Author Topic: Angle torque??  (Read 2691 times)
October 05, 2009, 07:34:02 am
1.9TD Caddy
Angle torque??
« on: October 05, 2009, 07:34:02 am »
Hi guys, time for my silly question. Can anyone explain what angle torque means?
Thanks
Reply #1October 06, 2009, 08:05:12 am
CdnVWJunkie
  • 309
Re: Angle torque??
« Reply #1 on: October 06, 2009, 08:05:12 am »
Angle torque is performed after a preliminary torquing has been completed.  Generally the fasteners are a stretch type and a one time use only.  The method I use, I'm sure there are others, mark each fastener with a paint pen and then with my big breaker bar I make note of my starting point and crank say 90 degrees.  360 degrees is one full rotation so 90 would be a quarter turn.  I use the breaker bar swing as one gauge and the pen marking for verification.
Rob
Reply #2October 06, 2009, 10:54:40 am
OM617
Re: Angle torque??
« Reply #2 on: October 06, 2009, 10:54:40 am »
Bolts clamp like a spring. The angle method stretches the bolt to a known length for it to provide tension. This is why "torque to yield" bolts should never be reused and "stretch bolts" should only be used once if given a choice.
Reply #3October 07, 2009, 09:31:48 am
1.9TD Caddy
Re: Angle torque??
« Reply #3 on: October 07, 2009, 09:31:48 am »
Thanks you guys!
