Author Topic: Is this even remotely possible? Over charging?  (Read 5077 times)
September 18, 2009, 02:04:28 am
  • 3468
    • McScrubbins Body Wash
« on: September 18, 2009, 02:04:28 am »
Could an alt be over charging the battery?
One of my parents had to move the cars around in the driveway this morning before i left for class.
I come up to the car in a rush to go to class to the sound of click,click,click...
Hurray, that sounds JUST like my glow plug relay... long behold there it is, still brightly glowing my GP switch in its orange goodness.
I jumped the jetta and i noticed that my alt light was not on at all! not dimly, no flickering no nothing.
could the light be triggered by being over charged?
Also, my running lights no longer work and nor do my high beams. My running lights come on with the switch but then when i turn on the high's my lights go out...
I had this issue before but then it went away.
Fuse or relay?
My guess is relay. Anyone know which one?
Reply #1September 18, 2009, 08:04:08 am
Re: Is this even remotely possible? Over charging?
« Reply #1 on: September 18, 2009, 08:04:08 am »
Sounds like a relay to me Ed.
Better bust out the Bentley and start reading again.
Look for the DRL (daytime Running Light) relay.
Reply #2September 18, 2009, 11:00:11 am
truckinwagen
  • 1895
« Reply #2 on: September 18, 2009, 11:00:11 am »
it is indeed possible to over charge a battery.
if your alt is putting out too high a voltage you can overcharge and boil off your batteries water.
a good way to tell if that is the problem is to pop the vent caps off your battery and see if the water is low.
it still sounds like a relay problem though.
83 Opel Kadett Diesel
Reply #3September 18, 2009, 07:04:16 pm
  • 3468
« Reply #3 on: September 18, 2009, 07:04:16 pm »
Aie aie fellas!
about that bentley... :P
Reply #4September 23, 2009, 12:29:15 pm
Zulfiqar
  • 254
« Reply #4 on: September 23, 2009, 12:29:15 pm »
you can only overcharge your batt with higher volts - if you regulator is duff.  I think you should check your grounds first
Diesel IS the future
Reply #5September 23, 2009, 12:32:00 pm
  • 3468
« Reply #5 on: September 23, 2009, 12:32:00 pm »
I just checked the battery and it was very very low. well below the minimum mark.
I should regularily clean the grounds.
Reply #6September 23, 2009, 01:05:01 pm
truckinwagen
  • 1895
« Reply #6 on: September 23, 2009, 01:05:01 pm »
clean the grounds really good, like with a grinder to get good metal to metal contact, and then re install with a good layer of dielectric grease on all mating surfaces to keep them from rusting/corroding again.
-Owen
Reply #7September 23, 2009, 03:24:41 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #7 on: September 23, 2009, 03:24:41 pm »
BE VERY CAREFUL OF LOW "WATER" LEVELS :P :P :P :P :P :P :P :P
The gas in a battery is hydrogen and oxygen at the perfect mix,
after some use, the plates in a battery deteriorate, and bits can float around and get loose. The plates are close together, and a bit of crap can get dislodged and make a circuit between the plates. If you topped up the fluid, this happens "underwater", so no bang. But if this happens in that nice hydrogen oxygen mix now that the fluid is too low and the plates are uncovered, the battery grenades lots of plastic shrapnel and sulphuric acid. To bad if you were carrying it at the time. Seen a few good ones after the event at the scrapyard. :o
Reply #8September 25, 2009, 06:09:08 pm
macka
  • 957
« Reply #8 on: September 25, 2009, 06:09:08 pm »
Aie aie fellas!
wanna borrow mine?
Quote from: Vincent Walden
Reply #9September 25, 2009, 06:28:08 pm
« Reply #9 on: September 25, 2009, 06:28:08 pm »
just use a cheap multimeter to check the alternator charging.  the voltage regulator is sort of like a big relay. once the set voltage is hit, it magnetizes the contact, and stops energizing the rotor, so the alternator can't produce a charge.  now i do believe some voltage regulators come with a little potentiometer so that you can adjust the charging voltage... so you might want to look into that.  but if not, then you could always find an old broken power supply from a computer, and snag the biggest resistor you can find, and wire that up to the voltage regulator.  it might just do the trick. just make sure you install it to the right lead on the regulator though! :)
