Author Topic: Injector pump leak  (Read 2186 times)
October 15, 2009, 12:48:18 am
stupidsongs2
  • 3
Injector pump leak
« on: October 15, 2009, 12:48:18 am »
I have a leak that appears to be coming from the large triangular nut in between the injector heads (the circled bits in the photos) and I have a few questions.
1: Where can you buy an adapter to fit over the bizarrely shaped nut?
2: Can the seal behind the nut be safely changed while the pump is still on the car?
Damn you ultra-low sulfur diesel!
Reply #1October 15, 2009, 01:11:22 am
maxfax
  • 2126
Re: Injector pump leak
« Reply #1 on: October 15, 2009, 01:11:22 am »
YOu can get the seal from a bosch dealer..   AS far as the tool I favved one for scratch...   Probably a certain size 12pt socket that could be ground out to work as well..    Chances are good you're probably going to be doing the rest of the seals before long..
Reply #2October 15, 2009, 11:28:27 am
stupidsongs2
  • 3
« Reply #2 on: October 15, 2009, 11:28:27 am »
I used a 12 pt 24mm socket and ground 6 of the points out.  It has worked great many times.  That seal is incredibly easy to change on the vehicle.  I'd torque the strange nut back on to 60+ ft. lbs.
Excellent! That's just what I was hoping to hear, thanks a ton!
