turbo compressor nut torque?
Topic: turbo compressor nut torque? (Read 5576 times)
June 22, 2009, 03:35:55 pm
jwspin
June 22, 2009, 03:35:55 pm »
what should i torque the nut to on my compressor wheel on a k14 turbo from an eco diesel?
thanks
-jared
June 23, 2009, 06:35:32 am
jwspin
Re: turbo compressor nut torque?
June 23, 2009, 06:35:32 am »
nobody? i need to get this turbo back together today.....
thanks in advance
-jared
June 23, 2009, 07:01:56 am
arb
June 23, 2009, 07:01:56 am »
I see no one on Vortex answered either... Did you try calling a local turbo shop and ask them? Maybe call the guys you got the rebuild parts from ?
June 23, 2009, 07:16:57 am
jwspin
June 23, 2009, 07:16:57 am »
yeh i might have to, i remember that a few years ago on here a bunch of folks were rebuilding turbos and i was hoping someone would chime in...
June 23, 2009, 08:20:53 am
jwspin
June 23, 2009, 08:20:53 am »
yeh this turbo was taken apart years ago and i cant find where everything was written down. can you remember what torque numbers have you used? i read somewhere that on a t3 you hand tighten onto the nut and then add another 1/4 turn. i figured there was something similar for the kkk turbos....
June 23, 2009, 11:14:33 am
June 23, 2009, 11:14:33 am »
the k24 is 28" lbs + 1/4 turn,
The k14 however has a MUCH smaller shaft size.
Better talk to a vendor to get the correct specs.
June 24, 2009, 09:08:01 am
jwspin
June 24, 2009, 09:08:01 am »
is the guy still on here that sold the dieselicious rebuild kits? thats the one i got maybe he would know the torque spec. i think his name was jake.
-jared
June 24, 2009, 12:50:22 pm
June 24, 2009, 12:50:22 pm »
Quote from: libbybapa on June 24, 2009, 11:32:27 am
Nope, hasn't been on here for a few years. Sorely missed also.
uh huh
June 24, 2009, 02:58:03 pm
June 24, 2009, 02:58:03 pm »
don't you need to properly orientate the nut for proper balancing as well?
June 25, 2009, 06:41:43 am
jwspin
June 25, 2009, 06:41:43 am »
if the nut is ground you do. i had a t3 that you could tell had been balanced as a unit because the nut and compressor wheel were ground together. does anyone else have any good turbo contacts if jake is not around?
thanks
-jared
