Author Topic: Monster AAZ Build  (Read 19185 times)
October 03, 2009, 02:42:32 pm
catlin_cava
  • 1954
Monster AAZ Build
« on: October 03, 2009, 02:42:32 pm »
Alright so I'm building an AAZ that needs to be reliable but I also want to be able to run the 1/4 in 13's. Here is what I've got planned so far.
complete AAZ overhaul,
K26/24 Hybrid
Giles Pump
Borred out to .5mm Over
Stage 3 Clutch
Intercooler
2.5" turbo back exhaust
I'm looking for 200 ish HP, and much more torque, I want over 300ftlbs of Torque. I do plan on looking at a Nitrous System, maybe a 50 or 75 Shot to be injected at WOT. Only for 1/4 mile racing
What else am I over looking at this?
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #1October 03, 2009, 05:25:39 pm
rallydiesel
  • 1880
Re: Monster AAZ Build
« Reply #1 on: October 03, 2009, 05:25:39 pm »
You may want to get some upgraded rods and possibly a crank girdle. Definitely an aggressive exhaust porting. I would go 3" exhaust rather than 2.5".
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2October 03, 2009, 05:50:43 pm
truckinwagen
  • 1895
« Reply #2 on: October 03, 2009, 05:50:43 pm »
I do have one extra girdle already made up if you decide you need one.
83 Opel Kadett Diesel
Reply #3October 03, 2009, 06:27:25 pm
catlin_cava
  • 1954
« Reply #3 on: October 03, 2009, 06:27:25 pm »
crank girdle? sorry i don;t want to sound like a moron
Catlin
Reply #4October 03, 2009, 07:36:57 pm
truckinwagen
  • 1895
« Reply #4 on: October 03, 2009, 07:36:57 pm »
well, a main bearing girdle, yes.
it needs to have the holes drilled, but there are dimples in the centers of where they should go, so you dont have to worry about drilling in the wrong place.
and it needs the slag cleaned off it(really simple with a wire wheel/grinder)
and you will need to come up with spacers to go between the girdle and the main bearing caps, but that should be easy/cheap for your local machine shop to do.
all the expensive/hard work is done.
you could have it for $70 plus shipping(a real steal compared to the $400 they cost commercially)
the $70 covers what I paid the machine shop to make it, plus ten ish dollars for my trouble(the machine shop needed constant hounding for over a month to get them to spit these out)
just let me know if you are interested!
-Owen
Reply #5October 04, 2009, 04:00:50 am
catlin_cava
  • 1954
« Reply #5 on: October 04, 2009, 04:00:50 am »
So its for strenghing up the Bottom end of the motor? I may be interested in it, I will def keep it in mind.
Any ideas what kind of connecting rods i'm going to need? I heard rumours that VW's have forged internals? I know the ABA had forged Rods and Pistons
Catlin
Reply #6October 04, 2009, 04:13:48 am
stewardc
« Reply #6 on: October 04, 2009, 04:13:48 am »
I never did any of the rods or the girdle on my AAZ, but then 300 HP was not a goal. I used late rods and ARP studs/bolts throughout. Better rods are the later Pumpe Duse rods from a TDI. Do the head porting for sure. It made mine breathe a lot better. Also a PD 140 or PD 150 intake manifold flows a lot better. Get an air/oil oil cooler in place of the water/oil one. 3" is overkill for these engines on the exhaust.
Reply #7October 04, 2009, 04:18:55 am
catlin_cava
  • 1954
« Reply #7 on: October 04, 2009, 04:18:55 am »
Well I'm Aiming for around 150 to 200HP, and over 300ftlbs of torque before Spray.... ;D .... The Motor I'm rebuilding is a 97 AAZ. So TDI Rods will fit in the AAZ? and For the intake I'm planing on making a custom Intake, and Exhaust Collector to the turbo,
Catlin
Reply #8October 04, 2009, 04:25:32 am
stewardc
« Reply #8 on: October 04, 2009, 04:25:32 am »
Sounds like a bear. Yes, the PD rods will fit the AAZ.
Reply #9October 04, 2009, 04:35:30 am
catlin_cava
  • 1954
« Reply #9 on: October 04, 2009, 04:35:30 am »
Where would I be able to pick up a set of those?
Catlin
Reply #10October 04, 2009, 06:54:02 am
« Reply #10 on: October 04, 2009, 06:54:02 am »
Have you read this about the K24/26?
http://www.vwdiesel.net/forum/index.php?topic=20820.0
Reply #11October 04, 2009, 08:39:12 am
stewardc
« Reply #11 on: October 04, 2009, 08:39:12 am »
I think the dealer would be the only source, but you could try a want ad in the classified section.
Reply #12October 04, 2009, 08:48:43 am
catlin_cava
  • 1954
« Reply #12 on: October 04, 2009, 08:48:43 am »
No I hadn't read that, but now I did. What would you suggest for a turbo?
Catlin
Reply #13October 04, 2009, 08:49:41 am
stewardc
« Reply #13 on: October 04, 2009, 08:49:41 am »
Garrett T3
Reply #14October 04, 2009, 12:32:00 pm
rabbid79
  • 684
« Reply #14 on: October 04, 2009, 12:32:00 pm »
Actually, be careful.  I don't think PD rods will fit.  They have bigger "big ends".  The 1Z, AHU, and ALH rods may be fine though.
'15 WRX
