Author Topic: Do I have to remove head to install turbo, intake, and exhaust manifolds?  (Read 7218 times)
September 06, 2009, 05:51:06 pm
mtnbob
  • 738
Just wondering if there was an easier way ;D
Getting ready to to a turbo changeover. Hope I don't need a different rear engine mount :o
96 Subaru Outback Wagon
Reply #1September 06, 2009, 11:46:30 pm
Quantum TD
  • 1195
Re: Do I have to remove head to install turbo, intake, and exhaust manifolds?
« Reply #1 on: September 06, 2009, 11:46:30 pm »
No, you don't need to remove the head. But, you do need to have a good 6mm allen-bit socket, and lots of patience. Rubber arms help too.
Basically, you'll need to remove the intake manifold. I usually feel in there with the tip of the allen bit, find a bolt hole, and hammer the thing in there (to prevent stripping). Then loosen each one.
Once the intake's off, have fun with those exhaust nuts! Aerokroil or PB blaster them overnight. Use heat if necessary.
Whenever I do a motor swap or a head job on a MK1 or MK2, I always leave the intake and exhaust manifold off until the motor (or head) is in the car. Then I give the head a reach-around and install the manifolds.
Reply #2September 07, 2009, 12:42:36 am
mtnbob
  • 738
« Reply #2 on: September 07, 2009, 12:42:36 am »
Thanks for the advice. I'd prefer to avoid replacing the headgasket and bolts if I dont have to. I couldn't even find the bolts to remove the intake manifold today, but I'll have a better look at it tommorrow in sunlight. 8)
Reply #3September 07, 2009, 07:29:14 am
« Reply #3 on: September 07, 2009, 07:29:14 am »
There are 6 intake manifold bolts. If you look at your turbo intake you will see exactly where they will be. You will need shorter bolts for the turbo intake... or maybe longer, I forget now.
Reply #4September 07, 2009, 02:53:22 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #4 on: September 07, 2009, 02:53:22 pm »
 ;DYup, it is a right git of a job!
If I was doing it again I would be tempted to jack the engine and remove the front engine mount (it will probably be knackered anyway) and ease the jack down, the engine should flop forward enough to make it  merely a wretched job to get at all the bits at the back. But I don't know wether this would work, or instead the engine falls out onto your legs :o, so best have a think first. The turbo manifold  is a 2 foot thick casting of recycled depleted uranium, at least that is how it feels with the head attached. It is heavy. :P
Reply #5September 07, 2009, 05:27:01 pm
mtnbob
  • 738
« Reply #5 on: September 07, 2009, 05:27:01 pm »
My only alternative would be to remove the head, then replace the headgasket and bolts? Is that any easier? I guess If I go that route, do the timing belt too since I have to switch in a turbo injection pump ::) Any other suggestions? This is the biggest undertaking I've attempted so far. :o
Reply #6September 09, 2009, 12:42:53 pm
jettabrendan
  • 198
    geschwindigkeitsueberschreitung
« Reply #6 on: September 09, 2009, 12:42:53 pm »
Not gunna lie, your probably going to have to replace the headgasket at some point, so I would just take off everything, change to studs, new gp's and block heater while its all apart.there isn't much space to work with and if you don't have a hoist it sucks getting under them, and I'm not a big guy. Just my 2 cents...
1991 Jetta TD Dark Teal
1983 bmw e21 320is Hennarot
1997 Volvo 850 Black
Reply #7September 09, 2009, 04:17:24 pm
« Reply #7 on: September 09, 2009, 04:17:24 pm »
Personally out of every task that I have ever done on a VW diesel, doing a head gasket job is BY FAR my least favorite. Unless you suspect a problem with your gasket I wouldn't touch it. It's not that hard to get the turbo/manifolds off. Your back will hate you the next day though, I can promise you that.
Reply #8September 09, 2009, 05:37:37 pm
jettabrendan
  • 198
« Reply #8 on: September 09, 2009, 05:37:37 pm »
Really haha, I liked doing it, I would do it again any day. To each his own I guess.
Reply #9September 10, 2009, 10:25:42 am
smutts
  • 720
« Reply #9 on: September 10, 2009, 10:25:42 am »
It's not THAT hard to do the manifolds, but it's just a fiddle as it is tight to the bulkhead (firewall?). Try the engine mount idea, there may be some joy there. ;D
Reply #10September 10, 2009, 11:34:13 am
88jetta350
« Reply #10 on: September 10, 2009, 11:34:13 am »
If you do go that route, please let us all know how it works for you, so we know if we should do it that way ourselves from now on.
Reply #11September 14, 2009, 06:35:58 pm
Jettage1
  • 202
    Past VWs: 80 Scirocco S, 90 GTI, 00 Passat GLX
« Reply #11 on: September 14, 2009, 06:35:58 pm »
Stop by next time you're in my neck of the woods - got one all ready and waiting just for you!   ;D
Steve
92 Jetta EcoDiesel
     pumped by Giles...powered by Frybrid...functional by dumb luck
Reply #12September 17, 2009, 09:54:09 am
macka
  • 957
« Reply #12 on: September 17, 2009, 09:54:09 am »
he has to stop at my place first
Quote from: Vincent Walden
Reply #13September 17, 2009, 08:35:09 pm
  • 2932
« Reply #13 on: September 17, 2009, 08:35:09 pm »
Setting the head on with the manifolds attached won't be easy either. Probably a 2-person job.
Reply #14September 23, 2009, 03:14:53 pm
SolarSteve
  • 264
« Reply #14 on: September 23, 2009, 03:14:53 pm »
Placing the head on with the manifolds on isn't very bad at all IF you take 2 of your old head bolts and cut them off about 2 - 3 inches from the bottom and then grind a slot in the top to fit a screw driver.  Once you are ready to install the head, screw the two bolts into two head bolt holes at adjecnt corners, set the gasket on the block over the studs and lower the head down over the studs on to the block/gasket.  Install the first 4 new bolts finger tight and then use a long skinny screw drive to unthread the cut bolts.  Use a stick magnet to pull the cut studs out and then press on with the install.
Or just install head studs...
Steve
91 Jetta 1.6 N/A
