Author Topic: Wastegate on K14  (Read 3901 times)
July 01, 2009, 06:05:45 am
ilikevwdiesel
  • 1202
Wastegate on K14
« on: July 01, 2009, 06:05:45 am »
Can you adjust the wastegate on a K14? I was romping on my pickup yesterday and I could feel the wastegate open, I'd like it to stay closed a little longer. Any gurus out there with some thoughts? The motor is a US Ecodiesel, there's no blowoff valve on the intake manifold.
My Bio
Reply #1July 01, 2009, 07:35:33 am
Re: Wastegate on K14
« Reply #1 on: July 01, 2009, 07:35:33 am »
just disconnect the WG, or add a manual boost control. read the FAQ.
its in there. this is the third "how do i get more boost" thread i have read this week.
you dont need more boost for your stock fuel setting. too much boost for a certain fuel level is not good. if it smokes, adjusting your boost so it just barely smokes is about optimum boost-to-fuel levels. so unless you are gonna want more fuel and less fuel mileage, just leave it alone. you could probably get 5 more psi out of it the way it is. but you have a ECO fuel injector pump, and they are RETARDED. you could make way WAY more power with a real TD pump, they have a bigger pump head in them. if you really wanted some power, take and disconnect the wastegate, add an intercooler, some turbo injectors and a turbo pump and really have a ripper.
Reply #2July 01, 2009, 08:06:54 am
ilikevwdiesel
  • 1202
« Reply #2 on: July 01, 2009, 08:06:54 am »
I have a 1.6 TD pump on it. Guess I should have said THAT.
« Last Edit: July 01, 2009, 08:13:09 am by ilikevwdiesel »
My Bio
Reply #3July 01, 2009, 08:20:09 am
ilikevwdiesel
  • 1202
« Reply #3 on: July 01, 2009, 08:20:09 am »
The waste gate on this k14 has a threaded rod with a lock nut on it. Is that an adjustment? Will turning it one way or the other change the opening pressure of the wastegate?
My Bio
Reply #4July 01, 2009, 08:46:14 am
anto
« Reply #4 on: July 01, 2009, 08:46:14 am »
Yes loosen the locknut off and wind the threaded rod in the ways for more boost ie clockwise
Reply #5July 01, 2009, 12:26:03 pm
ilikevwdiesel
  • 1202
« Reply #5 on: July 01, 2009, 12:26:03 pm »
well I installed a boost gauge and drove the truck before attempting any adjustment on the wastegate. It went to about 12psi. After I wound the screw in it made close to 20psi. The engine is a stock 91 1.6 eco diesel US model engine with about 200k mi., except that it has a injection pump from an 84 TD motor and a 2" straight back exhaust with no muffler. Does anyone know what a safe level of boost is for a stock engine? What can they take and for how long? Thanks
My Bio
Reply #6July 01, 2009, 12:45:19 pm
« Reply #6 on: July 01, 2009, 12:45:19 pm »
My opinion: assuming you watch your engine temperatures and have a properly torqued head with a good headgasket you can probably run 20 psi all day long.
Should you decide to start adding fuel to your extra boost a pre-turbo EGT gauge is an excellent investment.
Reply #7July 01, 2009, 12:49:33 pm
ilikevwdiesel
  • 1202
« Reply #7 on: July 01, 2009, 12:49:33 pm »
Thanks Vince. I'm not going to mess with the pump it runs fine now, plenty of power for me. The headgasket looks to weeping a tiny bit of oil below the waterneck on the front of the engine. If it craps out I'll replace it and install a stud kit. Anyone know where to get the best price on a stud kit for a 1.6?
My Bio
Reply #8July 01, 2009, 06:49:24 pm
Rabbit TD
  • 840
« Reply #8 on: July 01, 2009, 06:49:24 pm »
Summit Racing 8)
