General Information
General
kaputtwagen 1982 rabbit AAZ swap/build
Pages:
8
9
10
11
12
13
14
15
16
Topic: kaputtwagen 1982 rabbit AAZ swap/build (Read 133220 times)
Reply #150
September 14, 2016, 09:39:36 am
jack's lack
Reply #150 on:
September 14, 2016, 09:39:36 am »
On to the rain tray shaving.
welded a panel in
Then started filling and sanding again.
There was a nasty hole that rusted through the inner fender, and the firewall. Wasn't an easy place to get fingers to work either.
heat delete! No turning back now!
cleaned up inner fender. Wow that was too much work.
Epoxy primed the inner fenders. The first of a lot to come.
Engine bay cleaned up and ready for primer.
Freshly primed.
Last Edit: July 16, 2017, 07:32:28 pm by jack's lack
1982 Rabbit diesel L 4 door
AAZ, K14, Giles pump, PD150 intake, P&P'd head, ceramic coated pistons, 2.5" stainless down pipe & exhaust. FK coils
My Build Thread
Reply #151
September 14, 2016, 09:45:11 am
jack's lack
Reply #151 on:
September 14, 2016, 09:45:11 am »
On to the cowling A-Pillars & Roof.
Finally sanded! Again more time consuming than expected.
And the payoff. Wet paint action!
Here it has cured.
Last Edit: July 16, 2017, 01:59:03 pm by jack's lack
My Build Thread
Reply #152
September 14, 2016, 09:47:25 am
jack's lack
Reply #152 on:
September 14, 2016, 09:47:25 am »
Next up C-pillars and rockers.
First up shaving the rear repeaters.
cleaning up the rocker.
cleaning up the rear fender wells
check out my sweet new wheel
getting the passenger side C ready for paint
here is the only major floor board issue that I found. It was directly under the hole in the firewall/raintray. A real "there's yer problem moment.
There was a fair amount of cancer in front of and behind both rear fender wells.
There was also some black waterproofing gunk applied all around the car. I wonder if the previous owner did this, or something offered by the stealership. You're gonna want that true-coat!
Filling the dents. Apparently quite a few people opened doors into me.
filled the trim holes and smoothed the panel seam below
grabbed some gas piston hood openers, so went ahead and deleted the brackets for the old stick. I'm gonna miss that stick. We spent a lot of time together over the years.
primer gray potential is finally setting in.
On to the driver's side. Sand fill repeat. I can hear the air compressor droning away in my dreams.
and more cured primer
On to the back
had some real issues behind the wheel wells. Especially at the exhaust cut out.
stitched in a panel. Clearly I am yet to become an expert. I am thankful for kevlar strand body filler.
Started the POR 15 in the spare tire well. Found a couple more rust holes to weld before finishing up, hence the unpainted spots.
Lightweight fill ready to sand. I have since sanded it and will prime tomorrow after work if all goes well. Then it's on to doors and fenders. There is a light at the end of the tunnel, but it is still faint.
also in other news I scored a little piece of Unobtainium!
Last Edit: July 16, 2017, 10:56:18 am by jack's lack
My Build Thread
Reply #153
September 17, 2016, 05:16:44 am
jack's lack
Reply #153 on:
September 17, 2016, 05:16:44 am »
Oh my gosh, look at her butt!
Last Edit: July 15, 2017, 12:58:43 pm by jack's lack
My Build Thread
Reply #154
September 18, 2016, 12:42:59 pm
jack's lack
Reply #154 on:
September 18, 2016, 12:42:59 pm »
Spent 4 hours stripping the paint off of the outside of one of the doors.
Last Edit: July 15, 2017, 12:25:06 pm by jack's lack
My Build Thread
Reply #155
September 19, 2016, 08:40:10 am
Re: kaputtwagen 1982 rabbit AAZ swap/build
Reply #155 on:
September 19, 2016, 08:40:10 am »
Lots of work. Very impressive.
Reply #156
September 19, 2016, 07:36:09 pm
jack's lack
Reply #156 on:
September 19, 2016, 07:36:09 pm »
Put in another 2:30 today. Sanded the door with 80grit. Pulled a dent and welded some pin holes in the bottom aft corner.
Finished up the evening with some Everglass filler (not pictured). A couple more hours and this one will be ready to prime. I will tackle the jamb and interior of the door at a later pass, but regardless this has been the quickest panel by far.
Last Edit: July 15, 2017, 12:22:16 pm by jack's lack
My Build Thread
Reply #157
September 23, 2016, 07:25:40 pm
jack's lack
Reply #157 on:
September 23, 2016, 07:25:40 pm »
320 grit sanded here and ready for paint.
Und mit primer
The gloss of the wet paint highlighted a couple more little dings. I'll catch them in the next round.
Last Edit: July 15, 2017, 12:04:31 pm by jack's lack
My Build Thread
Reply #158
September 26, 2016, 07:55:56 pm
jack's lack
Reply #158 on:
September 26, 2016, 07:55:56 pm »
Today's progress
Last Edit: July 15, 2017, 11:55:24 am by jack's lack
My Build Thread
Reply #159
September 30, 2016, 08:58:30 pm
jack's lack
Reply #159 on:
September 30, 2016, 08:58:30 pm »
Sanded to 320
Primered
Last Edit: July 15, 2017, 10:50:10 am by jack's lack
My Build Thread
Reply #160
October 20, 2016, 06:56:54 pm
jack's lack
Reply #160 on:
October 20, 2016, 06:56:54 pm »
On to the next door. The passenger doors were not this car's good side. I found some evidence of previous repairs and a really large dent. It took quite a bit of filling and blocking to get it smooth. This was the most difficult panel yet.
Last Edit: July 15, 2017, 10:45:40 am by jack's lack
My Build Thread
Reply #161
October 23, 2016, 09:39:25 am
jack's lack
Reply #161 on:
October 23, 2016, 09:39:25 am »
got the dents at the aft of the passenger door as flat as I could with a hammer, dolly, and slide hammer.
And with the everglass filler. Hopefully I can carve out some time to block it and move on to lightweight filler this week.
Last Edit: July 15, 2017, 10:39:06 am by jack's lack
My Build Thread
Reply #162
October 25, 2016, 09:09:28 pm
Reply #162 on:
October 25, 2016, 09:09:28 pm »
Again, very impressive. Thanks for sharing.
Reply #163
October 25, 2016, 09:50:10 pm
Moderator
4552
Reply #163 on:
October 25, 2016, 09:50:10 pm »
Someone with a lot of dedication and time to do the kind of work we all would like to do but are too busy with our engines all the time.
Reply #164
October 28, 2016, 06:00:00 pm
jack's lack
Reply #164 on:
October 28, 2016, 06:00:00 pm »
Thanks for the encouraging words. I think that I started down this road grossly underestimating how much time it would actually take. At this point I'm just taking it one panel at a time.
Regarding the current panel, I was hoping to prime it today, but the dent needed yet alas at least one more layer of rage gold was required.
Last Edit: July 15, 2017, 10:34:48 am by jack's lack
My Build Thread
Pages:
8
9
10
11
12
13
14
15
16
General Information
General
