Author Topic: 1.6l Head Identification  (Read 18853 times)
September 21, 2005, 12:22:57 pm
Fisher
  • 148
« on: September 21, 2005, 12:22:57 pm »
Does anyone know if VW heads can be identified by the vw part numbers.
I bought what is supposed to be a TD Head 068 103 373E, can this be identified as a TD head?
068 103 373F  ?????    Thanks for any help.
Reply #1September 21, 2005, 12:27:04 pm
vwmike
  • 1158
« Reply #1 on: September 21, 2005, 12:27:04 pm »
I think there are some subtle casting differences, but that part is no longer any good. I'm sure it has been superceeded. Is it solid or hydraulic lifter?
Reply #2September 21, 2005, 12:39:16 pm
Fisher
  • 148
« Reply #2 on: September 21, 2005, 12:39:16 pm »
It's solid lifter.
Reply #3September 21, 2005, 01:13:16 pm
janb
  • 167
« Reply #3 on: September 21, 2005, 01:13:16 pm »
check with these folks, but let use know the answer...
http://www.aluminumheads.com/
Telephone: 503-230-0852,
Or toll free: 1-800-978-HEAD (4323) - (Wayne or Chuck)
Can you see a dimple on the prechamber insert?,  that is one indication of TD
The Stealth Rabbit
VW-d's are forever
Reply #4September 22, 2005, 03:34:36 pm
Fisher
  • 148
« Reply #4 on: September 22, 2005, 03:34:36 pm »
Chuck Tiller from Aluminum Heads in Portland said an E or F casting can be used for a TD.
Whatever that means!
Reply #5September 22, 2005, 10:18:38 pm
Fisher
  • 148
"Whatever that means"
« Reply #5 on: September 22, 2005, 10:18:38 pm »
Yes I did but someone ahead of you asked that I let them know what the guy from the head shop says.
Reply #6November 06, 2005, 06:04:55 pm
chrissev
  • 694
Re: 1.6l Head Identification
« Reply #6 on: November 06, 2005, 06:04:55 pm »
Quote from: "Fisher"
Regarding the F casting:  do you know if it is a solid or a hydraulic lifter head?  My TD has a D casting and it is hydraulic and I have found a rebuilt F casting head for $210 and would really like to pick it up for this price but I don't know if it will work on my engine.
Reply #7July 20, 2006, 05:01:40 pm
sethyboy85
  • 284
« Reply #7 on: July 20, 2006, 05:01:40 pm »
Quote from: libbybapa
I have a solid lifter engine code "ME".  Odd to me that VW also used ME for hydraulic n/a motors.
The head casting number is 068 103 373 M.
Anyone seen the M head before, and on what motor?
Andrew
I have a NA motor with that casting on the head... so I assume it's a Hyrdaulic and it has the vertical bump that my 91 ECO has.
91 Dodge Spirit R/T 2.2l T3/T4, Big valve head, 3" exh, NPR IC, goal. FS $4000
85 1.6lTD Garrett, NA34X mercedes INJ,2.5" turbo back- Sold
85 TD/91 Eco need to put together to make 1 good car
86 190D Merc with only 392k
96 Volvo 850 Turbo wagon, 1 grainger valve and 250hp/280tq
Reply #8July 21, 2006, 10:02:46 am
veeman
  • 421
« Reply #8 on: July 21, 2006, 10:02:46 am »
sethboy..
I just got a rebuilt head for my 1.6TD with a mechanical head.  The casting has the same part number as yours... the "M".   I did a bit of digging around in the archives and such and as best I can determine, the part number doesn't always appear to be a rock-solid indication of what the head came on.
The shop that supplied my rebuilt head claims that one of the only ways to tell between an NA head and a TD head is the "nipple(s)"  right next to the part number by cylinder number one.   They're about the size of a pencil eraser.
I'm not sure if that's true or not, but the guy said that if the head has one or more "nipples" (mine has two), then it's the TD head casting with the increased silica.   Take that for what it's worth.  I showed him a head that came off a 1.6 NA and he said that it was also a turbo head (it had one nipple).
So...why would that be?  It could be as Jake and others have theorized that all "later" IDI diesel heads got the same alloys as time went on or possibly the head I had was a replacement.   Who knows?
