Author Topic: Yikes! Coolant problem after Turbo install  (Read 11066 times)
September 08, 2009, 05:53:09 am
BlastIt
  • 66
    • bigrblasting.com
« on: September 08, 2009, 05:53:09 am »
I just finished installing a vnt-15 on to my 82 caddy. It's a 1.6 na. I replaced the head gasket, cam shaft seal, valve cover gasket, piston rings,
oil pan and gasket, new water pump, new thermostat, new expansion tank cap. Set the timing and injection pump timing. Went on a test drive
to start to dial the turbo in. When the turbo would get to just around 15 psi of boost it would start to blow coolant out of the expansion tank cap. Thats when I test the old cap found it bad and replaced it with a new one from VW. Went on a second test drive same thing blows coolant
out of the expansion cap. Where do I need to start looking to correct this problem. When the head was off there was no signs of cracks or damage. It has only been on the truck for maybe 10,000 miles. It was replace by the PO. Any help or thoughts are greatly needed.
Thanks John
Reply #1September 08, 2009, 08:14:53 am
BlastIt
  • 66
    • bigrblasting.com
Re: Yikes! Coolant problem after Turbo install
« Reply #1 on: September 08, 2009, 08:14:53 am »
That's not really what I wanted to hear. lol
A question though, How come it would not have shown up before? Is it possible that if I installed the wrong water pump or thermostat that it
may cause this? Grasping for straws here.
Reply #2September 08, 2009, 09:05:38 am
BlastIt
  • 66
    • bigrblasting.com
« Reply #2 on: September 08, 2009, 09:05:38 am »
One thing I found when running around 50 to 55 mph when I go to accel and the boost goes up to 15 or little higher is when it pushes the coolant out. When at lower speeds and lower gears hitting the same boost it does not push coolant out. Thats what made me think maybe water pump or thermostat building to much pressure. Am I way off base and still looking at bad head gasket and or cracked head/Block.
Reply #3September 08, 2009, 09:22:37 am
« Reply #3 on: September 08, 2009, 09:22:37 am »
If it only happens under boost, then that means your coolant system is getting pressurized, which can only happen by a cracked head/block, or a headgasket problem/sealing issue.
Reply #4September 08, 2009, 12:05:49 pm
BlastIt
  • 66
    • bigrblasting.com
« Reply #4 on: September 08, 2009, 12:05:49 pm »
yall were right. :'(  Head gasket is blown in at least 1 spot next to a coolant passage. I did some more checking and found the PO installed the wrong head gasket. It was a 3 notch but after checking it should have a 1 notch gasket. I guess I'll get the right gasket and try it again.
Thanks for the help guys.
Reply #5September 08, 2009, 05:10:32 pm
Baron VonZeppelin
« Reply #5 on: September 08, 2009, 05:10:32 pm »
Did you use New head bolts when you replaced the gasket last time ?
Did you follow all the special ceremonies for torquing - and the follow up torquing ?
Just wondering, not accusing.
Because i don't think having a 3 notcher where a 1 notcher should be would necessarily cause any problem with sealing. Some guys even purposely do that on Turbo Diesels.
Does your engine have 11mm or 12mm headbolts ?
What i'm basically getting at - is same thing could just happen again unless something is done different this time.
Reply #6September 08, 2009, 06:43:07 pm
Rabbit TD
  • 840
« Reply #6 on: September 08, 2009, 06:43:07 pm »
  When you pull the head off look at the block real close where the head bolts screw in to check for cracks around the holes.  I wouldn't even think about putting it back together without studs especialy if it is an 11 m/m bolt which doesn't thread in the block very far.  All the 1.5's and 1.6's eventualy have head gasket problems and the studs are the best cure for this and some say the metal headgasket as well.  Me personaly, I'd be afraid of the metal gasket unless at least the head was resurfaced and definately used studs with.  You don't have any water pump problems or thermostat problems from what you describe, just the compression problem these things always end up with when we get one of these beasts :(
Reply #7September 09, 2009, 04:45:50 am
BlastIt
  • 66
    • bigrblasting.com
« Reply #7 on: September 09, 2009, 04:45:50 am »
It was put back together with new arp studs. I did follow the torque sequence. I will also double check the head and block all seemed good last time. It is 12mm studs. What do you think the best gasket is to use in the case 1,2 or 3 notch? The spec for the gasket falls on the high side for the 1 notch gasket according to the bentley. It was .81 and the bentley says up to .82 for 1 notch.
Reply #8September 09, 2009, 06:45:44 am
BlastIt
  • 66
    • bigrblasting.com
« Reply #8 on: September 09, 2009, 06:45:44 am »
Thanks Andrew, One other question may be stupid but anyway. If I do need the head machined what needs to be done with the pre chambers?
Does it need to be machined with them in or out?
Reply #9September 09, 2009, 10:26:30 am
BlastIt
  • 66
    • bigrblasting.com
« Reply #9 on: September 09, 2009, 10:26:30 am »
With the ARP studs I should still follow the Bentleys method for tightening the studs right? Cause the directions for the arp studs say go straight to 80 ft-lbs.
Reply #10September 09, 2009, 12:06:50 pm
Baron VonZeppelin
« Reply #10 on: September 09, 2009, 12:06:50 pm »
Here's another goof question.
If spec called for .82 limit, and your spec was .81 -
would there be any appreciable foresight in going to the next gasket up, to allow for carbon build up on the dome and in the chambers over the next 100,000 miles ?
Or is that too much over-thinking ?
Reply #11September 09, 2009, 12:39:11 pm
jettabrendan
  • 198
    geschwindigkeitsueberschreitung
« Reply #11 on: September 09, 2009, 12:39:11 pm »
What about air in the system? We all know its a pita to bleed it..
1991 Jetta TD Dark Teal
1983 bmw e21 320is Hennarot
1997 Volvo 850 Black
Reply #12September 09, 2009, 07:26:08 pm
Baron VonZeppelin
« Reply #12 on: September 09, 2009, 07:26:08 pm »
The page rolled over, so wanted to put this up again.
Reply #13September 10, 2009, 04:05:02 am
BlastIt
  • 66
    • bigrblasting.com
« Reply #13 on: September 10, 2009, 04:05:02 am »
I'll let you know how I make out. I will be installing a new head gasket today. Keep your fingers crossed, I'll need all the luck I can get.
Reply #14September 10, 2009, 06:57:16 am
BlastIt
  • 66
    • bigrblasting.com
« Reply #14 on: September 10, 2009, 06:57:16 am »
Yes, I did Have them checked. My guy at the machine shop said should have no problems with the surfaces.  ;D
