General Information
General
kaputtwagen 1982 rabbit AAZ swap/build
Pages:
12
13
14
15
16
Topic: kaputtwagen 1982 rabbit AAZ swap/build (Read 133130 times)
Reply #210
September 03, 2017, 05:40:53 pm
Moderator
4552
Re: kaputtwagen 1982 rabbit AAZ swap/build
Reply #210 on:
September 03, 2017, 05:40:53 pm »
You should spend 15 mins on that fan cleaning it up, it would love to move more air for you if you did.
Reply #211
September 17, 2017, 04:28:30 pm
jack's lack
Reply #211 on:
September 17, 2017, 04:28:30 pm »
The entire garage could use a cleaning, but the king of fans is still blowing strong.
I finished sanding the inside of the passenger door and got it primed today. 2 down, 2 to go.
Last Edit: September 17, 2017, 04:48:56 pm by jack's lack
1982 Rabbit diesel L 4 door
AAZ, K14, Giles pump, PD150 intake, P&P'd head, ceramic coated pistons, 2.5" stainless down pipe & exhaust. FK coils
My Build Thread
Reply #212
September 17, 2017, 06:51:04 pm
srgtlord
Reply #212 on:
September 17, 2017, 06:51:04 pm »
This is giving me crazy ideas to go weld up all the holes in the caddy sitting in my cousin's field
Reply #213
November 05, 2017, 12:24:33 pm
jack's lack
Reply #213 on:
November 05, 2017, 12:24:33 pm »
Got the drivers door painted. One more to go!
My Build Thread
Reply #214
November 11, 2017, 07:31:37 pm
jack's lack
Reply #214 on:
November 11, 2017, 07:31:37 pm »
Getting closer on the last door. I️ just need it back above 40 for a few days to get it primed.
My Build Thread
Reply #215
November 11, 2017, 09:20:13 pm
Moderator
4552
Reply #215 on:
November 11, 2017, 09:20:13 pm »
With the NE getting a new cold front coming this weekend I don't think you will be spraying for awhile. But what has been done so far is just fantastic. Keep going when the weather lets up.
Reply #216
November 15, 2017, 05:48:21 pm
jack's lack
Reply #216 on:
November 15, 2017, 05:48:21 pm »
Thanks for the encouragement! It was a bit warmer tonight, and I managed to get the last door primed.
There is almost no trace of the diamond silver metallic left. I started cleaning up the under carriage. I’m glad that this phase is nearly over and I’m looking forward to getting on to the blocking.
My Build Thread
Reply #217
November 21, 2017, 04:34:44 am
beichMTDI
Newbie
Reply #217 on:
November 21, 2017, 04:34:44 am »
Looking really good man! Little here, little there. Keep it up! Enjoying the updates!
1982 Mk1 4 door 1.6 IDI 4 speed, all stock, daily driver.
1981 Mk1 2 door project car soon to be MTDI (ALH)
Build Blog:
https://beichmtdi.wordpress.com/
Reply #218
August 01, 2018, 07:30:12 pm
jack's lack
Reply #218 on:
August 01, 2018, 07:30:12 pm »
Winter and professional obligations aside, I’m back at my favorite hobby. I have continued to work on the undercarriage, and tonight I got the first coat of POR 15 on the fore section.
My Build Thread
Reply #219
August 01, 2018, 08:20:21 pm
Moderator
4552
Reply #219 on:
August 01, 2018, 08:20:21 pm »
We will all be driving our rust buckets to your door shortly.
Reply #220
August 06, 2018, 07:57:36 pm
jack's lack
Reply #220 on:
August 06, 2018, 07:57:36 pm »
It’s not all good news. There is substantial rust damage above where the swing arm bolts to the passenger side. I’m just gonna take repair one step at a time. I doubt i could make it worse. On the plus side, this explains the crazy shim I had to make to get this tire to align.
My Build Thread
Reply #221
August 07, 2018, 08:20:54 am
Reply #221 on:
August 07, 2018, 08:20:54 am »
Oooo, that's some ugliness. I'm sure you will get it sorted better than ever, though.
Reply #222
August 21, 2018, 04:59:22 am
jack's lack
Reply #222 on:
August 21, 2018, 04:59:22 am »
I’ve made some progress with the repair. I cut out the worst rectilinear area of the underlying tube support and welded in a 16 gauge plate and then ground it smooth. What remains of the light gauge unibody metal that wrapped it is still a mess. I am debating patching it with another 16 gauge plate to add some strength. I can blend it back in without making it too ugly. No one will ever be able to see it anyway.
My Build Thread
Reply #223
October 21, 2018, 10:25:30 am
jack's lack
Reply #223 on:
October 21, 2018, 10:25:30 am »
I’ve made significant progress recently, but haven’t posted because the Tapatalk app wasn’t ready for the new iPhone. Seems that has been addressed with the new update so here goes:
I finished the repairs on the frame rail.
Then I finished removing the rubberized waterproofing from the undercarriage. There is still some in the photo, but I have since removed the remainder.
Then I painted the remainder of the undercarriage with POR15.
I have since cleaned the car and started with the high-build primer filler. I am using Evercoat Superbuild 4:1. This stuff is way harder to work with than any paint I have ever used. Firstly, it is incredibly thick, and very sticky. It smells just like polyester resin like body filler. It had settled so much that it took me 90 minutes to stir it up. I have since bought one of those mixers that goes on a drill. The directions said that you can clean it with acetone, but this was not the case. I have since purchased a gallon of lacquer thinner. You can’t just throw a little in the mixing cup and wipe it out with a shop towel. I am going through shop towels at a record pace. Also with a 4:1 the little 8oz mixing cup only makes 5oz of paint, which does not get very far, so I grabbed a quart size that will mix 20oz a batch. So far I have only hit the front inner fenders and valance. I have been super busy at work and haven’t had time to sneak a few hours for garage time in the last couple weeks, but I am excited to post progress when I do.
My Build Thread
Reply #224
October 21, 2018, 11:15:32 am
Moderator
4552
Reply #224 on:
October 21, 2018, 11:15:32 am »
The Great Work continues. On that primer, do you find that you have to have a large tip opening on the gun to spray it or do you thin it down more than recommended to get it to come out and lay flat. I was trying to use a 1.5 mm tip with some primer/surfacer and never got the mixture right to suit my environment. Which is cold and foggy today. Other times I tried where it was super hot, 98, and dry. I just couldn't correct with the reducer at hand.
I now own a better HVLP gun capable of painting latex paint, a 2.5 mm tip. If that doesn't handle the thicker paint I don't know what to use. Mabe a roller and then just sand it more?
NOT
Pages:
12
13
14
15
16
General Information
General
