Author Topic: more supercharger talk  (Read 158006 times)
Reply #165December 06, 2009, 07:28:02 pm
truckinwagen
  • 1895
Re: more supercharger talk
« Reply #165 on: December 06, 2009, 07:28:02 pm »
that works, but do you do it that way to time the engine?
I have found that it is very easy to turn the crank too much, and finding perfect TDC is fiddly.
the notch in the pulley may make it a little easier.
83 Opel Kadett Diesel
Reply #166December 06, 2009, 07:28:43 pm
« Reply #166 on: December 06, 2009, 07:28:43 pm »
i just made a thread on the tex, cause i know i've seen them but i cant remember where from
Reply #167December 06, 2009, 07:46:28 pm
truckinwagen
  • 1895
« Reply #167 on: December 06, 2009, 07:46:28 pm »
cool, I just put one up in the MK2 forums as well, and I might throw one up in the G60 forum too.
-Owen
Reply #168December 06, 2009, 07:47:14 pm
« Reply #168 on: December 06, 2009, 07:47:14 pm »
What about using an ALH roller like one of the ones in this picture?
http://www.dieselgeek.com/images/DCP_8363.JPG
Reply #169December 06, 2009, 07:49:41 pm
truckinwagen
  • 1895
« Reply #169 on: December 06, 2009, 07:49:41 pm »
well, I have a couple gasser timing belt tensioners lying around, so for the moment I will proceed that way.
but if a reverse rotating water pump becomes available, I will go that route to eliminate moving parts.
Reply #170December 06, 2009, 07:54:20 pm
« Reply #170 on: December 06, 2009, 07:54:20 pm »
I did some searching, didn't come up with much
http://forums.vwvortex.com/zerothread?id=4099567
Reply #171December 06, 2009, 08:05:06 pm
truckinwagen
  • 1895
« Reply #171 on: December 06, 2009, 08:05:06 pm »
yeah, I have done extensive searching on the vortex, and the interwebz in general, and come up with nothing.
one thing that came up was to import the impeller into cad, mirror it, and then have it machined.
might be doable, but pretty costly.
the other thing is, weren't some of the impellers(maybe cheap replacements) stamped out of steel with little flaps bent inwards?
one like that would not be too difficult to manufacture with the flaps made facing the other way.
-Owen
Reply #172December 07, 2009, 02:20:32 pm
Turbinepowered
  • 1206
« Reply #172 on: December 07, 2009, 02:20:32 pm »
They're not very good pumps, though.
Reply #173December 07, 2009, 03:41:37 pm
truckinwagen
  • 1895
« Reply #173 on: December 07, 2009, 03:41:37 pm »
well, the general consensus os that reverse water pumps do not exist.
it is also apparent that that is plenty of belt contact to turn the water pump.
that being said, I am going to put the timing belt tensioner on the alternator bracket simply to make adjusting the belt tension easier.
-Owen
Reply #174December 07, 2009, 04:16:39 pm
« Reply #174 on: December 07, 2009, 04:16:39 pm »
yeah those pumps really suck on a jetta/golf, but on a  vanagon i heard they barely work, i think i put one on my car but i don't remember, kind of regret that.
Reply #175December 07, 2009, 07:38:51 pm
« Reply #175 on: December 07, 2009, 07:38:51 pm »
If you mirrored the impeller you would also need to mirror the scroll in the water pump casting.
Good point......plus they're junk.
Reply #176December 08, 2009, 03:17:08 am
gldgti
  • 488
    • http://scramjetsite.8m.com
« Reply #176 on: December 08, 2009, 03:17:08 am »
how about a standalone electric water pump?
'91 Golf Cabrio 1.9TD
Reply #177December 09, 2009, 07:46:27 am
macka
  • 957
Quote from: Vincent Walden
Reply #178December 13, 2009, 06:11:36 pm
calebessent
  • 16
« Reply #178 on: December 13, 2009, 06:11:36 pm »
Is it running, yet?
Reply #179December 13, 2009, 06:48:30 pm
truckinwagen
  • 1895
« Reply #179 on: December 13, 2009, 06:48:30 pm »
nope, the holidays have taken my time, have to go to homer to visit the folks and what not.
the motor will be going in the car after the new year.
