Author Topic: VNT15 1.6td compressor surge? (video)  (Read 2690 times)
June 08, 2009, 07:06:41 pm
hamradio
  • 282
« on: June 08, 2009, 07:06:41 pm »
So, I know, I know, supposedly compressor surge cannot happen on a diesel.  However, my turbo is making a not so awesome noise.  It is a chirping-barking-ish kind of noise if I rev it up a couple k to build some boost, and then let off, in neutral.  I can also hear it if I'm shifting from 1st to 2nd.
My vanes are shut all the way until 15 psi, when they open.
The video.  Boost gauge is 0-25 psi.  Hopefully the sound can be picked out over the rattling of some trim.
http://www.youtube.com/watch?v=nUXKkoJ5BLE
Reply #1June 08, 2009, 09:20:07 pm
Re: VNT15 1.6td compressor surge? (video)
« Reply #1 on: June 08, 2009, 09:20:07 pm »
I watched your video and couldn't hear anything abnormal, hopefully someone else will be able to hear it ::).
Reply #2June 09, 2009, 03:22:23 am
carrizog60
  • 978
« Reply #2 on: June 09, 2009, 03:22:23 am »
the only noise i hear is at idle...
Portugal
Reply #3June 09, 2009, 05:13:20 am
hamradio
  • 282
« Reply #3 on: June 09, 2009, 05:13:20 am »
Ugh, I figured it would be like that.  I can hear it through headphones, but I also know what to pick out.
I'll try to get something better tonight.  The engine kinda chirps a bit and you can feel it shake through the steering wheel as it goes back down to idle.
Reply #4June 21, 2009, 03:11:25 am
OM617
« Reply #4 on: June 21, 2009, 03:11:25 am »
That is your problem. You need to make a system that moves the vanes progressively with the throttle or adjust the screw setting for minimum vane position.
