Author Topic: FS: 1991 VW Jetta Diesel 1.6 non-turbo 414K Carmel, IN 46032  (Read 4293 times)
August 15, 2009, 10:06:29 am
Dan414
  • 5
« on: August 15, 2009, 10:06:29 am »
This is my daily driver that I have had since 1995. I recently have changed cars, so I am reluctantly selling this one. I got it when it had 76K on it and it now has 414K, so as you can imagine, I pretty much know the history of it since I have done everything on it in the meantime myself except 2 clutches and a head gasket that I had other people do. The engine is good – does not use any oil – maybe a quart between oil changes. Right now it does need a head gasket, it went out in the winter, and I ended up deciding to sell it this way. Here’s what has been done in the last year: Timing belt, water pump, injector pump rebuilt, glow plugs, 1 new front wheel bearing – the other one not that long ago, new front calipers, rotors, pads, booster, and master cylinder. It has good alloy wheels that ride smooth, but the tires are ready to be replaced. It has the high 5th gear, which is nice, that I put in way back at the beginning, The rear brakes and cable are worn out. Needs a head gasket. The body is a little rusty around the edges in a few spots. AC has had a leak for a while that I never fixed. It has never had new injectors, but has always gotten 42mph average. The return hoses seem to leak a little, but I haven’t tried replacing the whole return line yet either- probably just the injectors because they seem to give off a steady stream of excess fuel that is probably more than the hoses can handle. In the winter this year it was starting fine until I could tell that the head gasket was bad.  Any questions, let me know, would be happy to talk on the phone, too. The windshield is cracked. I am happy to answer any other questions. Asking $1800. For photos click this or paste it in.:
http://www.kodakgallery.com/ViewSlideshow.action?&collidparam=614950585111.276664716211.1250350871906
1991 Jetta Diesel
2001 Beetle TDI
Reply #1August 15, 2009, 10:25:14 am
mtnbob
  • 738
Re: FS: 1991 VW Jetta Diesel 1.6 non-turbo 414K Carmel, IN 46032
« Reply #1 on: August 15, 2009, 10:25:14 am »
Isn't that a turbo injection pump? 8)
96 Subaru Outback Wagon
Reply #2August 15, 2009, 12:37:19 pm
foxracer1
  • 991
« Reply #2 on: August 15, 2009, 12:37:19 pm »
It has the alditude compesation on it. It limits full fuel at higher elevation. Can be used as a turbo pump with nods.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #3August 15, 2009, 12:40:52 pm
ilikevwdiesel
  • 1202
« Reply #3 on: August 15, 2009, 12:40:52 pm »
nope. it's the same pump as a turbo car but the pressure to the diaphragm is sent underneath it instead of above. it's regulated by the valve near the fuel filter. It leans out the mixture at high altitude to control emissions. A pump builder can easily convert that pump into a turbo pump though.
My Bio
Reply #4August 15, 2009, 01:23:01 pm
mtnbob
  • 738
« Reply #4 on: August 15, 2009, 01:23:01 pm »
I love this site! I learn something every time I'm here ;D
