Author Topic: Adding oil capacity  (Read 6159 times)
October 14, 2009, 12:23:03 pm
blackdogvan
  • 574
Adding oil capacity
« on: October 14, 2009, 12:23:03 pm »
I'm in the final strokes of my vanagon 50* m-tdi build & am thinking of the pros & cons of adding a quart or two of oil capacity. Oil temp on the van installs can be an issue, i have a PD150 oil cooler for it & while the DI's do run cooler oil than the IDI's its still on my mind. Eurospec sells oil pan spacers for 15* engines (+ 2 quarts) & that would get me a bit more at 50* but the pickup would need to be modified...
http://www.eurospecsport.com/products/components/oiling-systems.htm
Anyway I'm just wondering if anyone has thoughts on a few more liters of lube...
1991 Vanagon 1.9 mTDI
Reply #1October 14, 2009, 06:44:20 pm
Re: Adding oil capacity
« Reply #1 on: October 14, 2009, 06:44:20 pm »
My personal opinion... and it's just that... is that you won't run any cooler with more oil.  It will just take longer to get up to temperature... ie more volume to heat up... but once you're there you're there.
If you're solving for cooler oil my thought would be to add cooling capacity... bigger oil/water, extra oil/air, etc.
Reply #2October 14, 2009, 06:56:39 pm
« Reply #2 on: October 14, 2009, 06:56:39 pm »
I would think it wouldn't be a bad thing. 2 more quarts of oil to trap soot at least. I would think that the oil would be slower to change temp either way since there is more mass there. It always seemed to run a little cooler in my SBC when I put the big filter on it, I think it was a 2 quart instead of a 1. If you welded cooling fins on the oil pan I bet it would run even cooler :D
Reply #3October 14, 2009, 07:08:28 pm
macka
  • 957
« Reply #3 on: October 14, 2009, 07:08:28 pm »
I was thinking of relocating the oil filter, it would allow for more oil capacity and easier access to change the oil filter.
Quote from: Vincent Walden
Reply #4October 14, 2009, 09:18:07 pm
blackdogvan
  • 574
« Reply #4 on: October 14, 2009, 09:18:07 pm »
hmm good point...
Reply #5October 14, 2009, 10:09:09 pm
« Reply #5 on: October 14, 2009, 10:09:09 pm »
Stop burning donuts in the Walmart parking lot Andrew... problem solved. ;)
Reply #6October 14, 2009, 10:37:02 pm
Syncroincity
  • 727
« Reply #6 on: October 14, 2009, 10:37:02 pm »
Front-mount oil cooler! :D
Hoses / tubing alone forward and back should net you 2 extra quarts...
http://www.vwdiesel.net/forum/index.php?topic=19739.msg168514#new
« Last Edit: October 14, 2009, 10:39:40 pm by Syncroincity »
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #7October 16, 2009, 10:08:23 am
« Reply #7 on: October 16, 2009, 10:08:23 am »
i have the FS-2500 bypass oil filter :) the metal housing does help cool the oil so for the winter i'm going to make a little 'sock' for it.  ;D
best of both worlds though... extra quart or so of oil, mild oil cooling, and most of all excellent soot removal :)
i would definitely like to have their filter housing made out of aluminum though. it weighs about 10 lbs!!! (super rugged.. made for a big rig)
