Author Topic: Turboing a N/A  (Read 6658 times)
June 30, 2009, 01:58:21 pm
SolarSteve
  • 264
Turboing a N/A
« on: June 30, 2009, 01:58:21 pm »
Will turboing a N/A motor kill it?  I know the N/A's don't have the piston skirt oil squirters, so how bad would it be?
Also, is an ECO pump the same as a N/A pump?  If I turbo my N/A and keep the same pump will it essentially be an ECO?
Thanks
Steve
91 Jetta 1.6 N/A
Reply #1June 30, 2009, 02:25:58 pm
Re: Turboing a N/A
« Reply #1 on: June 30, 2009, 02:25:58 pm »
Lots of people have turbo'd NA's, eco pumps have an 8mm plunger and NA's have 9mm so the NA will be able to pump more.
From what I've gathered here, the piston squirters are to cool the piston, if you keep the EGT's low enough you won't have to worry about it.
Reply #2June 30, 2009, 02:43:28 pm
SolarSteve
  • 264
Re: Turboing a N/A
« Reply #2 on: June 30, 2009, 02:43:28 pm »
Will it be a problem if I use any turbo larger than a stock ECO turbo?
Steve
91 Jetta 1.6 N/A
Reply #3June 30, 2009, 05:44:52 pm
Rabbit TD
  • 840
Re: Turboing a N/A
« Reply #3 on: June 30, 2009, 05:44:52 pm »
You are talking about an N/A 1.6 aren't you?  I just built a T/D 1.6 for my Rabbit and ordered a turbocharger with supposedly the next size bigger compressor wheel and it  was miserable as far as boost, barely 5 psi.  I put the old T3 on it that came on the engine originaly with 432,000 on it and it ran twice as good and I am using an N/A pump at present with it till I get the T/D pump straightenedout.  If you are goinnng to drive normaly and want a little more power the stock one is the one in my opinion to use because you can add more fuel later and increase it's boost.  If you go to one that's too big you won't have the boost the smaller one does unless you really turn up the fuel, cut your mileage in half and have nothing but smoke and high EGT's.  But it will make a bigger whine if that's of importance, to me it's not. I think my stock t3 is actualy a little big but I haven't ran it with the T/D pump other than for just a little bit and took it off for leak repairs.  I've seen 10 psi from it maxed out in 4th on a flat road, 7 on a mountain. Stay with a smaller turbo and have more low end power sooner where you need it and you will be a lot happier and especialy since you don't have the other T/D engine parts that are a little more heat resistant but will probably be fine with the smaller turbos.  Myself if somebody even gave me a brand new one bigger than a t3 I wouldn't even bother putting it on the car but I'm not looking for 150 horsepower, smoking up the whole highway and 30 mpg either.
« Last Edit: June 30, 2009, 05:48:37 pm by Rabbit TD »
Reply #4June 30, 2009, 05:55:45 pm
Rabbit TD
  • 840
Re: Turboing a N/A
« Reply #4 on: June 30, 2009, 05:55:45 pm »
You are talking about an N/A 1.6 aren't you?  I just built a T/D 1.6 for my Rabbit and ordered a turbocharger with supposedly the next size bigger compressor wheel and it  was miserable as far as boost, barely 5 psi.  I put the old T3 on it that came on the engine originaly with 432,000 on it and it ran twice as good and I am using an N/A pump at present with it till I get the T/D pump straightenedout.  If you are goinnng to drive normaly and want a little more power the stock one is the one in my opinion to use because you can add more fuel later and increase it's boost.  If you go to one that's too big you won't have the boost the smaller one does unless you really turn up the fuel, cut your mileage in half and have nothing but smoke and high EGT's.  But it will make a bigger whine if that's of importance, to me it's not. I think my stock t3 is actualy a little big but I haven't ran it with the T/D pump other than for just a little bit and took it off for leak repairs.  I've seen 10 psi from it maxed out in 4th on a flat road, 7 on a mountain. Stay with a smaller turbo and have more low end power sooner where you need it and you will be a lot happier and especialy since you don't have the other T/D engine parts that are a little more heat resistant but will probably be fine with the smaller turbos.  Myself if somebody even gave me a brand new one bigger than a t3 I wouldn't even bother putting it on the car but I'm not looking for 150 horsepower, smoking up the whole highway and 30 mpg either.  I would do a compression check first before I did anything, if it doesn't have at least 400 plus psi I'd be rebuilding the engine first before adding a turbo anyway.
Reply #5June 30, 2009, 06:07:17 pm
SolarSteve
  • 264
Re: Turboing a N/A
« Reply #5 on: June 30, 2009, 06:07:17 pm »
I am just looking for a little extra power.  My drive home takes me up some hills on the highway.  I keep the speed at about 70 MPH but even with it floored, going up these hills drops me down to 55 MPH.  I have been doing this for 2 years and if I have to I can live with but it sucks.  If I have a lot of stuff in the car or extra people it drags down even more on hills.
From the sound of what you said it seems like an ECO turbo will provide what I am looking for.  I'm not looking for 150HP, just a little extra to help me maintain 70 MPH up the hills.
