How to Clean Injector Bores in Head
Topic: How to Clean Injector Bores in Head (Read 2123 times)
June 24, 2009, 07:22:49 pm
Doakster
June 24, 2009, 07:22:49 pm »
Any tips on how to clean the injector bores in the heads. I just pulled out my injectors tonight to get them rebuilt.
Anything that needs to be done to the bores in the head for cleaning other than a solvent clean and a good vacuum?
1991 VW Jetta 1.6TD (Formally an ECO), Giles LDA Pump and Injectors, Techtonics 2.25" Down Pipe and Exhaust system, Rebuilt Trans with 3.94 final drive and a Peloquin Limited Slip Diff, Front H&R Sport Springs, MK4 VR6/1.8T front brakes, Single Round Headlight Conversion.
June 24, 2009, 11:42:55 pm
Re: How to Clean Injector Bores in Head
June 24, 2009, 11:42:55 pm »
if you're dang sure you got a good vacuum - a strong pipe cleaner brush might work well. I clean mine out every time i have the head off.
Blue 2009 CR140 Jetta CBEA/CJAA. Malone stage 2. EGR/DPF/Exhaust-valve deletes. 2.5" open exhaust. ADP Turbo swap. 1-stage nitrous kit.
THROWN ROD
