Author Topic: Creating a W terminal on alternator.  (Read 9890 times)
July 28, 2009, 04:55:31 pm
colectb
  • 93
« on: July 28, 2009, 04:55:31 pm »
So does anyone know how to, or have a link to a good write-up with pictures on how to wire in a W terminal to an alternator without one? Thanks alot!
1986 Porsche 944 NA
1983 Audi 5000 Turbo Diesel
Reply #1July 28, 2009, 06:30:05 pm
lovinthedeez
  • 489
Re: Creating a W terminal on alternator.
« Reply #1 on: July 28, 2009, 06:30:05 pm »
by reading your post, i'm assuming that you don't have the w terminal on your alternator, this post should help its in the FAQ :P
http://www.vwdiesel.net/forum/index.php?topic=3741.0
Reply #2July 28, 2009, 08:49:33 pm
« Reply #2 on: July 28, 2009, 08:49:33 pm »
I don't think I've actually seen a pictoral how-to... will have to do one up some day with a junk alternator... but the schematic looks like this:
Tap into a field coil wire that runs to a diode bridge and bob's your uncle.
Reply #3July 28, 2009, 09:00:34 pm
colectb
  • 93
« Reply #3 on: July 28, 2009, 09:00:34 pm »
Ok thanks, I'll probably be opening up my junk alternator to attempt this sometime this/next week, and I'll be posting pictures along the way, probably asking for some guidance. Thanks alot!
1986 Porsche 944 NA
Reply #4July 28, 2009, 09:06:36 pm
« Reply #4 on: July 28, 2009, 09:06:36 pm »
Yup, if you can post a clear picture when you get the alternator apart we can photoshop where to solder on the W terminal for ya.
Reply #5August 02, 2009, 07:08:54 am
fairweather
  • 85
    • TDI Syncro
« Reply #5 on: August 02, 2009, 07:08:54 am »
Here are some pics:
remove the plastic cover off the back of the alternator and pick one of the clamping points.
83 Caddy with CY code 1.6TD out of a rabbit.
Reply #6August 02, 2009, 09:39:04 am
« Reply #6 on: August 02, 2009, 09:39:04 am »
As luck would have it I just stumbled across this writeup for the MK1 alternator... they are all pretty much the same though:
http://www.vwwatercooled.org.au/newforum/upload/showthread.php?t=31515
Reply #7August 04, 2009, 03:11:18 am
Hiho
  • 77
« Reply #7 on: August 04, 2009, 03:11:18 am »
Pretty good writeup!
1978 1.5 GLD
1978 1.6D soon to be TD
Reply #8November 04, 2009, 06:05:24 pm
macka
  • 957
« Reply #8 on: November 04, 2009, 06:05:24 pm »
you can also do this with most of the remy delco alternators running from the 87 to mid 93. So if you want a 105 amp alternator on the cheap....
Quote from: Vincent Walden
