Author Topic: Newbie question: Is your diesel more 'cackly' when cold apposed to warm?  (Read 4768 times)
July 01, 2009, 10:02:21 pm
Pre95
  • 81
I swear when I fire my diesel off in the morning or when it's cold in general the cackle almost sounds like a rod knocking or something (enough that I have brought out the mechanic stethoscope, only to find it's coming from the valve cover area in general) but as it warms up it smooths out and becomes less of a distinctive knock, and more of the normal cackle. Am I going crazy or something?
81 Rabbit Diesel - 250k and climbing :)
Reply #1July 01, 2009, 10:32:26 pm
It's normal for mine so I hope it's supposed to be normal :)
Reply #2July 02, 2009, 04:45:54 am
Zulfiqar
  • 254
you may have a dying lifter if you are running a hydro head
Diesel IS the future
Reply #3July 02, 2009, 07:55:37 am
Pre95
  • 81
How do I know if it's a hydro head?
Reply #4July 02, 2009, 01:16:44 pm
Zulfiqar
  • 254
there is usually a sticker on the valve cover with a cross on it meaning no settings required,
the other dead giveaway would be that the head would have a projected sections between cylinders 1 2 and 3 for hydraulic lifter head and only one projection for mechanical lifter head between cylinders 2 and 3
Reply #5July 02, 2009, 11:34:45 pm
DCC
  • 184
Checkout Tyler's post, you can see the differences between solid and hydro:
http://www.vwdiesel.net/forum/index.php?topic=16688.0
Reply #6July 03, 2009, 05:37:47 pm
jkmackenzie
  • 9
Yeah mine definitely does as well.  I've never really worried about it though, as I also thought it was normal.  Thanks for the info on hydraulic heads to guys.
'91 Jetta TD 504,000km
'05 Jetta TDI 87,000km
Reply #7July 15, 2009, 08:07:50 pm
Rabbit TD
  • 840
That's always been my objection to the hydraulic lifter engine, lifter problems, you hear so much about it on here all the time and I can't figure for the life of me why anyone wats to mess with them in the first place.
Reply #8July 17, 2009, 08:44:13 pm
very true.  i loved my '86 solid lifter 1.6TD.  sticky valves suck!  solid lifter engines also have a little bit more power too! now if only they didn't need as much maintenance...  maybe using royal purple with that Z Max stuff???  :D
