Author Topic: Connecting Rod bolts  (Read 6538 times)
September 30, 2009, 12:45:14 pm
1.9TD Caddy
« on: September 30, 2009, 12:45:14 pm »
This is my first engine rebuild. Do you guys advice replacing the connecting rod bolds on my 1.9 AAZ? Thanks!!
Reply #1September 30, 2009, 08:05:56 pm
diesel smoke
  • 209
Re: Connecting Rod bolts
« Reply #1 on: September 30, 2009, 08:05:56 pm »
Yes! They are one time use stretch bolts.  ;)
'99.5 Bora TDI
'88 Fox Coupe
'71 Tin Top Westfalia Bus
'85 Mercedes 300SD
Reply #2September 30, 2009, 08:09:02 pm
« Reply #2 on: September 30, 2009, 08:09:02 pm »
As are the main bearing bolts iirc, and of course the all-important crank sprocket bolt.  ;)
Reply #3October 02, 2009, 12:29:30 pm
1.9TD Caddy
« Reply #3 on: October 02, 2009, 12:29:30 pm »
Can any one help me with P/N for the main bearing cap bolts? Who sells them?
Thanks!
Reply #4October 02, 2009, 12:31:32 pm
rallydiesel
  • 1880
« Reply #4 on: October 02, 2009, 12:31:32 pm »
I don't know about the AAZ, but on the 1.6, the main bearing cap bolts can be re-used.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #5October 04, 2009, 04:17:24 am
stewardc
« Reply #5 on: October 04, 2009, 04:17:24 am »
Never reuse those bolts either. They have been a major cause of grief in modded AAZs. Go ARP throughout.
Reply #6October 04, 2009, 08:13:49 am
« Reply #6 on: October 04, 2009, 08:13:49 am »
The dealer is a good source
Reply #7October 04, 2009, 08:40:56 am
stewardc
« Reply #7 on: October 04, 2009, 08:40:56 am »
The dealer doesn't have ARP and there's little sense using stock bolts when the ARP units are sooo much stronger for very little more money......IMHO. ;)
Reply #8October 05, 2009, 06:12:44 am
« Reply #8 on: October 05, 2009, 06:12:44 am »
yeah my arp bolts paid for themselves already. I had to take out the rotating ass. when I didn't put any of the "vw paste" on the oil squirters...I didn't have paste either just high temp silicone and break cleaner before hand. But when I was retorqing all of the rods I was smiling that I didn't have to put new bolts in. Especially since the engine hasn't made a start yet.
$100 arp vs. $70 dealer every time. ARP FTW!
Reply #9October 05, 2009, 12:42:28 pm
gilligan5000
  • 63
« Reply #9 on: October 05, 2009, 12:42:28 pm »
Depending on what the nuts look like, the rod bolts may be reusable.  The pictures are available in poor richard rabbit book, as well as the bently.  They supposedly are good for 6 re-torque's in their lifetime...which is good, because they are pressed into the rods and a biotch to change.
The main bolts really should be replaced with ARP's.  and remember, order two sets of main bearings and never use the 2 piece #3 (center) bearing; re-use the factory thrust bearings  (if not worn terribly) and a regular 1,2,4, or  5 bearing shell...otherwise all your work will be for nothing in a few thousand miles.
Reply #10October 05, 2009, 03:02:04 pm
1.9TD Caddy
« Reply #10 on: October 05, 2009, 03:02:04 pm »
Thanks all for all the advice!
Reply #11October 10, 2009, 02:10:41 am
rolo
  • 40
« Reply #11 on: October 10, 2009, 02:10:41 am »
"the "vw paste" on the oil squirters"????    Should I be worrying?
the last one
Reply #12October 10, 2009, 06:38:05 am
« Reply #12 on: October 10, 2009, 06:38:05 am »
I don't know, but there was a thread about it not long ago and it worried me enough to do it. If it would have been in the car or even the head on I wouldn't have done it unless there was trouble.
