Author Topic: A question about Piston Rings  (Read 13152 times)
Reply #30October 26, 2009, 06:02:39 pm
Op-Ivy
  • 513
Re: A question about Piston Rings
« Reply #30 on: October 26, 2009, 06:02:39 pm »
that's 60$/set from a vw specialty shop called AVR. there is 1 in abbotsford and 1 in kamloops in British Columbia.
It's here in Kelowna, not Kamloops. They used to be Bowwow before and they used to have a store in Victoria as well.
Reply #31October 26, 2009, 06:54:10 pm
  • 3468
    • McScrubbins Body Wash
« Reply #31 on: October 26, 2009, 06:54:10 pm »
OHHHHHHHHHH
WELLLL THEN!
Thank you for the correction! I was too lazy to double check.
Do you use em? I find some of their stuff is nice and others are just way too marked up.
Reply #32October 26, 2009, 07:34:46 pm
cyrus #1
  • 360
« Reply #32 on: October 26, 2009, 07:34:46 pm »
I try to buy my parts from AVR whenever I can.  The guys that run the Kelowna one are super nice and pretty knowledgeable too.  I find their prices to be on par or lower than lordco's in most cases, except that AVR usually has nice German made parts.  I've had a couple of suspect experiences with parts from NAPA and Lordco.  Ball joints that lasted less than a year, etc.  There's not a ton of local options around these parts though.
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #33October 26, 2009, 10:05:21 pm
  • 3468
« Reply #33 on: October 26, 2009, 10:05:21 pm »
Yeah AVR is definitely dependable.
Reply #34October 27, 2009, 08:41:34 am
Op-Ivy
  • 513
« Reply #34 on: October 27, 2009, 08:41:34 am »
Yeap. Couldn't say it better myself. They really are great guys there. Always helping out! And in comparison with other stores, they are much cheaper while stocking good German parts.
Reply #35November 09, 2009, 10:43:36 am
« Reply #35 on: November 09, 2009, 10:43:36 am »
Zuk, did you send them rings to be custom machined, or did you buy from them outright? if you bought from them, what P/N did you use for the proper rings? i know andy2 and a few others found some for a 1.9, but to date i have been unable to find any for a 1.6
Diesel Specific Rings from Total Seal for the 1.6.
The part number for 1mm over pistons is 7844-40 (TSR-S7844-40)
.50mm over would be 7844-20 (TSR-S7844-20)
Standard would be 7844-00 (TSR-S7844-00)
Summit Racing # is the one in the ( ).
They were $191.69 before shipping.
thats good to know, thanks! i guess i don't feel so bad for spending around $250 cdn on my goetz total seals now  ;D
