Author Topic: Can I Run 16" Low profiles on my 1990 Jetta IDI?  (Read 4495 times)
August 04, 2009, 02:08:52 pm
Matteo
  • 47
« on: August 04, 2009, 02:08:52 pm »
I have a cool set of 16" rims, but am unsure of clearance issues. Are these going to fit if I use low profiles? What would be the tallest tire, and widest adviseable?
Thanks,
Matt
Aircooled rules!
Biodiesel makes us better humans.
Make your own fuel and stick it to the man!
I never thought it was possible to Love a car.
Help me I'm sick!
Reply #1August 04, 2009, 06:43:15 pm
mystery3
  • 774
Re: Can I Run 16" Low profiles on my 1990 Jetta IDI?
« Reply #1 on: August 04, 2009, 06:43:15 pm »
You can use this handy calculator and your stock tire size:
http://www.miata.net/garage/tirecalc.html
It'll only help you so much though, what is the offset and width of your 16" wheels? If you're running 225/35 r16 or something the difference in rolling diameter is not great.
Reply #2August 04, 2009, 07:54:46 pm
Jettagli16v
  • 344
« Reply #2 on: August 04, 2009, 07:54:46 pm »
Couple questions too:
1)What size wheel? (width and offset)
2)how low is the car?
205/40-16 always works really well on a rim from 6.5-7.5" wide.
You can tuck that properly in the fenders with the proper offset and no scrub...
The short answer is:
Yes, you certainly can run some 16" lo pros on your Mk2 Jetta.
Just dont put heavy wheels on the car.
Factory alloys are surprisingly light and very strong,
and that is one of the main reasons these cars are super fun to drive.
-Brad
Reply #3August 04, 2009, 10:33:05 pm
Op-Ivy
  • 513
« Reply #3 on: August 04, 2009, 10:33:05 pm »
205-45-16 also works fine but it will depend on the offset of your wheels too. If you are going to lower your car I would advise you to go with the 40's.
Mine is lowered pretty good and I had to roll my fenders even with the 40's.
Reply #4August 05, 2009, 01:46:51 pm
Matteo
  • 47
« Reply #4 on: August 05, 2009, 01:46:51 pm »
The wheels on the car are stock. Not sure if the rimms are centerline or exact size of tires that are on them. I will have to check. I was concerned with hitting the strut and wheel wells.
Aircooled rules!
Help me I'm sick!
Reply #5August 07, 2009, 03:15:40 pm
Jettagli16v
  • 344
« Reply #5 on: August 07, 2009, 03:15:40 pm »
The wheels on the car are stock. ....I was concerned with hitting the strut and wheel wells.
There weren't any stock 16" wheels for a mk2 to my knowledge.
Strut and wheelwell contact is totally relative to
wheel width and offset...
-Brad
Reply #6August 08, 2009, 01:12:25 am
burnt_servo
  • 278
« Reply #6 on: August 08, 2009, 01:12:25 am »
Thanks,
Matt
i have 16 inch rims on my jetta ....... can't remember the size off hand , i think they are something like 215/45/16 ..... in a day or so i can pull the numbers off of the car if you want .
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
Reply #7August 11, 2009, 09:43:02 am
Matteo
  • 47
« Reply #7 on: August 11, 2009, 09:43:02 am »
I'm not sure the offset on my 16" rims that I want to put on. Is there any way to measure? The rear tires are 205 50/16 and the fronts are 205 40/16's.
The current rimms are the stock 15's.
So tire width is a consideration for hitting the strut's? That would be the 205 number with the 50 or 40 being the height? Is there a limit to Width/height on a 16" rimm? I suspect I need to know the offset first...
What is the stock 15" rim offset?
Thanks Volks,
Matt
Aircooled rules!
Help me I'm sick!
