Author Topic: engine idle RPM  (Read 3309 times)
October 17, 2009, 07:59:01 pm
92EcoDiesel Jetta
engine idle RPM
« on: October 17, 2009, 07:59:01 pm »
I think spec is 950 RPM? I have a tach in the cluster which is accurate enough (calibrated with a 3450 RPM AC motor). At 1000 RPM, the idle is not smooth at all and just does not sound right. If I set it to 1100-1200 RPM, it is much smoother and sounds much better. Do you see any issues with a higher idle? What idle RPM is your engine set to?
Reply #1October 17, 2009, 08:01:33 pm
truckinwagen
  • 1895
Re: engine idle RPM
« Reply #1 on: October 17, 2009, 08:01:33 pm »
the higher idle will use more fuel and make the car run hotter when sitting at a light.
not huge issues, but lowering the idle is still a good idea.
start by checking your motor mounts, if they are bad they can cause vibration at idle.
83 Opel Kadett Diesel
Reply #2October 17, 2009, 08:39:16 pm
92EcoDiesel Jetta
Re: engine idle RPM
« Reply #2 on: October 17, 2009, 08:39:16 pm »
More fuel at idle yes. But hotter at a light? There's no load at idle so a hot idle should be no issue?
Reply #3October 17, 2009, 08:45:03 pm
truckinwagen
  • 1895
Re: engine idle RPM
« Reply #3 on: October 17, 2009, 08:45:03 pm »
more fuel means more heat.
at a light you have no air passing through the radiator(until the fan turns on)
I had my idle jacked up quite a bit to mitigate really bad motor mounts and found that the temp would rise to the point of needing the fan much more quickly than it did with the lower idle.
not a big deal like I said, but it is there
Reply #4October 17, 2009, 11:08:19 pm
neimis
  • 75
Re: engine idle RPM
« Reply #4 on: October 17, 2009, 11:08:19 pm »
Just changed my rear (passenger) side motor mount 1 hour ago. It was the original mount ('92 Passat TD). My God, what a difference. The car is like new! Vibrations gone, shifting smooth, idle is nice. Car even seems to have more power! (I know it's just my imagination). I had previously changed the front mount, didn't make any difference. Now I will complete the set by changing out the transmission mount too.
If you don't know how old your mounts are, it's certainly worth a try.
'92 Passat TD
'01 Golf TDI
'15 Golf TDI
Reply #5October 18, 2009, 07:10:51 am
Re: engine idle RPM
« Reply #5 on: October 18, 2009, 07:10:51 am »
My car idles at 1000. Anything lower and it feels and sounds like it's going to rattle to death. I think that I have an injector issue, but that will be addressed later.
Reply #6October 18, 2009, 01:38:50 pm
Jettage1
  • 202
    Past VWs: 80 Scirocco S, 90 GTI, 00 Passat GLX
Re: engine idle RPM
« Reply #6 on: October 18, 2009, 01:38:50 pm »
Shame on you Tyler...
snort / guffaw!  ;D
Steve
92 Jetta EcoDiesel
     pumped by Giles...powered by Frybrid...functional by dumb luck
Reply #7October 18, 2009, 02:16:02 pm
Re: engine idle RPM
« Reply #7 on: October 18, 2009, 02:16:02 pm »
The cobbler's kids always have the worst shoes...
Reply #8October 18, 2009, 03:47:45 pm
Re: engine idle RPM
« Reply #8 on: October 18, 2009, 03:47:45 pm »
 :-[ I don't even know what to say...
Another potential cause of a rough idle could be uneven compression. You should check compression with the engine cold and with the engine at temperature.
Reply #9October 18, 2009, 03:57:36 pm
veedubcanuck
  • 151
Re: engine idle RPM
« Reply #9 on: October 18, 2009, 03:57:36 pm »
 Question here.... What temp does the engine need to be when checking the compression "hot"? By the time you pull the injectors and lines out the engine is cooled off considerably...
