Author Topic: changing coolant flange  (Read 5431 times)
June 08, 2009, 05:10:01 am
92EcoDiesel Jetta
« on: June 08, 2009, 05:10:01 am »
I need to change the coolant flange (one between #3&4 glow plugs). How much coolant will come out of there? Should I drain the head first? If so, where's the best place to drain?
Reply #1June 08, 2009, 05:25:16 am
macka
  • 957
Re: changing coolant flange
« Reply #1 on: June 08, 2009, 05:25:16 am »
drain the engine completely. I always do this unless the antifreeze is less then a few months old. It gives you a chance to see if your getting crud in the cooling jacket.
Quote from: Vincent Walden
Reply #2June 08, 2009, 05:32:26 am
92EcoDiesel Jetta
« Reply #2 on: June 08, 2009, 05:32:26 am »
Where's the drain plug? Still waiting for the Bently.
Reply #3June 08, 2009, 07:32:19 am
BellCityDubber
  • 251
« Reply #3 on: June 08, 2009, 07:32:19 am »
no "plug"
bentley states to drain the system by removing the lowermost rad hose at the thermostat housing/lower waterpump flange.
Reply #4June 08, 2009, 07:02:00 pm
Jettage1
  • 202
    Past VWs: 80 Scirocco S, 90 GTI, 00 Passat GLX
« Reply #4 on: June 08, 2009, 07:02:00 pm »
no "plug"
One of the reasons I question the alleged superiority of German engineering.  It ain't rocket science - heck, even my '67 MGB has a petcock on the radiator (and yes, the electrical system is just fine, thanks.)  ;D
Steve
92 Jetta EcoDiesel
     pumped by Giles...powered by Frybrid...functional by dumb luck
Reply #5June 08, 2009, 07:12:15 pm
« Reply #5 on: June 08, 2009, 07:12:15 pm »
But wait, there's more.
Pulling the lower rad hose will only drain the rad.  In order to drain the block you need to pull the t-stat housing, and in order to do that the power steering pump has to come out of the way. ::)
Reply #6June 08, 2009, 07:34:43 pm
Turbinepowered
  • 1206
« Reply #6 on: June 08, 2009, 07:34:43 pm »
Not on my Fox. :D
Reply #7June 08, 2009, 08:12:57 pm
sdwarf36
  • 159
« Reply #7 on: June 08, 2009, 08:12:57 pm »
I wouldn't sweat the amount of coolant leaking out from changing the flange.  Put a drip pan in the general location and have at the flange.  If the coolant is old, then it's worth draining the whole system, tho.
Andrew
 I'm with you on this one. Draining the coolant in these cars is a crewl hoax.  :-[  I've said to myself "s**t-i got to get to the thermostat-might as well pull the motor since I'm 1/2 way there."  :-\
91 Jetta on WVO na / td swap in progress.
 "VW happiness is having 4 working door handles."
Reply #8June 08, 2009, 08:15:40 pm
92EcoDiesel Jetta
« Reply #8 on: June 08, 2009, 08:15:40 pm »
Andrew
That's exactly what I did when I looked under the car and saw what a PITA dirty job it would be. Anyway the new flange is in and it don't leak there no more but I've got another problem. Please see this thread and give me some help.
http://www.vwdiesel.net/forum/index.php?topic=19876.0
Reply #9June 09, 2009, 03:29:13 am
Jettage1
  • 202
« Reply #9 on: June 09, 2009, 03:29:13 am »
Yep, and after pulling the t-stat housing three times to try to quell a pesky leak, you know I was ready to push it off a pier.  Finally decided to change the water pump due to severe pitting in the aluminum where the O-ring seats.  That fixed the bastard.
Oh and did I mention how much crap you have to pull to change the @#$% water pump?  They just tack stuff on the engine with no thought to future maint. issues. (Course that gives the stealerships service money...)
And no, I'm not bitter... :P
Steve
92 Jetta EcoDiesel
Reply #10June 09, 2009, 07:20:31 am
92EcoDiesel Jetta
« Reply #10 on: June 09, 2009, 07:20:31 am »
Sounds like a real PITA! Is this pitting on the water pump housing? Should I replace the water pump (that's not leaking) when I do the timing belt as insurance? I see that you can buy a water pump with and without thr housing. Which way should I go?
Reply #11June 09, 2009, 10:52:24 am
Jettage1
  • 202
« Reply #11 on: June 09, 2009, 10:52:24 am »
To each his own...  I wouldn't have done it except that I couldn't get the plastic t-stat housing & O-ring to seal properly.  I finally decided that the pitting in the aluminum on the O-ring sealing surface on the water pump was the culprit.  If yours doesn't leak, I'd leave well enough alone.  I don't think it's possible to remove the water pump without also removing all accessories and the IP too.
My $.02...
Steve
92 Jetta EcoDiesel
Reply #12June 09, 2009, 11:01:18 am
92EcoDiesel Jetta
« Reply #12 on: June 09, 2009, 11:01:18 am »
You probably could have scraped off the gunk in the pitting off the aluminum, clean with solvent and fill with epoxy then sand smooth and it would then seal against the o-ring. Don't know if there's enough room to do that.
For an easy and accesible drain of the coolant, how about removing the 4 pin radiator fan switch on bottom driver's side? It may not be the lowest point in the system but draining from the water pump sounds horrible.
Reply #13August 20, 2013, 03:07:48 pm
92EcoDiesel Jetta
« Reply #13 on: August 20, 2013, 03:07:48 pm »
 Bringing back a really old post. Having just done a water pump replacement and having studied it closely, the block can be drained by the barb that goes to the metal pipe, wthout removing the t-stat.
Pulling that hose may be difficult. but if you tee  into it with a hose coming down with a plug that can be removed when you want to drain the block, it can be done without mess or spill.
Anyone done something like that?
Reply #14August 20, 2013, 05:30:18 pm
« Reply #14 on: August 20, 2013, 05:30:18 pm »
 ::) you all work tooo oooo hard...
why not heat it up with cap off bottle so no pressure... warm enough to open thermo stat.. then pull lower hose off rad? drains it all.. easy peasy.. if not warm enough.. restart it fo ra few min.. you will see when it starts to open..
how i do it...
