Author Topic: engine conversion  (Read 6224 times)
September 12, 2009, 09:59:23 am
turborabbit
  • 41
engine conversion
« on: September 12, 2009, 09:59:23 am »
Anybody know anything about engine adaptors? I am mulling over attempting to swap a 1.6na diesel for the 34hp 4cyl gas Ford in my Bobcat. Can machine shops build adaptors for this purpose? Any experiences out there-thanks-warren :-\
If "the more you know, then the more you know, you don't know, then I've got a lot to learn, since I'm forgetting what I thought I knew!!
01Dodge TD
81 Caddy TD
84 Winnebago/Renault TD
86Jetta84GolfCaddyCaddyCaddyCaddy
Reply #1September 12, 2009, 06:48:21 pm
maxfax
  • 2126
Re: engine conversion
« Reply #1 on: September 12, 2009, 06:48:21 pm »
I've seen anything from having an adapter made to using a partial bell housing trans input shaft and a coupler...
How does the Ford engine connect to the rest of the drive???   Pics are a plus!
Reply #2September 12, 2009, 07:10:20 pm
« Reply #2 on: September 12, 2009, 07:10:20 pm »
Kennedy Engineering are the kings of engine adapters... they used to do "send us tracings of the bell housing and we'll make you an adapter" work... dunno if they still do.
Reply #3September 13, 2009, 09:33:03 am
« Reply #3 on: September 13, 2009, 09:33:03 am »
if you have a drill press, grinder steel, and lots of time, why not do it yourself? most people use cardboard or bristle board to get the bolt pattern and transfer it to a steel plate. the most crucial part is getting the transmission shaft lined up properly. a micrometer is a very good idea to be as precise as possible. this site gives a good idea of whats involved, but they use CAD software to make a very precise plate (good idea, but $$$).  doing it by hand, i'd say measure about 100 times, and drill once. a misaligned hole can ruin the whole plate.
Reply #4September 14, 2009, 06:26:17 pm
turborabbit
  • 41
« Reply #4 on: September 14, 2009, 06:26:17 pm »
Thanks, guys, all good suggestions. I haven't pulled the Ford, yet, in fact, I just checked compression, today, 95-155-120-120, so I haven't given up on the gasser, yet. I much prefer diesel/wvo and size wise the 1.6 seems to fit, maybe a little too much power, though. Does VW make any smaller (hp) engines? Thanks again-warren
01Dodge TD
81 Caddy TD
Reply #5September 14, 2009, 07:26:36 pm
burnt_servo
  • 278
« Reply #5 on: September 14, 2009, 07:26:36 pm »
if the engine fits ok size wise , i wouldn't worry about having too much hp ,  you can turn the pump down so it makes less power overall .
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
Reply #6September 16, 2009, 06:16:41 pm
Wayland
  • 364
« Reply #6 on: September 16, 2009, 06:16:41 pm »
I could be wrong, but I thought I heard somewhere that some Bobcats came with Vw diesels. Might be worth looking in to.
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
Reply #7September 16, 2009, 09:08:05 pm
Turbinepowered
  • 1206
« Reply #7 on: September 16, 2009, 09:08:05 pm »
If I'm not mistaken ours has a three cylinder Kubota in it.
