Author Topic: Miles to a full tank VW Passat.  (Read 8454 times)
September 16, 2005, 09:48:15 am
TD Passat
  • 29
« on: September 16, 2005, 09:48:15 am »
How many miles will i get to the 70Litre tank in my passat?
Just everyday driving.
Craig
Tips and info required for tuning 94 Passat Turbo diesel.
Reply #1September 17, 2005, 04:27:51 pm
Giles@PerformanceDiesel
  • 221
    • http://www.performancediesel.ca
miles per tank
« Reply #1 on: September 17, 2005, 04:27:51 pm »
hi
after i did a pump for Chris, his passat got a whopping 1150 km for
one tank of fuel, i think it was 68 liters.
Giles
before my super pump he didn't get this kinda mileage.
Reply #2September 17, 2005, 09:48:25 pm
commuter boy
  • 277
« Reply #2 on: September 17, 2005, 09:48:25 pm »
Did you modify the pump specificly for mileage, or was it the standard power up magic you do?
Reply #3September 18, 2005, 02:06:00 am
  • 221
mileage or power
« Reply #3 on: September 18, 2005, 02:06:00 am »
yes i did my full magic on his pump which made a big diff
he got the better mileage when he didn't have to push his car
as much to go the same speed as before.
Giles
Reply #4September 18, 2005, 09:35:14 am
Mark(The Miser)UK
  • 1557
Re: miles per tank
« Reply #4 on: September 18, 2005, 09:35:14 am »
Quote from: "Giles@superiorFuelInj"
hi
Giles
Whats that? 1150/68 =16.9..A/C as well?
My Quantum just did 988 km to 52.5 litres  or 18.8km/litre This was 2/3 town driving.
 Best ever run was 21.1km/ litre No A/C  :evil:
Mark-The-Miser-UK
Reply #5September 18, 2005, 10:36:16 pm
RAMMSTEIN
  • 331
« Reply #5 on: September 18, 2005, 10:36:16 pm »
You have an Estate or a limousine TDpassat?
What kind of diesel you got in there?
AAZ or 1Z?
On my passat variant I do no less than 1000 miles per tank and as much as 1400 miles.
I drive for it, but I get results too. :D
95 litres tank comes standard on variants. :twisted:
Rammstein
In abscence of light, darkness prevails.
Reply #6September 18, 2005, 11:26:12 pm
TD Passat
  • 29
« Reply #6 on: September 18, 2005, 11:26:12 pm »
Its a 1994 1.9 TD Saloon. Fuel gauge indicates 70litres.
Craig
Reply #7September 24, 2005, 09:39:29 pm
RAMMSTEIN
  • 331
« Reply #7 on: September 24, 2005, 09:39:29 pm »
At 47 mpg (imperial gallons, or 6 litres per 100 km) you should at least get 700 miles per tank.
I've heard AAZ engine getting in the low 5's so 900 miles to the tank.
Rammstein
Reply #8September 25, 2005, 05:57:07 am
  • 221
Info on Chris' car
« Reply #8 on: September 25, 2005, 05:57:07 am »
his car is a AAZ Pasat
we did a full upgrade on the pump, changed the turbo to the bigger
unit from 1.6L and added an intercooler.
we dynoed his car at 100 HP at the wheels.
he drives about 50:50 hwy and city. hwy does 120 Km/Hr
city is mostly sitting in traffice
Toronto is really bad right now.
Giles
Reply #9September 25, 2005, 10:36:08 pm
vixentd
  • 88
pump
« Reply #9 on: September 25, 2005, 10:36:08 pm »
what kind of charge is there for doing a pump? Does the turbo also have to be changed?
Reply #10September 26, 2005, 11:49:30 am
TD Passat
  • 29
« Reply #10 on: September 26, 2005, 11:49:30 am »
I find my turbo spinning nearly all the time. Sitting at 70mph constant in 5th it is boosting to 10psi. If i back off the boost drops but the car starts to slow down.
In my other turbo'd car i can back off so the boost drops below the 0psi mark but stays at a constant speed. Like a N/a engine.
Any tips on stopping it running boost all the time? Is there a mod so i can run the boost when i need it. ie accelerating.
Craig
Reply #11September 26, 2005, 03:22:16 pm
  • 1156
    • Malone Tuning Ltd.
« Reply #11 on: September 26, 2005, 03:22:16 pm »
Quote from: "TD Passat"
1) Do you have a factory switch on the pump that opens when the throttle lever (also on the pump) is in idle/neutral position? Wire that switch to a boost solenoid running to your wastegate.
This way the solenoid will always stay open to bleed boost to wastegate until you press the accelerator pedal. Pressing the accelerator pedal will pull the throttle lever on the pump away from the switch (at least 5-10% or wherever you want to adjust it).
You can use the solenoid as a regular boost controller too.
2) Just install a $1 switch on your dashboard and wire it straight to the boost solenoid. Manually flick the switch on when you don't want boost. Might be convenient for long highway drives, but it would otherwise be annoying having to flick it on and off constantly.
... or you can use the in-dashboard switch to activate the throttle switch on your fuel pump. Adjust the switch on the pump to prevent boost if you press the accelerator pedal to within 40% for example. Turn it off if you're in strictly city driving.
3) Larger turbo.
http://www.tunezilla.com
93 Eurovan AHU TDI
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Reply #12September 26, 2005, 06:40:24 pm
  • 221
pump price
« Reply #12 on: September 26, 2005, 06:40:24 pm »
hi all
i charge $950 Can for a full performance upgrade/rebuild
Giles
Reply #13September 26, 2005, 06:42:28 pm
  • 221
Turbo boost problem
« Reply #13 on: September 26, 2005, 06:42:28 pm »
hi
u said that your other turbo'ed motor doesn't spin up boost on the hwy
what motor is that?
the reason your diesel pushes  boost all the time is because the engine
needs the boost to run at the throttle/speed that you're doing.
Giles
Reply #14September 27, 2005, 11:28:35 am
TD Passat
  • 29
« Reply #14 on: September 27, 2005, 11:28:35 am »
My other car is a Mk3 Astra Turbo with around 360PS. It is quick!!!
Still running as standard on the TD.
Craig
