Author Topic: Clutch set up for Vanagon TDI swap  (Read 10211 times)
June 30, 2009, 02:17:03 am
midwestfalia
  • 34
« on: June 30, 2009, 02:17:03 am »
What is the preferred set up for a Vanagon TDI swap at 50 degrees?  I will be running pp520's and a chip.  Whats the beefiest set up?  Any help would be appreciated.
Thanks
Dave
82 diesel aba westy, 89 westy, 98 TDI
Reply #1June 30, 2009, 07:13:39 am
westyventures
  • 45
Re: Clutch set up for Vanagon TDI swap
« Reply #1 on: June 30, 2009, 07:13:39 am »
I always install the 1Z/AHU flywheel and clutch assembly, now that HA-Projekt supplies the nice replacement tranny input shafts to match the TDI clutch disc. Note that there are two small tabs jutting from the TDI pressure plate that should be bent flat (hammer down) and also one small spot of clearancing needed inside the bell housing.
Karl Mullendore
www.westyventures.com
Reply #2July 02, 2009, 03:23:17 pm
midwestfalia
  • 34
« Reply #2 on: July 02, 2009, 03:23:17 pm »
Thanks for the info Karl.  I will look into the HA Projekt input shaft.  I like the idea I can use fairly readily available parts this way.  Thanks
Reply #3July 03, 2009, 05:27:45 am
« Reply #3 on: July 03, 2009, 05:27:45 am »
See my build and go to clutchnet.com. They will custom make anything for you.
Reply #4October 05, 2009, 10:53:32 pm
Syncroincity
  • 727
« Reply #4 on: October 05, 2009, 10:53:32 pm »
Does anyone have a convenient source for the T3-TDI input shafts? HA-Project website does not list them... Notter motorsport has them, but only takes wire transfer payments (200 euros w/ shipping & taxes :o)
http://www.tdi-umbau.com/getriebe-t3/getriebeeingangswellekupplungswelle-tdi.html
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #5October 06, 2009, 02:46:38 pm
blackdogvan
  • 574
« Reply #5 on: October 06, 2009, 02:46:38 pm »
Thanks
Dave
Gasser or diesel bellhousing?
1991 Vanagon 1.9 mTDI
Reply #6October 06, 2009, 05:42:59 pm
westyventures
  • 45
« Reply #6 on: October 06, 2009, 05:42:59 pm »
Thanks
Dave
I would never run the gasser bell housing and adaptor plate, the TDI's torque will flex and distort the plate and possibly pull threads. (I've seen it happen more than once) The diesel bell is the best way to go @50 degrees, the Overland/Eurospec (mexican) bell for 15 degree setups. No more reason to use adaptor plates.  8)
Karl Mullendore
Reply #7October 06, 2009, 05:46:51 pm
westyventures
  • 45
« Reply #7 on: October 06, 2009, 05:46:51 pm »
HA-Projekt was getting 120 euros + 32 shipping. No reason to have to pay any taxes. Gotta pay to play. These shafts make the job so much nicer.
Karl Mullendore
Reply #8October 06, 2009, 07:27:37 pm
Syncroincity
  • 727
« Reply #8 on: October 06, 2009, 07:27:37 pm »
Agreed, I have no problem paying for it, but I'm trying to avoid the VAT... HA Projekt does not have them on the website.
I wish I'd known about these before I put the bellhouse on and sealed up the output flanges :P I take it the TDI flywheel & clutch are larger, and w/ a higher clamping force? Otherwise, I was considering the VR6 pressure plate...
JC McCavitt
'98 Jetta Wolfie
Reply #9October 06, 2009, 07:40:21 pm
westyventures
  • 45
« Reply #9 on: October 06, 2009, 07:40:21 pm »
I think something crashed on HA's website, it appears to be an older version. I'd email them to check. I just sent an email to them through eBay since that's how I got my last one and need a couple more.
The TDI flywheel uses a 228mm disc, same as wbx and VR6. the VR6 PP bolts right up, but as with the TDI PP you need to bend over the two tangs that stick up and also be sure to transfer a TDC mark from your old DV flywheel/clutch.
Karl Mullendore
Reply #10October 12, 2009, 10:06:12 am
blackdogvan
  • 574
« Reply #10 on: October 12, 2009, 10:06:12 am »
Karl I've heard your feelings on the adaptor plate before but since its what I have & since I sprung for one of your tdi starter adapters its going to stay! I may remake it in steel tho...
Any thoughts on the best clutch upgrade to use when using the gasser bellhousing on a tdi setup??
Reply #11October 12, 2009, 10:38:49 am
westyventures
  • 45
« Reply #11 on: October 12, 2009, 10:38:49 am »
Kennedy makes upgraded pressure plates that should work.
Karl Mullendore
Reply #12September 18, 2016, 12:48:03 pm
rotaecho
  • 33
« Reply #12 on: September 18, 2016, 12:48:03 pm »
What if building from ground zero; new DK tranny with modified TDI input shaft, new AHU engine, LUK clutch/flywheel, with the DV BH, but none of the existing DV flywheel/clutch components exist.
Why would you need to transfer the old DV to the new setup? I'm missing something.
-Will
1982 Westfalia 1.6na diesel aka Betsy Bertha The Tortoise
