VWDiesel Blog
Facebook Group
VWD on Twitter
TDI Engine -General Info
01 Golf wont start
Topic: 01 Golf wont start (Read 3679 times)
July 15, 2009, 12:16:36 am
tindias
01 Golf wont start
July 15, 2009, 12:16:36 am »
The strangest thing happended the other day. I went to the store and my TDI was running just fine. When I came back it would not start. I tried many times till the battery died on me, then I got a buddy to tow me home. When I was trying to start it some white smoke was coming out of the tail pipe when i had it floored, but it will not fire. When I cracked the fuel lines there was no fuel. I am going to throw the battery on the charger, but does anyone have any ideas?
'87 16v Scirocco w/ direct port nitrous
'81 Supercharged 1.6 Diesel Caddie
http://www.youtube.com/watch?v=XSAcDXLiCCk
'01 TDI Golf (daily driver)
July 15, 2009, 12:00:45 pm
tindias
Re: 01 Golf wont start
July 15, 2009, 12:00:45 pm »
Could my fuel lines have a leak? I will have to check the filter line to make sure there is diesel in there. It has about 160k miles on it, I hope its not the IP.
July 15, 2009, 12:32:29 pm
tindias
July 15, 2009, 12:32:29 pm »
State
July 15, 2009, 01:36:11 pm
tindias
July 15, 2009, 01:36:11 pm »
Ok, I will start at the filter and start looking at the lines. You dont think its the IP do you? Would hope it wouldnt be leaking, have not seen any diesel pooling up anywhere.
July 16, 2009, 11:56:13 pm
tindias
July 16, 2009, 11:56:13 pm »
The plot thickens. My glow plug light is flashing now, car still wont start. Didnt find any air leaks. Really dont know what to do now.
July 17, 2009, 01:29:04 am
July 17, 2009, 01:29:04 am »
If the glow plug light is flashing it's probably throwing a code or two... perhaps get the codes read to see if they offer any clues?
Unfortunately the flashing glow plug light is used to signal many different faults.
July 19, 2009, 10:53:20 pm
tindias
July 19, 2009, 10:53:20 pm »
Updates- Need a new brake light switch for sure. Glow plugs come on for 2 secs and then off, if I unplug the coolant sensor they will stay on. Glow plug fuse and bus all have 13v, glow plugs have .9 ohms. Getting fuel to injectors and stop solenoid is working. ASV is open and I charged to battery up so it cranks at a good speed. I am getting lots of white smoke, enough to sting my eyes. THe car will sputter a bit if I feather the pedal, but wont fire up. Its about 70 degrees where I am at so I am not sure what is going on.
July 22, 2009, 09:52:12 am
tindias
July 22, 2009, 09:52:12 am »
I am starting to think that could be it. I inspected the timing belt and there is a portion in the middle of the belt that has been damaged. I have ordered Vag-com and a new belt, should be here next week. I really hope it just jumped a tooth and needs to be retimed.
July 22, 2009, 11:39:14 pm
diesel smoke
July 22, 2009, 11:39:14 pm »
Is the anti shudder valve stuck shut?
'99.5 Bora TD
I
'88 Fox Coupe
'71 Tin Top Westfalia Bus
'85 Mercedes 300SD
01 Golf wont start
