Thanks for the answers.I checked the ring, and close to the gap I found "TOPC" written.So I mounted it that way, and the groove is facing down. (the letters up)The top ring had "PC" mounted on it, so I mounted that facing upwards as well.The oil ring had nothing on it, looked to be the same on both sides, so I just put them on Hope I have compression later =)Thanks.
Quote from: klang on August 10, 2009, 03:45:05 pmThanks for the answers.I checked the ring, and close to the gap I found "TOPC" written.So I mounted it that way, and the groove is facing down. (the letters up)The top ring had "PC" mounted on it, so I mounted that facing upwards as well.The oil ring had nothing on it, looked to be the same on both sides, so I just put them on Hope I have compression later =)Thanks.If you have those letters facing up you have them on right.