Does anyone have any documented proof of an NA head getting melted from turbo use?  Do the NA heads warp prematurely or something when bolted to a TD?
I'm wondering how much the alloy matters.  There's even some debate as to whether the TD head used different valves (the part no. is different at least).  There's a post in the archives that says that they're not sodium filled.
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
Reply #9July 21, 2006, 08:43:24 pm
sethyboy85
  • 284
« Reply #9 on: July 21, 2006, 08:43:24 pm »
crap, now I don't know what headgasket to buy.. gues I could buy more than one but I was hoping to slap a AAZ 1.9l HG on the motor.
Reply #10December 04, 2012, 11:35:13 pm
Nevadan
  • 14
« Reply #10 on: December 04, 2012, 11:35:13 pm »
sethboy..
Just to  update this from some data I got today from an experienced mechanic at J's VW here in Reno, NV:  He said the small "nipples" cast into the head just indicate the crew at the factory that made the heads, it has nothing to do with the type of aluminum used in the casting.  I ask him if it was like a "night shift" signature and he said yes.
I then asked him if there was a difference in the aluminum between the TD and N/A heads and he said he didn't think so.
sethboy..
This would be the best proof and based on answers on various forums it sounds like there is no proof of an N/A head melting in a turbo application.  This from Kantdrivefast in a post from July 2009: "Ive got a non turbo head on my turbo engine... no troubles so far."
I'm convinced the only difference between the N/A and TD heads are sodium filled exhaust valves and the different prechamber inserts that have the little dimple in them indicating they the the thicker walled insert.  There are (were, for some reason they're not showing up now) some photos of a 1.9, 1.6 N/A and 1.6 TD prechambers here that show the differences:
http://www.vwdiesel.net/forum/index.php?topic=2329.30
The TD prechamber has the little dimple in it.  These were posted by Malone and originally posted by 935racer.
Jack knows the cams are the same per and email I recently got from him.
I took two heads to the same shop today to see if they could sort out the "N" vs "M' letter at the end of the head part number and they looked it up on their parts system and there was no indication that one or the other was a turbo or non turbo head.
So....I'm going to put an "M" casting head on my TD with the TD inserts (30mm, thank you Jack) and the valves I got from Jack.  I don't know if those new valves are sodium filled but he said they were for the TD.
« Last Edit: December 04, 2012, 11:39:09 pm by Nevadan »
1985 Jetta 1.6 TD
1985 Volvo 745 2.4 TD
1987 Quantum Syncro Wagon (to receive 2.0TD)
1981 Caddy (getting 1.6 TD)
2006 Touareg V10 TDI
Reply #11December 05, 2012, 06:25:04 am
« Reply #11 on: December 05, 2012, 06:25:04 am »
This is one that I asked when I was a noob and found out the casting letters and most markings mean pretty much nothing in VW. The casting number will tell you if you have a certain head, but the letter F, T, M etc at the end mean nothing for sure...sometimes it seems that certain numbers appear more often with turbo heads vs. N/A, but those letters have no concrete meaning.
Reply #12December 05, 2012, 08:28:57 am
« Reply #12 on: December 05, 2012, 08:28:57 am »
from what i understand the cams are different, td is a little bit better.  i think later tds did not come with the sodium valves but that is speculation, and from what my parts guy told me they help to keep from getting burnt exhaust valves and reduce detonation in gas engines but they also cause the valve guide and seals to wear out faster since more heat is being transfered up the stem.
« Last Edit: December 05, 2012, 08:43:50 am by Trev0rbr »
Reply #13December 05, 2012, 08:57:26 am
« Reply #13 on: December 05, 2012, 08:57:26 am »
Cams can be different but casting letters still do not tell you anything about the cams either.
FWIW you are not supposed to swap the hydro and mech cams. The ramp angles close faster on the mech and create a harmonic that can ruin the cam/valvetrain. Many do and worn cams maybe less aggressive than new. Even new the cam guy I spoke with said it can take more than 50,000 to 100,000 miles to start to show up...all depends on how aggressive the ramp angle is.
Reply #14December 05, 2012, 09:39:05 pm
  • 2931
« Reply #14 on: December 05, 2012, 09:39:05 pm »
F heads are used on NA and TD engines.
 It's the standard 12mm headbolt head.
 I think all N heads are turbo/mechanical.
