Tack just stopped working
Topic: Tack just stopped working (Read 2836 times)
July 04, 2009, 10:03:54 pm
91jettaidi
July 04, 2009, 10:03:54 pm »
Hey guys my tach stopped working one day and when ever i drive in the rain it some times works but i hear a squeal(like a belt)but i don't know what it is.
July 04, 2009, 10:14:11 pm
rallydiesel
Re: Tack just stopped working
July 04, 2009, 10:14:11 pm »
Sounds like you have a problem at the w terminal on your alternator. Be careful if it is loose because you could blow a bunch of stuff. My w terminal shorted against the alternator housing and blew my radio fuse, wrecked my tach and junked my alternator. Not fun.
1991 Jetta TD - sold
2001 Golf TDI - Son's
July 04, 2009, 10:17:41 pm
91jettaidi
July 04, 2009, 10:17:41 pm »
so i should just tighten all the wires on my alternator
July 04, 2009, 10:18:06 pm
July 04, 2009, 10:18:06 pm »
As well, loose alternator belt = slips when wet = makes a squealing noise = wonky tach operation.
July 04, 2009, 10:19:48 pm
91jettaidi
July 04, 2009, 10:19:48 pm »
ya i tightened my belt but. . .it seems only in the rain it wanted to work some times but where is that terminal on the alternator? should i take it out and clean it a bit? and retighten it.
July 04, 2009, 11:07:29 pm
rallydiesel
July 04, 2009, 11:07:29 pm »
There will be one wire going into the alternator with a quick connect joint. That is the w terminal which is what your tach uses to determine rpm. There is really no way to tighten it. Just make sure it is not contacting the actual alternator housing. That's just one possibility of why your tach isn't working.
