Author Topic: What exactly does the "cold start" pull out do on my MK1?  (Read 4397 times)
July 21, 2009, 06:41:48 pm
Pre95
  • 81
« on: July 21, 2009, 06:41:48 pm »
I understand that it attaches to the injection pump, and causes something inside to make the car run a hell of a lot better then normal, without adding smoke. Whats it do? I noticed today cruising the highway it allowed me to peg the needle on the rabbit which it was unable to do with the cold start pushed in.
81 Rabbit Diesel - 250k and climbing :)
Reply #1July 21, 2009, 07:19:21 pm
Re: What exactly does the "cold start" pull out do on my MK1?
« Reply #1 on: July 21, 2009, 07:19:21 pm »
It advances the timing. It only has an effect up to about 2000 RPM (depending on your pump and it's condition)
It will have NO effect at cruising speeds
Reply #2July 21, 2009, 07:58:09 pm
lovinthedeez
  • 489
« Reply #2 on: July 21, 2009, 07:58:09 pm »
omfg ;D.  cold start is actually german for "fast mode" :-X
Reply #3July 21, 2009, 09:43:48 pm
« Reply #3 on: July 21, 2009, 09:43:48 pm »
has no affect at cruising speed? if i leave it pulled and i drive around after its warmed up, it takes a little longer for the turbo to light and it seems like it takes some of the quick away.
Reply #4July 21, 2009, 09:52:33 pm
« Reply #4 on: July 21, 2009, 09:52:33 pm »
Correct.  The cold start handle moves the timing piston slightly, but by around 2000 RPM the piston is already moving on its own (due to increased internal pump pressure... aka "dynamic" advance) past where the cold start lever has pushed it.
Reply #5July 21, 2009, 10:45:45 pm
« Reply #5 on: July 21, 2009, 10:45:45 pm »
Makes perfect sense once you see the inside of a pump.
Reply #6July 22, 2009, 07:14:11 am
Pre95
  • 81
« Reply #6 on: July 22, 2009, 07:14:11 am »
Hmmmm... this has me thinking my dynamic advance isn't functioning properly? Or possibly my pump timing is off a bit?
Reply #7July 22, 2009, 07:34:29 am
« Reply #7 on: July 22, 2009, 07:34:29 am »
.. Or possibly my pump timing is off a bit?
Ding!  Winner.  :)
Reply #8July 22, 2009, 10:09:28 am
Pre95
  • 81
« Reply #8 on: July 22, 2009, 10:09:28 am »
Ding!  Winner.  :)
Well SOB... I just had the timing belt & tensioner done but I am sure they locked in the timing where it stood instead of checking if it was all proper. Well, at least I know where the fault is....  Any easy way of setting the pump timing (not involving going full TDC on the motor, removing the valve cover, using a dial indicator, etc etc etc)?
« Last Edit: July 22, 2009, 10:17:01 am by Pre95 »
Reply #9July 22, 2009, 11:23:52 am
« Reply #9 on: July 22, 2009, 11:23:52 am »
If your dynamic advance was far enough out of wack for the knob to affect it cruising it would run really bad, the cold start knob only changes the timing at idle and slightly above idle. If you have zero internal pressure at all rpm then the knob would change the timing at all rpm.
Reply #10July 22, 2009, 09:00:20 pm
Rabbit TD
  • 840
« Reply #10 on: July 22, 2009, 09:00:20 pm »
As rabbitman just mentioned, IF your cold start does affect the performance at cruising RPMs then it points to either internal pump problems or poor adjustment.  On the upside, when properly functioning and adjusted, there should be significant gains in both performance and economy.  I would start by checking and adjusting internal pump pressure.
Andrew
How do you actualy check and adjust the internal pump pressure anyway.  I know there is a pressure regulator in there but have no idea how it works or is adjusted or even if it's possible.  Or is this one of those things that has to be done on the expensive test stand?
« Last Edit: July 22, 2009, 09:06:28 pm by Rabbit TD »
Reply #11July 22, 2009, 10:03:38 pm
« Reply #11 on: July 22, 2009, 10:03:38 pm »
When www.vwdieselparts.com is back up have a peek there... there's an entire thread on internal pump pressure... you measure it with an oil pressure gauge and adjust it with a hammer. ;)
I'd post the link but the site is down at the moment... usually comes back quick.
EDIT: here's the link: http://www.vwdieselparts.com/forum/viewtopic.php?t=5936&sid=76b741e42d5a2e19b2a8d6df2c2b9976
« Last Edit: July 22, 2009, 10:55:44 pm by Vincent Waldon »
Reply #12July 23, 2009, 07:47:43 am
Pre95
  • 81
« Reply #12 on: July 23, 2009, 07:47:43 am »
Ok well after some tooling around and test driving I guess it really doesnt effect much @ cruising speed. It does seem to handle the up-hill struggles a little better but for now she is tuned at a comfortable level, with minimal smoke. For now I will leave well enough alone, I am not going to put much of anything else in to the 1.6 N/A as I have gotten the green light from the misses to start sourcing a 1Z TDI swap. More on that later...
