 pm »
I prefer the dishwasher with some of that Purple Power degreaser stuff..  Works well, and no spots!  ;D
Reply #11October 24, 2009, 07:36:21 am
« Reply #11 on: October 24, 2009, 07:36:21 am »
see, you guys all have wives to deal with. or girlfriends. they are a pain in the ass. females annoy the crap out of me.  >:(
Reply #12October 24, 2009, 02:26:04 pm
monomer
  • 414
« Reply #12 on: October 24, 2009, 02:26:04 pm »
Water plus TIDE laundry detergent
TIDE is high in phosphates and clean nicely. It's a nice little trick I learned from my shop's tolken mopar guy.
www.michiganvw.org
Reply #13October 24, 2009, 02:58:15 pm
« Reply #13 on: October 24, 2009, 02:58:15 pm »
What kind of tide? Liquid, powder?
Reply #14October 24, 2009, 03:00:48 pm
macka
  • 957
« Reply #14 on: October 24, 2009, 03:00:48 pm »
Powder, you mix it into a paste and brush it in. I completely forgot about this old school trick. It cleans hands awesomely after a day in the shop. There is one catch though, you know where all your cuts and scratches are.