Steve
91 Jetta 1.6 N/A
Reply #6June 30, 2009, 06:49:37 pm
Rabbit TD
  • 840
Re: Turboing a N/A
« Reply #6 on: June 30, 2009, 06:49:37 pm »
I know exactly what you mean there, I have 2 mountains to cross everyday and I know how it pulls you down and the smoke that it makes doing this in an N/A.  That's another plus with a turbo if it's matched right, they burn a lot cleaner, I mean way cleaner and both my N/A and T/D were both bored and rebuilt.  A stock T3 or a K14 is what I would recomend, I'd like to try the K14 if I can find one with the right flange.  The mountain is a lot of fun now, even with the N/A pump on it.  On the other N/A engine I could maintain 65 if I didn't have to let off for anything which was almost never, you know how that is.  With the new T/D engine with the old T3 and N/A pump I can hold 75 under the same conditions and don't have to worry about the fast lane at all or very seldom, there's always someone who has to go 90 or better.  You want to make sure you get an EGT gauge and make sure you don't get too high especialy since you don't have the squirters.  Since I have one in the car now and my temps are like 1,100 on the mountain and no smoke I've always wondered what they might have been with the N/A just pouring out black smoke on those pulls those other years.  But I never had a problem with that engine though and it got 52 mpg on top of it no matter how you drove it.  This one only does about 45 but does have the 155 injectors {stock T/D} and the turbo does create a little exhaust restriction  at times but it's well worth that little loss im mpg for what you gain.  The engine is a lot smoother too and actualy a lot quieter exhaust.  Mine is all stock T/D 2 in. with a Magnaflow muffler, don't worry about it being too loud, it won't be even with a $20 glass pack.
Reply #7July 01, 2009, 05:52:24 am
ilikevwdiesel
  • 1202
Re: Turboing a N/A
« Reply #7 on: July 01, 2009, 05:52:24 am »
I have a 91 Eco diesel motor in my rabbit truck. It's stock except for a 2 in straight exhaust and an 84 TD injection pump. It blasts up over the hills at 70 mph.  ;D
My Bio
Reply #8July 01, 2009, 07:56:39 am
arb
Re: Turboing a N/A
« Reply #8 on: July 01, 2009, 07:56:39 am »
I turbo'd mine with a new GT15 turbo. Its really small, but does a great job of giving me up to 10 psi (4 - 5 typical at 75 mph), allowed me to haul a large pop-up camper up some rather high hills with the caravan (where I put my 1.6L diesel) loaded with people and stuff, get better mpg, and I have zero smoke (un-burned diesel fuel) except for a few moments at cold startup. I have not touched the N/A IP settings.
Reply #9July 01, 2009, 08:08:31 am
92EcoDiesel Jetta
Re: Turboing a N/A
« Reply #9 on: July 01, 2009, 08:08:31 am »
ilikevwdiesel, how loud over a stock exhaust is it with the 2" straight pipes? Does it ever backfire? What would you say is the power gained with the 2"?
Arb, have you checked your mpg not towing? How heavy is it?
Reply #10July 01, 2009, 08:23:06 am
arb
Re: Turboing a N/A
« Reply #10 on: July 01, 2009, 08:23:06 am »
My 3950 pound car gets about 40 mpg going 65 - 75 mph. This is a rough calulation. I have not done precise tests yet as I still don't have the car's speedo working, so I use my GPS to stay clear of the Law Man.
Reply #11July 01, 2009, 08:26:14 am
ilikevwdiesel
  • 1202
Re: Turboing a N/A
« Reply #11 on: July 01, 2009, 08:26:14 am »
it's a little loud but nothing like an NA would be...backfire? never
My Bio
Reply #12July 01, 2009, 09:08:27 am
Kantdrivefast
  • 196
Re: Turboing a N/A
« Reply #12 on: July 01, 2009, 09:08:27 am »
My exhaust consists of just a 2.5 downpipe and its not too bad idling, still loud... but get your foot into it ;D
Reply #13July 01, 2009, 10:27:23 am
arb
Re: Turboing a N/A
« Reply #13 on: July 01, 2009, 10:27:23 am »
Do you mean afterfire? Backfire = intake, afterfire = exhaust
Can diesels even "backfire" (afterfire)?
Good question. I didn't think it was possible if it was running correctly - maybe a common rail diesel could spray after the exhaust valve is open... but wait, they do that now to clean the DPF :-) and they don't after-fire in a noisy way.
Reply #14July 01, 2009, 02:12:48 pm
SolarSteve
  • 264
Re: Turboing a N/A
« Reply #14 on: July 01, 2009, 02:12:48 pm »
I'm a pretty long way off from this.  I just picked up a spare motor (1.6 N/A)that I plan to rebuild and figure if I am going that far I may as well turbo it.  I probably won't even get started on the re-build for months.
How and exactly where do you plumb in a EGT line/gage?  Is the a port on the turbo for it?  And are K14 turbos readily accessable?  Are there different intake/exhaust manifold for different turbos or are they all the same?
Thanks for the info
Steve
91 Jetta 1.6 N/A
