Author Topic: Well, that was a letdown....  (Read 6924 times)
Reply #15July 04, 2009, 03:58:07 pm
westcoaster
Re: Well, that was a letdown....
« Reply #15 on: July 04, 2009, 03:58:07 pm »
Change in tactic....
So the block is trash, that is plain to see. I had the head in for a pressure test and they told me it was leaking between intake and exhaust on one cylinder. I opted to simply toss it back on the block with a new gasket anyway.
This really is a "nothing to lose" engine....
I would like to be able to get another half dozen or so tanks of diesel through this before I pull it for a long block. I also need to solve my cooling issues and ensure the rad I have will keep things cool.
Drilling the ends of the crack to keep things from travelling is a start. grove the crack and fill with?
So, let's hear your bootyfab solutions to seal this thing up and get it running again. I'm not done blowing this one up yet....
'87 suzuki samurai with a 1.9 AAZ TD transplant
Reply #16July 04, 2009, 04:02:05 pm
Zulfiqar
  • 254
« Reply #16 on: July 04, 2009, 04:02:05 pm »
that is bad - it can be repaired tho - find someone who really knows how to weld cast iron, its a very finicky process
usually caused by overtensioned headbolts not tightened in the correct sequence - it can also be caused by blocked headgasket passages..
when I replaced my headgasket - which btw was the original factory VW gasket, the coolant holes on cyls 3 and 4 were larger while on cyls 1 and 2 were smaller, makes sense coz the pump is running just south of cylinder 1 - its got loads of coolant flow available immediately cyl 4 doesnt.
I always make sure to enlarge the coolant holes for cyl3 and 4 in new head gaskets
Diesel IS the future
Reply #17July 04, 2009, 04:49:24 pm
lovinthedeez
  • 489
« Reply #17 on: July 04, 2009, 04:49:24 pm »
just wonderin', what is the bolt hole that the crack goes through hold on; the injection pump bracket?  makes you wonder which bolt was torqued too much, the cylinder head bolt or that one.  either way, that sucks.  good luck.... :)
Reply #18July 04, 2009, 05:10:15 pm
westcoaster
« Reply #18 on: July 04, 2009, 05:10:15 pm »
It's a double nut thing that holds on the IP bracket and the one bolt for the timing belt cover.
Reply #19July 04, 2009, 05:30:54 pm
53 willys
« Reply #19 on: July 04, 2009, 05:30:54 pm »
your better off with a different block all together imho...thats a really bad crack that will take lots of work to "fix" and even then your asking for trouble.
seems like it would be money..time and headache ahead if you found a new engine.
if you do run it please report back :P ;D
if that crack goes to the Head gasket surface then I cant see how you could stop any leaks for very long.........
Reply #20July 05, 2009, 04:00:13 am
« Reply #20 on: July 05, 2009, 04:00:13 am »
If you have compression in that cylinder I'd channel out the crack a bit, fill it with JB weld and then run that coolant that doesn't require any pressure. Evans perhaps? I would not use that "double nut" bolt hole though.
I'd recommend a leak down test on that cylinder to see if combustion gasses are getting into the oil or coolant.
Reply #21July 05, 2009, 08:42:59 am
westcoaster
« Reply #21 on: July 05, 2009, 08:42:59 am »
Well, I have nothing to lose and everything to gain by trying that.
None of the parts I have bought can be re used on a new engine so I might as well get some use out of them..... :'(
edit:
I will need to install that "double nut" thing back in the block with gobs of permatex sealant on it to keep any leaks from dribbling out of the hole...
« Last Edit: July 05, 2009, 08:46:37 am by westcoaster »
Reply #22July 05, 2009, 11:11:27 am
maxfax
  • 2126
« Reply #22 on: July 05, 2009, 11:11:27 am »
Dang!
If it weren't for having to pull the head again, I'd grind it out and fill it with brass..   Old school head and block repair from back in the day, but it worked rather well...   Trouble is you're gonna have to get it hot and probably end up damaging the HG...
Reply #23July 05, 2009, 03:37:11 pm
  • 3468
    • McScrubbins Body Wash
« Reply #23 on: July 05, 2009, 03:37:11 pm »
could always weld the crack with the head off and grit your teeth?
Reply #24July 05, 2009, 06:39:17 pm
Dean Erickson
  • 58
« Reply #24 on: July 05, 2009, 06:39:17 pm »
I had to spot weld a ring grear on my two cylinder JD 70 flywheel. I used my arc welder with nickel rod. Worked great. Might work for the block.
Reply #25July 05, 2009, 07:33:09 pm
westcoaster
« Reply #25 on: July 05, 2009, 07:33:09 pm »
Oh, Yeah!
This is going to be booty fantastic (if it holds for very long....)
Ground out the crack a little with a rotary file.
Mixed up some JB weld and applied to the cracks.
Permatex form-a-gasket between the IP bracket and the block. Stuffed some permatex down the hole (not enough no doubt) applied a liberal ammount to the threads on the "double nut" and screwed that in without cranking it down too tight.
It'll more than likely still leak a little. At least it won't be gushing out without any pressure in the system like it was before.
Reply #26July 05, 2009, 07:34:51 pm
« Reply #26 on: July 05, 2009, 07:34:51 pm »
Switch to a coolant that doesn't require pressure. I'm pretty sure it's called Evans coolant
Reply #27July 05, 2009, 07:41:30 pm
92EcoDiesel Jetta
« Reply #27 on: July 05, 2009, 07:41:30 pm »
It's expensive sh*t though. Over $30 a gal and you may need to buy extra sh*t to wash out the system so it's gonna be a lot of dough. ::)
Reply #28July 09, 2009, 09:18:54 am
« Reply #28 on: July 09, 2009, 09:18:54 am »
i bet you, or the previous owner cracked it from torquing the head. or it could be from tons of boost. is this a turbo engine? on my first 1.5D, i cracked 7 out of the 10 threaded holes in the deck of the block. but over 30psi didnt help that situation out any.
Reply #29July 09, 2009, 03:38:10 pm
« Reply #29 on: July 09, 2009, 03:38:10 pm »
Garden hose, and some Dawn dish soap from your local General store. Great for washing out the system trust me :P lol
