Author Topic: Different injectors on the same head (AAZ)  (Read 2088 times)
October 07, 2009, 07:56:04 am
jbturgeon
  • 71
« on: October 07, 2009, 07:56:04 am »
Hi guys, i just bought a golf 95 1,9td and the first injector is not the same as the 3 others. It looks smaller and shorter. Apparently, the other owner had a broken injector and replaced it with an injector from an other diesel car. I was wondering what kind of injector could fit into an AAZ head and can it have something to see with the knocking sound from the side of the engine where the injector is?
If anybody knows what i am talking about, then i would like to know the size of socket to use to unscrew it. It looks to be 22mm or 20mm.
Thx very much
AAZ for life!
Subaru Loyale 4x4
Reply #1October 07, 2009, 09:39:48 am
veedubcanuck
  • 151
Re: Different injectors on the same head (AAZ)
« Reply #1 on: October 07, 2009, 09:39:48 am »
Sounds like they put an injector from the 1.6 in it....
Reply #2October 07, 2009, 12:51:09 pm
jbturgeon
  • 71
« Reply #2 on: October 07, 2009, 12:51:09 pm »
Does it matter? should i just leave it or put four same injectors? Is it the same pressure? What does it do on the fuel economy (good, bad or same?
Thx
AAZ for life!
Subaru Loyale 4x4
Reply #3October 07, 2009, 02:06:30 pm
« Reply #3 on: October 07, 2009, 02:06:30 pm »
You should change it. It is completely different. The AAZ injectors have 2 opening pressures, the first being 150 BAR the second is over 200. The 1.6 injector only has one opening pressure, 155 BAR for turbo, and 130 BAR for NA. Mercedes injectors will even screw in (I think).
It could definetely be causing the knocking.
Oh yeah, 27mm extra deep socket
Reply #4October 07, 2009, 07:01:57 pm
jbturgeon
  • 71
« Reply #4 on: October 07, 2009, 07:01:57 pm »
Thanks Tyler, the car drove ok but that knocking soundsss! I am going to change it tomorrow with four others injectors from an AAZ.
AAZ for life!
Subaru Loyale 4x4
