Author Topic: Batt. light mystery.  (Read 6300 times)
June 13, 2009, 04:18:22 pm
  • 3468
    • McScrubbins Body Wash
« on: June 13, 2009, 04:18:22 pm »
batt holds 13.3 volts.
alt charges at 14.3 volts.
when the car is turned off the batter gradually drops 0.1 volts every second and stops at 13.3 (give or take a couple tenths).
My battery light flickers and is sometimes solid while driving and this is all the time. Any thoughts?
I tried playing with the rpm while monitoring the voltage at the battery terminals and rpm made no difference.
I am under the impression that these voltages are adequate.
I was planning on running a secondary battery in the trunk.
I'm totally stumped.
Reply #1June 13, 2009, 07:33:28 pm
clbanman
  • 705
    Cambridge, Ontario
Re: Batt. light mystery.
« Reply #1 on: June 13, 2009, 07:33:28 pm »
If your alternator consistently charges at 14.3 and your battery holds 13.3 there is nothing wrong with either.  You have something wrong in the light circuitry.
Calvin
91 VW Golf 1.6NA 5spd
Reply #2June 13, 2009, 09:51:06 pm
« Reply #2 on: June 13, 2009, 09:51:06 pm »
Your battery sounds fine.. at least from a voltage perspective.   Batteries are partly capacitors and so it's normal for it to slowly drop in voltage from the charging voltage (14.x) to the charged voltage (13.x) soon after the engine is switched off.
On our cars a flickering or dimly glowing alternator light is pretty common.  When it's associated with normal charging voltages it almost always results from a increased resistance in the ground path between the alternator and the cluster... the additional resistance allows a small voltage to develop, which drives the BAT light slightly.
The fix is to check the ground path carefully... clean metal-to-metal contact wherever the alternator bolts to the engine block, good grounds from the tranny to the chassis, and chassis to cluster (star ground under the dash).  You may find directly grounding the alternator case helps.
In terms of a solid light... that's a different issue and almost always means that the alternator is in distress... are you able to measure the output voltage while you're on the road and when the light comes on?
« Last Edit: June 13, 2009, 09:55:24 pm by Vincent Waldon »
Reply #3June 13, 2009, 10:10:29 pm
  • 3468
« Reply #3 on: June 13, 2009, 10:10:29 pm »
Thanks for the prompt replies!
Okay, i'll check the grounds. I have added an additional ground though and replaced the old grounds with very large ones. The terminals on my battery are both lead now.
An important symptom is that the light goes out with my high beams on.
"If your alternator consistently charges at 14.3 and your battery holds 13.3 there is nothing wrong with either.  You have something wrong in the light circuitry."
Reply #4June 14, 2009, 09:52:54 pm
maxfax
  • 2126
« Reply #4 on: June 14, 2009, 09:52:54 pm »
One of my past rabbits did just about the same thing..  Turned out to be a bad ground to the cluster itself..  I cleaned the plug and terminals on that and it fixed it right up... The gauges worked better too!
Reply #5June 15, 2009, 11:36:14 am
catlin_cava
  • 1954
« Reply #5 on: June 15, 2009, 11:36:14 am »
I'm having the battery light constante on my gasser right now, battery is fully charges and altenator is new...
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #6June 15, 2009, 04:18:36 pm
  • 3468
« Reply #6 on: June 15, 2009, 04:18:36 pm »
hey yeah my temp gauge just stopped working. I'm going to dig out that ground.
fixed my gauge. it was unrelated.
where is this ground?? I had a poke about with the cover off under the steering wheel. Que?!¿
« Last Edit: June 15, 2009, 10:23:22 pm by Smokey Eddy »
Reply #7June 16, 2009, 08:29:34 pm
maxfax
  • 2126
« Reply #7 on: June 16, 2009, 08:29:34 pm »
I pulled my cluster out, it was the actual connector into the cluster that was giving me problems..
Reply #8June 17, 2009, 04:48:50 pm
  • 3468
« Reply #8 on: June 17, 2009, 04:48:50 pm »
and the fix was? replacing the whole pig tail?
Reply #9June 17, 2009, 07:47:50 pm
maxfax
  • 2126
« Reply #9 on: June 17, 2009, 07:47:50 pm »
I cleaned the contacts on both the pigtail and the cluster with some electrical cleaner and crokus cloth. then bent the little contacts in the pigtail so that they pressed against the contacts in the cluster a bit tighter...
Reply #10June 18, 2009, 04:01:39 pm
  • 3468
« Reply #10 on: June 18, 2009, 04:01:39 pm »
PURE GENIUS!
