Install input shaft seal dry or wet?
Topic: Install input shaft seal dry or wet? (Read 2586 times)
July 10, 2009, 09:36:10 pm
kibs45
User+
July 10, 2009, 09:36:10 pm »
Bosch VE. I can't remember if the seal is installed wet or dry...grrrrr. Thanks in advance!
July 11, 2009, 05:42:18 am
92EcoDiesel Jetta
Re: Install input shaft seal dry or wet?
July 11, 2009, 05:42:18 am »
I recall reading somewhere that you want to lubricate the seal with a bit of vaseline to make the seal go in easier.
July 11, 2009, 10:29:47 am
July 11, 2009, 10:29:47 am »
Are you talking about the OD or ID? For the ID I would use oil, diesel, ATF or whatever.
It might be good to use permatex on the OD.
July 11, 2009, 05:58:17 pm
Rabbit TD
July 11, 2009, 05:58:17 pm »
Quote from: kibs45 on July 10, 2009, 09:36:10 pm
Any seal should have the correspoding shaft or whatever part that is being sealed lubricated first and I like to take some fine sandpaper and polish the area the seal rides on also if possible.
July 12, 2009, 11:59:01 am
July 12, 2009, 11:59:01 am »
i always lubricate a seal before i install it. kinda seems like the lube glues the seal in after the rubber absorbs the lubricant.
