Author Topic: Found the leak now can't get to it...  (Read 2584 times)
July 11, 2009, 11:05:18 pm
kibs45
  • 46
« on: July 11, 2009, 11:05:18 pm »
Has anyone seen this setup but with a security head instead of a nut and a washer?  Mine has a goofy thing I can't get off, its completely round, with two notches out of it.  Kind of makes replacing the seal difficult.  I will try and get a picture but anyone with experience with how to get it off please let me know!
Reply #1July 12, 2009, 01:41:58 am
Re: Found the leak now can't get to it...
« Reply #1 on: July 12, 2009, 01:41:58 am »
I use a punch and a hammer. IIRC it's backward threads.
Reply #2July 12, 2009, 04:52:26 am
Patrick
  • 1034
« Reply #2 on: July 12, 2009, 04:52:26 am »
Sounds like it's supposed to use the same kind of tool as a front strut mount. Wouldn't happen to be the same size would it?
Reply #3July 12, 2009, 08:03:15 pm
« Reply #3 on: July 12, 2009, 08:03:15 pm »
You're asking for trouble if you plan to remove that shaft without taking the lid off the pump.
Reply #4July 13, 2009, 12:31:39 am
« Reply #4 on: July 13, 2009, 12:31:39 am »
X2
Reply #5July 13, 2009, 07:04:26 am
Pre95
  • 81
« Reply #5 on: July 13, 2009, 07:04:26 am »
X2
X3
81 Rabbit Diesel - 250k and climbing :)
Reply #6July 13, 2009, 09:47:37 am
kibs45
  • 46
« Reply #6 on: July 13, 2009, 09:47:37 am »
I know it holds things in place inside the pump, just need to replace the o-ring.  By the way both of the threads with the safety lock are reverse.
